Question about Brother HL-6050DN Laser Printer
Reset drum unit counter brother hl-6050-dn - Brother HL-6050DN Laser Printer
Press the "Go" and "+" switches together until the menu "RESET
PARTS LIFE" appears on the LCD display. Select the Drum Unit using the "+/- " switches, then press the "Set" switch
Posted on Jan 21, 2011
OPC-Life over error. How to fixit
If the print quality is still acceptable you may be able to perform a reset on the drum counter. If print quality is bad you will need a new drum. Reset instructions at this site.
Brother HL 2150N Drum Unit Reset Instructions
May 26, 2015 | Brother HL-2150N Laser Printer
BROTHER HL-7050 CHANGE DRUM STILL INDICATES CHANGE DRUM
you need to reset drum counter by pressing go & + together "reset parts life" "drum unit"
then press "SET" button.
that's it.
Feb 12, 2010 | Brother HL 7050 Laser Printer
Resetting the Drum counter on a Brother HL-2040
Hi.
Have you recently replaced the drum?
  • The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
  • The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
  1. Open the front cover of the printer.
  2. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  3. Close the front cover.
Reset the drum counter only when you replaced the drum unit with a new one.
Aug 03, 2009 | Brother HL-2040 Laser Printer
How do I reset the Drum counter on a Brother HL-5140?
Caution! Reset the drum counter only when you replace the drum unit with a new one.
To reset the Drum Counter:
1. Press the cover release button and then open the front cover of the printer.
2. Press and hold down the 'Go' button until all four LEDs are lit. Once all four LEDs are lit, release the 'Go' button.
3. Close the front cover. Make sure that the Drum LED is now off.
Jul 16, 2009 | Brother HL 5140 Laser Printer
How to reset the drum counter on a brother printer HL5270 DN
There should be a way to reset the drum setting. Call Brother they will help you are look in your manual.
May 21, 2009 | Brother HL-5270DN Laser Printer
Brother HL 1250 Laser. Drum & page counter
Reset the drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
  4. close front cover
Mar 23, 2009 | Brother HL 1250 Laser Printer
Brother printer HL 5250 DN. The drum light was flashes and I have replaced the drum kit and toner cartridge.
Brother Drum Reset Instructions
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
Dec 05, 2008 | Brother HL-2070N Laser Printer
Beother Hl 2040 printer
f the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
Aug 28, 2008 | Brother HL-2040 Laser Printer
Brother HL-5250DN
if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Sep 01, 2007 | Brother HL 5250DN Laser Printer
Printer drum light on
Have you already replaced the drum? If you have not replaced the drum that may be why you are getting smudges. If you have already replaced the drum, here is the reset procedure. The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one. The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below: Open the front cover of the printer. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button. Close the front cover. CautionReset the drum counter only when you replaced the drum unit with a new one.Related Models HL-2030, HL-2030R, HL-2040, HL-2040R, HL-2070N, HL-2070NR http://www.tonerovernight.com
Mar 31, 2007 | Brother HL-2040 Laser Printer
Brother HL-6050DN Laser Printer Logo
5,677 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
