Question about Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat
Hi The straps on my maxi cosi car seat won't tighten when I press the grey circle button. Can I get it fixed? thanks Tara
SOURCE: Maxi-Cosi Tobi Straps not working
I guess that you have perhaps solved your problem now but if not, have you seen this?
http://maxicosi.com/tobi/default.aspx
Hope this helps.
Chris
Posted on Apr 29, 2009
SOURCE: Maxi Cosi Tobi straps locked
hi i had the same problem so i took it back to toys r us where i got it from, they rang manufacture and were advised that they r going to recall them as it is a fault. hope this helps
Posted on Sep 19, 2009
  • 419 Answers
SOURCE: straps on my maxi cosi tobi car seat is stuck,
Hi, This sounds like either the harness is twisted at the back or inside, or there is a build up of dirt etc that could have fallen through the **** strap area. I would suggest that you go to this link and contact the supplier who will be able to clarify this for you. http://www.maxi-cosi.com/maxicosi/forms/contact.aspx?mode=contact&language=gb-en I hope this helps.
Posted on Nov 15, 2009
  • 419 Answers
SOURCE: I need a replacement shoulder strap pad for maxi cosi infant seat
If you contact this link, you will be able to purchase spares for this seat:
I hope this helps.
SOURCE: can't take off maxi cosi carseat cover, because
Slack off the straps as far as possible and recline the seat. Open the strap guard door on the rear of the bit of the seat that reclines (Item 3 on diagram http://www.maxi-cosi.com/media/producthandleidingen/maxicosi/PrioriFix.pdf). The shoulder straps can be released from the metal clasp which is in here.You can now pull the straps through the back of the seatand release the cover.
Posted on Dec 12, 2009
Can you re thread straps on maxi cosi tobi?
Hi
Due to the safety implications of this being incorrectly done it should not be attempted at home. The carseat needs to come in for our engineers to re-thread the harness and ensure it is performing as it should be.
Please visit www.maxi-cosi.com and select the country you're in, then use the "Contact Us" tab for your enquiry to go through to the customer care team in your country who can provide further assistance.
Apr 05, 2013 | Maxi-Cosi Tobi Car Seat - Jet Black
Ive pushed button and straps on my maxi cosy cabrio car seat will not loosen, help??
Hi
When you press the silver / grey button at the front of the carseat you should pull both harness straps at the same time and it should loosen the harness. If this is not happening the carseat needs to be inspected. Please contact your retailer with proof of purchase if it is under 12 months old. Alternatively please let us know what country you're in and we can put you in touch with the correct customer care team to assist.
Jul 06, 2012 | Maxi-Cosi CabrioFix (Black Reflection)...
Hi i have got a maxi cosi cabriofix car baby car seat and cannot seem to remove the cover at the bottom where the grey circle is how do i do this and can i was the cover in the washing machine once...
Good Morning
The grey tensioner strap appears to be stitched in place but it isn't. Follow it around under the bottom of the carseat and the strap is in a piece of plastic catch shaped like an H on it's side. Wiggle one way then the other to unhook from this catch, and the carseat fabric can be removed (where the grey circle part is the fabric is tucked underneath slightly, once you've unhooked the tensioner strap you'll be able to get the fabric off easily).
Hand washing is recommended, but if you have delicate or handwash cycle on machine this is also suitable. Use a mild detergent and maximum temp 30 degrees for washing. Do not tumble dry: Do not leave in direct sunlight to dry. Ensure fabric is completely dry before putting it back on for use as damp fabrics may result in mould or mildew growth.
Remember never remove the harness straps from the carseat, the fabrics can be completely removed while the harness remains in place!
Aug 04, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Need instructions for adjusting straps in maxi cosi tobi car seat also on how to remove covers to wash thanks tracy
Good Afternoon
Please visit www.maxi-cosi.com and select the country you're in, then select the Tobi carseat and download a replacement user manual which will have information on how to adjust straps and remove fabric.
Jul 13, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Maxi-cosi tobi strap tensioner not working. able to tighten straps when child is in seat but when buckle is pressed to release straps and get child out, unable to loosen straps tensioner will not let go.
Hi, Make sure that when you go to loosen the shoulder straps that the **** strap is pulled toward you, otherwise you cannot make the shoulder straps loosen, this is a safety feature. Hope this helps.
Jul 28, 2010 | Maxi-Cosi Baby Gear
Can't take off maxi cosi carseat cover, because grey strap at the bottom doesn't come loose.
Oct 20, 2009 | Maxi-Cosi Priori
I've removed the maxi cosi cabriofix cover to wash it and misplaced the round grey button that adjusts the shoulder straps can i replace this
Yes you can, this is called a Quick Adjuster I think and costs very little.
Contact www.maxi-cosi.com who will advise you.
I hope this helps.
Jun 28, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Maxi-Cosi central tension strap has been pulled out
I would always suggest that you take this back to the retailer to have the part professionally repaired, or contact www.maxi-cosi.com who will be able to advise you.
I hope this helps.
Jun 14, 2009 | Baby Gear
Buying New Straps Our Covers
Just go to the maxi cosi website and call the contact number. Or you can dowload the online usermanual, it has a order form.
Jan 23, 2009 | Maxi-Cosi Priori
Removing maxi-cosi priori cover
under the strap that is just below the grey round plastic length adjuster there is a stiched loop. Pinch the stiched loop and you will see that it can be removed.
Sep 06, 2007 | Maxi-Cosi Priori
Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat Logo
415 people viewed this question
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Douglas Dinnebeil
Douglas Dinnebeil
Marc Cohen CPSTI
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
