Question about GE JVM1870 Microwave Oven
Ge microwave Hi, I have model number jes1039wj02 ge microwave. The arm does not spin with the glass on it. The arms will rotate but not with the plate on it. What should I do?
  • Anonymous Mar 18, 2014
    I need the rotating arm plastic rings
  • GE Master
  • 8,865 Answers
You probably have a cracked turntable coupler or a failing motor.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand: http://www.youtube.com/watch?v=rPSWi_z7M58
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it.
We have critical safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jun 23, 2008
The glass turntable broke. Where can I find a replacement?
Go to www.ebay.com Type: make and model of microwave, and refine search to glass plate.
Apr 02, 2012 | GE Spacemaker JVM1540 Microwave Oven
Hi, I have a GE JVM1440 & the plate won't spin
This is commonly caused by a turntable motor that has worn out and needs replaced. The following link explains how to access and replace one:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
If the model number is correct, the part number is WB26X10038. You may also consider replacing the turn table shaft (coupler), part number WB06X10138. You can purchase replacement parts at the following websites: searspartsdirect.com pcappliancerepair.com appliancepartspros.com repairclinic.com The first three sites listed offer helpful exploded view diagrams to assist you in parts location/identification. If you have any questions, please post back and let me know. I hope this helps you.
Dec 09, 2009 | GE JVM1440 Microwave Oven
The spinning plate in my Microwave broke.
Hi there! Universal Glass plates are available from a good local appliance spares shop. Please note that size of the plate, the coupler (The centre connection point to the plate) and the ring size (on which the plate rests) are all important to the correct function of the plate. Take these along for correct matching if you can or they may even keep your particular Model and Brand. Best Wishes and Good Luck, JUS004
Aug 30, 2009 | GE Microwave Ovens
JVM1871sk04 GE XL 1800 Microwave
PS50009 is the part number for your glass plate that will cost you $60.00, go to partselect.com, simply put the part number... and place an order ....you know what to do next...
cheers pls mark my solution
Nov 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Plate does not rotate freely and make noice
There is no belt in your model - the turntable is motor driven. The problem is either the motor itself or the coupling that engages the glass tray.
The motor (GE part # WB26X10038) is a very common failure as the internal gears are plastic and tend to strip.
You can view the motor at this link...
www.microwaveglasstrays.com
Jul 10, 2008 | GE JVM1650 1000 Watts Microwave Oven
Glass plate turntable won't spin any more
no microwave 1.5 yrs old has a belt - they're all motor driven
Jan 10, 2008 | GE XL1800 1100 Watts Microwave Oven
GE Profile Spacemaker Microwave - JVM1660BBC
The turntable has a small motor underneath it that rotates the glass tray. You could have a motor that is going bad, or the plastic spindle (what the glass plate sits on) could be slipping. You can access the motor through the bottom panel. Be careful to make sure the microwave is unplugged for attempting any repairs inside. There is potentially as much as 14,000 volts in the high voltage network around the magnetron. Let me know if this helps.
Jun 27, 2007 | GE JES1039 Microwave Oven
Non-Stick surface peeling off inside microwave.
Normally you can strip and sand the old paint, get it squeaky clean, and use appliance paint. Yes indeed it is a heat-resistant enamel. You can get it from appliance parts stores, Wal-Mart, or home centers, etc. BUT if it's under warranty I would call GE Customer Relations with your model and serial numbers. They're at 1-800-386-1215 (8-6 ET) and I would also suggest you ask them for a referral to a GE-authorized servide center in your area. Good luck. I appreciate your thoughtful rating of this answer.
Jan 29, 2007 | GE JES1231 Microwave Oven
GE JVM1870 Microwave Oven Logo
66 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
