Question about Dell Inspiron 6000 Notebook
Cannot Start (turn on) my Inspiron 6000 Laptop
For about a week now when I turn my laptop on from Standby or Hibernation, I have to press (with force) and hold the on botton for a few seconds. Today, it refuses to turn on.
I don't think this is a battery issue... Maybe the on button is malfunctioning?
Is there another way to turn on the computer?
Can this be repaired?
Thank you!
  • aplasa Jun 17, 2008
    do you recommend calling dell for this issue, or brining it to any computer repair shop?
  • 42 Answers
Yea the button can be replaced
Posted on Jun 17, 2008
  • OMAR MUKTHAR
    OMAR MUKTHAR Jun 19, 2008
    call the dell.. thats the most recomended
Dell inspiron 6000 dead when connect power adeptor to laptop the led light on psu goes off is this mother board fault or psu.
If the led on the power supply turns off after connecting it to your laptop, the problem most likely lies with the power supply especially if the machine will run on battery power. This can be tested by
1. Turn the laptop off.
2. Remove the battery and power supply plug.
3. Press and hold the power button for at least 15 seconds to reset the laptop.
4. Replace the power supply plug into the laptop without replacing the battery.
5. If the computer will not start and there are no lights turning on on the laptop the power supply is bad.
6. Replace the battery and attempt to start the machine both with and without the power supply plugged in.
Apr 04, 2011 | Dell Inspiron 6000 Notebook
Tip
Battery won?t charge and AC adaptor not recognized
I have a Dell Inspiron 6000 that just turned two years old.
After one year, my dell 6-cell battery started to falter, so Ipurchased a new 9-cell battery. This worked fine until a couple ofmonths ago when I noticed that my 65W adaptor was frayed. I bought anew 65W Dell Inspiron 6000 ac adapter andit worked well for about a week until I noticed that my battery wasn’tcharging at times. If I was patient, or unplugged the adapter andplugged it back in, the battery began charging and all was saved.
dell-inspiron-6000-laptop-battery.jpg?w=200
This lasted only a short time until my Dell Inspiron 6000 batterywouldn’t charge at all for long periods of time, and sometimes thecomputer wouldn’t turn on, even if plugged into the wall. I thought itmight still be the adaptor, so I borrowed a fully functioning 90W Delladapter from a family member to test the system. This worked better,but still not great.
When I removed the battery and started only fromAC power, the functionality was also intermittent. Usually, if thecomputer actually started, I received the start-up error “The Inspiron 6000 AC AdapterType could not be determined, etc. etc. etc.” After pressing F1, thecomputer booted, but if the battery wasn’t in, the computer didn’tusually last long before shutting off. Unsure if maybe the battery wasthe problem, I put the 6-cell Inspiron 6000 batteryback in, and it too wouldn’t charge, although (together with the 90Wadapter) my computer would at least start more consistently if pluggedin. The error remained however, and sometimes the system stopsrecognizing power and switches to my ever dwindling battery power untilthe adapter is recognized again.
The problem is with the jack on the motherboard inside our Inspiron 6000’s. This is the jack you plug your power plug into on the back of the laptop.
Somehow the jack gets worn and does not make correct contact withthe laptop so the Laptop does not see the power supply as a legit Dellbrand. So the powersupply will not charge the laptop battery and run the laptop at the same time.
DC power jack repair guide. Do-it-yourself instructions.
Modern laptops are all sold with built-in wireless laptop ac adapter.Some power notebooks used by corporate road warriors will have powerfulcellular adapters that connect the laptop to the Internet via the cellphone infrastructure
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with dell pa 12,dell e1505 and Dell Inspiron 6000notebooks. If your laptop is out of warranty, then you can fix theproblem by resoldering DC-IN jack on the system board. If it’s stillunder warranty, it would be fixed at no charge to you. Problem symptoms:
  • Laptop randomly shuts down without any warning.
  • Power LED and battery charge LED start flickering when you wigglethe power cord or the AC adapter tip on the back or your laptop.
  • The battery will not get charged.
  • When you plug ac adapter for laptop, the laptop appears to be dead and there is no LED * activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. dell pa 12 and Dell Inspiron 6000 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system laptop board witha magnifying glass. In most cases you get the power problem because ofa bad connection between the DC jack and the system board, you’ll see acrack between the DC jack connector and the system board.
on Jan 22, 2010 | Computers & Internet
Dell Inspiron 6000 New Hard Drive, Now no Hibernate or Standby
Try to enable hibernation from command prompt
Click on start click run type cmd then ok, black screen will appear then just type command:
powercfg /hibernate on
If there is a problem with PAE we gonna need to disable PAE
Feel free to ask for questions
Jun 05, 2010 | Computers & Internet
My daughter charged her machine and can't turn it on although the light is on
hello, while laptop was being charged was it powered off?? or hibernation mode?
TRY THIS:- Disconnect power cable from the laptop, then remove the battery from the laptop with power unplugged and battery out open up laptop and hold the power button down for about 15 second and then let it go. Plug the battery and power cable back and try turning it on...
let me know if that works or need further trouble-shooting
good luck,
Amar Sondhi
Oct 29, 2009 | Dell Inspiron 6000 Notebook
Screen stays black after closing and then opening Inspiron 6000
you try pressing the power button once?  or maybe even pressing any keys.
also try adjusting your power management
vista) start. control panel. power option.  Edit plan settings.
xp) right click anywhere.  properties.  screen saver tab.  power management.
Mar 09, 2009 | Dell Inspiron 6000 Notebook
Cant open laptop
Is this when you start it up, or after closing the lid and the machine being on standby?
Jun 25, 2008 | Dell Inspiron 6000 Notebook
Screen went black
When you close the lid, there is a small pin that engages the case and flips a switch to tell the laptop the case has been closed. The monitor will ALWAYS turn off then, because otherwise, the heat build up would burn the screen! Do not try to defeat this, replacing an LCD screen is usually more expensive than the value of the laptop!
Now, that all being said (and please remember), the situation you have now is (hopefully) just that the laptop tried/succeeded in going into ACPI "suspend" or "hibernate" mode.
1. Remove all cables and 10/100. Remove all USB devices. Just leave the PSU (AC power supply) connected.
2. Press the power button firmly, JUST once. Wait. And I mean WAIT, because some laptops can take 2 minutes or more to come out of suspend/hibernate, if they were very busy at the time it was shut down.
3. If the LCD screen lights up. you are done. But if it does not light up now, then proceed to step 4.
4. Press and HOLD the power button down for 10 seconds. This forces the laptop to shut down completely, even from suspend/hibernation. Some unsaved files may be lost, but tghe laptop goes cold, so you can start ACPI over again.
5. After a few minutes, press the power button again, firmly, just ONCE and for 1 second max. Laptop should start up OK.
6. Once it starts up, go to START MENU/SETTINGS/CONTROL PANEL/POWER SETTINGS and search for the "hibernation" tab. Turn hibernation OFF. your laptop obviously has some problems or lack of responsiveness with hibernation (most do). Use suspend, instead. It is much safer,. faster, and still does a good job of saving HDD and LCD wear. Please let me know how this goes for you, there are other more detailed problems that may be involved here, but I suspect this is most likely.
Feb 11, 2008 | Dell Inspiron 710m Notebook
Dell Inspiron 6000 Notebook Logo
62 people viewed this question
Alun Cox
