Question about Universal Electronics - Others
The electric water heater is not heating any water in my 2001 Keystone rv.
    Problem Solver:
  • 35 Answers
Check to see if your GFI has tripped. That heater should be on one. Or your breaker for the tank.
Posted on Feb 03, 2011
Where is the water pump on a 28sgs fifth wheel
look in the cabinet work underneath the sink.look also above your potable water tank inside the rv. maybe look around inside and out of the hot water heater.
Feb 04, 2016 | Keystone 2012 Cougar Xlite 28SGS
Does the water heater and furnance run on gas and electric?
If the units are in a RV then yes, they both may run on gas and DC (battery power). The furnace requires gas to provide heat and DC power to run the fan. A water heater may be gas or electric, but if gas, it requires gas to heat and DC power to ignite. If the water heater is electric it requires AC power to heat.
Oct 15, 2015 | Water Water Heaters
Where is water pump located on a 2008 montana 285rld 5th wheel.
You may get the info from the following:
Montana Mountaineer RV 285 RLD -- Keystone RV Dealer ...
? 2:07
www.youtube.com/watch?v=zATfbwsZX68
May 14, 2012 - Uploaded by Lakeshore RV Center
Lakeshore-RV.com - Lakeshore RV Center Dealer to the World! This Montana Mountaineer RV Fifth Wheel ...
Oct 01, 2015 | Keystone 2008 Montana Mountaineer Edition...
Should ele and gas work to gether onwater heate .dont now if we used water or gas.or bouth
Some RV water heaters are both gas and electric, depending on what hookup is available at campground.
Otherwise, water heaters are electric or gas.
Gas water heaters have a 3" to 4" round vent pipe located on top.
Electric water heaters have electric wire connected on top or side of heater, but no vent pipe.
Look at images on following link
http://waterheatertimer.org/Leaking-water-heater.html
Gene
Water Heater Timers Save Money
Mar 20, 2015 | Water Water Heaters
Where is the pump located in a Keystone 27 rbs RV
usually inside where the water fills are you might have to take a panel or two off to get to it don't forget the water heater bypass inside of where the got water heater is
Aug 17, 2014 | RVs
Keystone manuals rv
You would need to buy a propane hot water heater. Unfortunately you can not convert an electric hot water hearter to propane.
I didn't want to use either an electric or gas hot water heater so I invested in a solar hot water heater for my home. Best thing that I ever did as far as saving money. Once it is paid off then the benefits are lower utility bills.
Good luck,
Marty
Jul 15, 2014 | Water Heaters
Keystone hornet rv
water heater is shorted, or the wires to it are shorted. or the breaker is bad. we use an ammeter on that breaker line (clamp....)
oops it is shorted, then inspect the line
the check current in to the heater, oops is shorted.
i have a DC amp clamp meter, that finds shorts. like magic.
Dec 16, 2013 | RVs
Electric heating not working
Have you checked for additional switch, perhaps on rear of water heater on side of cover that wiring goes into for element. How far have you gone with it?
May 15, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Make sure switch on water heater at back where electrical wire is attached is in the on position, as well as any breaker marked for water heater. Some RV's also share a connection at a switch by counter in kitchen that only allows either microwave, or water heater, not both at same time. Possible that ECO, Thermostat assy in behind black cover on outside may be faulty, but not very likely. If you verify that there is hydro to connection at back of tank, I would suspect element is faulty. Not uncommon to burn element out if it was on, before tank was full of water, or when tank was emptied for some reason.
Mar 27, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Heating element
Is the water gas or electric?It could be both.So if it gas then the burner is inside the front cover.If it's a electric one then it would have two wires coming out of it.
Apr 30, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Electronics - Others Logo
124 people viewed this question
Top Universal Electronics - Others Experts
Are you an Universal Electronics - Other Expert? Answer questions, earn points and help others
