Question about Brother IntelliFAX 1250M Fax
Broken Plastic latch - Brother IntelliFAX 1250M Fax
  • 1,110 Answers
You did not mention which latch but I am familiar with the thermal head latch breaking on these models. It is a somewhat common failure. If the latch looks like this:
Then you can order them thru precisionroller.com
Their parts numbers are E3882 for the left side latch and E3883 for the right side.
If these are not the latches you see broken then perhaps give me a bit more info so I can help out.
Thank You for using Fixya.
WheatlandServices
Posted on Nov 10, 2010
Tip
Repair a Broken Plastic Tab / Latch on a Carrying Case
Has the plastic latch on your toolbox or carrying case weakened or completely broken off?
Use a bicycle tube repair patch to re-attach a broken plastic tab or reinforce a weak latch on your tool carrying cases. The rubber patch is designed to vulcanize (basically stiffen) after application and the adherence is great. I layer two on each latch in opposite directions to improve strength and cover a larger area.
Be sure to thoroughly roughen the plastic and remove all "shiny" surfaces on the plastic with sandpaper for best adherence. Most bicycle patch kits include the patches, a metal tool to roughen the plastic, and the solvent necessary to react with the soft red rubber on the patch....and they are cheap - less than $2.
on Mar 06, 2015 | Hardware & Accessories
My Bosch Dishwasher door sticks shut at the end of the cycle. I can open and close it with ease during the cycle, but once it finishes I have to pull really hard to open it.
see all this steps and fix it. God bless you
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Door wont shut
Door Hinge
Door Catch
Door Lock
Door Latch
Door Strike
Apr 05, 2013 | Miele Dishwashers
Older model (unknown) Whirlpool Dishwasher. Door latch failure. Dishes trapped inside.
You may have to break the little handle off to open it and order a new door latch mechanism. Just be careful. This is a lip latch so it wont be hard if you can get to where the latch connects. Use the internet and model to order new one.
Jan 23, 2012 | Whirlpool Dishwashers
Ge front loading washer door won't unlock
Some machines do this when the power is cut, there should be what looks like a screw heat on the front of the handle which will allow you to unlock the door and open it. If there is still water inside you will need to empty the machine first. There is usually a hatch at the bottom of the unit, open this hatch and you will find a cap to unscrew, unscrewing this cap will empty the contents of the machine onto your floor so be prepared!!!!!
May 08, 2011 | GE Washing Machines
The back seat latch on my 2005 Honda CRV not not
check to see if parts are jammed in the path of movement
Sep 12, 2009 | 2005 Honda CR-V
Broken latch
Replacement latch can be found at amazon, click here Amazon com mailbox latch and chose needed one. Wish you best of luck. John
May 03, 2009 | Solar Group Black Aluminum Mailbox Post,...
GE front load washer WSXH208v1ww door latch
Unfortunately, the "door latch assembly" is what you would need. It comes with a new concrete front tub counter weight which is redesigned to not be able to contact the door latch switch on out of balance spins. It is also a lot of work to replace. (you can not get just the little plastic part) Please don't rate this solution, as anything but a Fix-Ya lowers my score, and I know you don't want to shoot the messenger.
Mar 08, 2009 | GE WSXH208A Front Load Washer
42 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
