Question about Vizio VP322 32 in. Plasma TV
It would take 8 to 10 times to get tv to stay on. I decided to just leave on and not turn off for a week The tv powered off. There is no light or reponse to the remote or power switch on side of the tv.
  • 748 Answers
Hi
The TV has electronic components that have changed value due to heat. A reputable local tech should be able to handle this repair.
Thanks
Posted on Nov 10, 2010
  • ABRsvcs Nov 10, 2010
    The constant heat change inside a set can sometimes affect the solder joints. The question here is whether or not the TV will return to previous behavior once it cools off. If so, then odds are that there are poor solder connections inside. Also there are cases where some of the filter capacitors fail. This can cause excessive noise on the data lines inside which effectively "confuse" the set, I would get a repair estimate for this from a local shop. If it is poor solder joints, then the repair should be a simple one of labor only.
    Keep us posted,
    Dan
    Scholar:
  • 98 Answers
Pull the tv apart. carefully lay it on its face and remove 70-100 screws( no kidding) You also have to remove the speaker and plastic on the bottom, theres more screws hiding under there.
Look over the power board. Its the board in the middle. There are several capacitors on there that are well known for failing. I just bought a vp322 that was dead. I replaced about 10 bulged or leaking capacitors and im back up and running. If you google vizio vp322 you will find posts and pictures of the common failure with this unit.
You can get caps from mouser, digikey, bdent, or if you want cap kit where the gathering is done for you, theres a guy on ebay that sells cap kits for these tvs.
Best of luck!
Posted on Feb 12, 2011
Panasonic Viera TC-P65S1 No Picture, Red Light Stays on for 10 Seconds then Clicks Off
Need power board. Unplug then Have to remove all screws on back. The big board that the plug goes to is power board. Get serial number and find on Amazon or Internet. Usually around 150$ replace. It is easier than sounds. Any time power will not stay on or will not come on it is the power board. Tics are now just like computers. If u can change a hard drive u can do this
Sep 27, 2014 | Panasonic Viera TC-P65S1 65 in. HDTV...
Dead, power light flashes 10 times then nothing for 4 seconds then flashes 10 times then repeat. This is after I inserted an SD stick.
Unplug,replug the tv about hour later.Tv will,reset itself,back to factory setting.Should have power now.Still have the same problems.The power supply board is dead.That the board,where the power a/c plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Aug 07, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
The green light flashes for 2 minutes and screen goes light blue
You have a defective power supply, most likely faulty electrolytic capacitors on the power supply board. The board can be repaired, I fixed one for a friend, it took 2 new capacitors $0.90 each.
Sep 23, 2009 | LG 47LC7DF 47 in. LCD HDTV
LG TV Turns itself off
Sounds like it could be a poor connection in the power plug or a ' dry joint ' on the power board, if it's the latter, it will respond to light thumping at the side of the tv. If that's the case it needs resoldering by a technician..
good luck !
Mar 30, 2017 | LG 32LG30 32 in. LCD HDTV
OVERHEATED?
yes open it up get dust out run small fans in nit see how long it stays on
Sep 15, 2008 | RCA HD52W56 52" Rear Projection HDTV
I have a Hitachi Plasma TV model 55HDS69 that recently went black while being watched. I turned the main power off and unpluged it overnight and tried turning it back on, but only the red standby light...
Do it again, only this time unplug any video and audio inputs and outputs, unplug it from any power source, and leave it sit overnight.
I had the same problem with my Hitachi. I called a local repair shop and he said to unplug it for 10 minutes and start it again. That didn't work so I got it ready to take to the shop. I disconnected everything. The next morning I decided to check it one more time so I reconnected everything. It worked just as it had before.
I hope it works for you.
Jul 13, 2008 | Televison & Video
Monitor Black, Green Power Light Flashes Monitor is 4 yrs. old
Assuming you've already checked your driver and system settings, tried a different monitor, and checked the cable and connector pins, this would almost certainly be a problem with the power or signal circuit board inside the monitor.
Jan 19, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
Tv turns on, but when you turn it off it won't turn back on.
sounds like its a cold solder connection somewhere in the set or a capacitor thats bad in the power suppy.. These problems are the most dificult to troubleshoot unless they happen all the time.sorry I wish I could give you more info..
Mar 26, 2006 | Samsung TCC1340 13" TV
Vizio VP322 32 in. Plasma TV Logo
963 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
