My boiler a renova bulex thema classic gives an error on the display is F9
Yeni bir bulex duvar 24kw takip calistirdiktan sonra yaklasik 5dakika sonra pervanaden sesler geliyor
Posted on Apr 19, 2013
2 Suggested Answers
SOURCE: I have a RENOVA boiler
You simply do not have enough water pressure inside your heating system and therefore the Boiler will not fire up. On your Control Panel, press the Bar/Mode button to display the system pressure... Then under the Boiler you will find a valve (On ours its a Blue knob), turn it anti-clockwise to let in more water, when the indicated pressure reaches that required by your system (On ours its 1.7 Bar) shut the value (Turn knob clockwise) - Then you can restart the system.
Posted on Oct 07, 2012
We have a Faema E92 Elite, 3 head. The display keeps giving an error code: Boiler overpressure E1. Already replaced the heating element (the gasket as well). How do we get rid off the error message?
You have one of two things going on here, the boiler is really over a safe pressure (very dangerous condition if error is for real) or the pressure sensor is malfunctioning. For safety sake I would have a professional look into this, a boiler explosion is a very dangerous.
Nov 29, 2016 | Washing Machines
How do I clear the fault codes ?
How To Fix Maytag Washer Error Code F9 E1 ...
www.appliancerepairlesson.com/2013/.../maytag-washer-error-code-f9-e...
Dec 10, 2013 - The error code F9 E1 will be displayed on most newer Maytag washers and ..... My whirlpool duet wfw94heaw0 gives the error code F09 E01.
KitchenAid f09 error code Dishwashers Questions ... - Fixya
Nov 29, 2015 | Dishwashers
SAUNIER DUVAL model 31-026. Where can I obtain a troubleshooting manual?
Boiler Manuals: Saunier Duval - Plumbase
https://www.plumbase.co.uk/documents/index/10000204
Boiler Manuals for the Saunier Duval range. ... Saunier Duval Thema Range · Saunier Combitek F23E · Saunier Duval Isomax F28E · Saunier Duval Sylva ..
Aug 20, 2015 | Heating & Cooling
I have a RENOVA boiler and on the screen it shows F1 problem. What does it mean?? And what I have to do?? Thank you
Apr 13, 2011 | Heating & Cooling
Hello! Yesterday some "click" sound came from my
The click you heard was the pilot light cutting off. Have you tried to relight the pilot to get it started again? If the pilot will light, but not stay lit, you will need to replace the Thermocouple.
That should solve your problem.
Mar 05, 2011 | Heating & Cooling
My precious Gaggia Classic machine has developed a "fatal error". It will not pass water through the shower head. I have tried cleaning, re-priming to clear air block, several times over. The pump appears...
Remove the shower, then the 2 allen wrench screws for the diffuser, careful do not loose the spring ad valve seat that is above the diffuser, now turn machine on to see if water will come thru, if water flows, problem is either screen or diffuser blockage, if no water then you need a stronger descaler because blockage is in the boiler, at the solenoid or from the pump. Most likely in the boiler, if you have a boiler gasket go ahead and open the boiler to clear the blockage.
Jul 04, 2010 | Gaggia Classic Espresso Machine
Push ok to start boiler
Try opening the steam valve before pressing ok.
This will let water into the boiler before the heat element comes on.
Apr 23, 2009 | Saeco Incanto Classic Espresso Machine
Kemore microwave model number 721.63763300
F9 is an error that indicates an inverter board or magnetron
has failed. With the F9 error cleared, start the oven and
listen for a ticking sound. The inverter will attempt to
'fire' the magnetron 5 times.(ticking sound). If can hear
ticking, replace magnetron. Check owners manual. Part may be covered by limited warranty.
Mar 26, 2008 | Kenmore 62622 Microwave Oven
F9 code on stove
Here's what F9 code means:
1. Door lock safety circuit on ERC sensed Replace the door latch assembly
2. Door Lock Warning Check door lock circuit or Replace Clock
Try pressing and holding the door latch to unlock position and then press cancel for a few seconds. The latch should return to its original position.
Jan 23, 2008 | Ovens
Heating & Cooling Logo
640 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
