Question about Frigidaire Refrigerators
I have a refrigerators model # GLRT188WDSC, the door not level so when you close the door it does not close properly. Is this a manafactures defect?
  • 4,793 Answers
Most fridges have adjustable feet so you can get them to sit correctly on the UNEVEN FLOOR.use a spirit level to confirm.vertical in two planes and of course horizontal.
Posted on Nov 10, 2010
Why does the freezer door not close securely?
need to level the refrigerator properly where the doors will gently close themselves. it is normal for the doors to pop another door open if closed rapidly. model number?
APPLIANCE 911
Jan 04, 2016 | Refrigerators
I have a GE side by side refrigerator (Model #GSL25JFXLB and the doors will not close all the way
Leveling the refrigerator so that the doors close easily is one of the most important ways of getting the doors to work properly. Here is a link to a Profile/Artica Service Manual Go to page 24 through 26 where the manual explains what you need to do to get the doors to open and close properly. If you have questions I will be here to answer any questions you may have, Thank You Sea Breeze
Mar 09, 2013 | GE GSL25JFXLB (250 cu ft) Side by Side...
When I close my side x side frig the freezer door pops open
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Oct 17, 2012 | Kenmore Side by Side Refrigerator
MZD2766GEQ - MAYTAG Side-by-side refrigerator fresh food door will not stay closed? hinge or gasket? inside seal?
Normally the most common fix for the doors is to level the cabinet. Leveling the cabinet will also adjust the doors to help level them and help them close properly.
May 04, 2011 | Refrigerators
Left door of the refer isn't closing properly, must manually feed it thru the little channel at the top for it to fold in and close
check the door hinges a in place:
The door latch and lower hinge pin should hold your refrigerator door in place..
Uncover the door by removing the screws.Take the door off and pack bottom hinge with washers and make sure hinge brackets on cabinet are tight.
Check the seal is clean and pliable:
If seal is gapping, one solution is to warm with a hairdryer and pull outwards gently.
Check the refrigerator is properly leveled:
Adjust the middle hinge to straighten the lower portion of the door. Use a level to ensure the door is flush.
After fitting the door back again,check to see if the seal is touching on all sides when the door is closed. If not, you will need a new seal.Refrigerator is properly leveled.and hinges should be properly placed.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 06, 2010 | Amana AFD2535DES French Door Refrigerator
KitchenAid Superba refrigerator door not closing
have you adjusted the levelers underneath to make sure f/f is square.use a level on top.
Mar 06, 2010 | KitchenAid Superba Architect KSCS25INSS...
Doors creak loudly when closed and pushed from the outside. Don't when open.
This short solution may help solve your creaking problem. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly. Putting vaseline insid the hinge pins too is a good idea.
Let me know if I can assist you better, Thanks, Sea Breeze
Apr 27, 2009 | LG LFC21760 Bottom Freezer French Door...
Refrigerator Door does not always seal properly
When you close it put pressure on the door to displace air inside and create a vacuum. Then release it.
Aug 06, 2017 | Refrigerators
How do you level the kitechenaid side by side
Hope this helps solve your problem, Let me know. Thanks, Sea Breeze
Feb 27, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Refrigerators Logo
62 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Sal De
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
