Question about Kenmore 62642 / 62644 / 62649 Microwave Oven
No power Hi I have no power at all, checked plug in and its fine, checked breaker box, thats fine. But still no power. The microwave has been well maintained but it just died on me help! I dont know where to find the fuse at ,what color is it or where is it located and if needed where do i get one? any info would be greatly appreciated!
  • Kenmore Master
  • 9,098 Answers
A microwave can be dead for many reasons.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can probably find an exploded view by entering your FULL model number here: http://www.searspartsdirect.com
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 23, 2008
No power, no lights, no clock. Nothing works on my Samsung over the range microwave model SMH17138
Your microwave may be plugged into a regular receptacle which is on a circuit breaker often in a cupboard above the range.Check around to see if anything else is not working. Check your circuit breaker box for a breaker that needs resetting. If you see one out of line with the others turn it off and then back on. Good luck..
Dec 09, 2016 | Samsung Microwave Ovens
Will not heat food
HELLO.
The solution to make your microwave oven to be able to heat food is detailed given below.
1 Make sure the door is closed. If the door is not closed tight, the microwave will not function.Sometimes food will get stuck in the door and prevent the latch from working. Use the paper towel to get the food out, then close the door carefully and listen for the latch to click.
2 Check the power sources. First, make sure the microwave is plugged in; the plug may have shifted or slipped partway out of the socket. If it is plugged in and still does not work, voltage test the outlet the microwave is plugged into. If you are not getting a reading, the breaker is probably blown. Reset the breaker for that outlet in your home's circuit breaker box.
3 Reset the microwave breaker. Take the back cover of the microwave off with a screwdriver. Inside you will find a motor. Most microwave motors have a small red reset button on them. Hit that button. Your microwave should work again if the breaker was the issue.
Thanks
Sep 20, 2011 | Frigidaire Microwave Ovens
Microwave, kenmore 721.89822, will run when powered, but will not cook, no microwaves
HELLO.
Follow some straightforward troubleshooting steps to make your microwave work like new again.
Thanks.
Sep 18, 2011 | Kenmore 80822 80823 80824 80829 1500...
No Power
Remove cover. Check that the fuse is good, if it is good, check power from power supply to main board.
Oct 29, 2009 | Sharp R-316FS Microwave Oven
Lg micorwave, lam1180st refridgerator and microwave were plugged into the same outlet. i heard a loud pop. circuit breaker popped. i reset and the frige works fine. Microwave does not have power. the...
It is possible that the interconnection link(s) between the two sockets in the duplex outlet have blown apart. Turn off power at the electrical panel for this circuit, remove the outlet from it's box, and check the interlink on both sides. If obviously burned, replace the socket. A better option is to run another duplex cable from the breaker box to the outlet from a new breaker, cut the interconnections on the new socket, and wire the new cable to the isolated part of the socket. This supplies full power to each half and allows both units to run at the same time.
Oct 19, 2009 | LG 1.2 Cu. Ft. Mid-Size Microwave -...
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
Jul 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How can I get the power to come on my Sharp microwave?
The problem may be an electrical one. Microwave ovens require a lot of power. Often, they use most of the power available to the circuit they are plugged in to. If there is not enough power in the circuit to feed the microwave and whatever else is plugged into that same circuit the fuse will blow or the circuit breaker will kick off.
Go to your electcical box, and check the breakers or the fuses. If one of the breakers has kicked, reset it by pushing it all the way off and then back on. If the fuse is blown, unscrew it and screw in a new one of the same amperage.
good luck. please rate my answer. thanks
Feb 12, 2009 | Sharp KB-6015K 1000 Watts Convection /...
Kenmore 62642 / 62644 / 62649 Microwave Oven Logo
102 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
