Question about Sony 4GB Memory Stick PRO Duo Memory Card
My memory stick pro duo 8 g , no open in my computer . I try to open memory stick file , but no open , please help my . Rogelio Benabe from Puerto Rico
  • 5 Answers
SOURCE: memory stick pro duo pc connection
To change the size of the virtual memory paging file
You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings may also prevent you from completing this procedure.
  1. Open System in Control Panel.
  2. On the Advanced tab, under Performance, click Settings.
  3. On the Advanced tab, under Virtual memory, click Change.
  4. Under Drive [Volume Label], click the drive that contains the paging file you want to change.
  5. Under Paging file size for selected drive, click Custom size, and type a new paging file size in megabytes in the Initial size (MB) or Maximum size (MB) box, and then click Set. If you decrease the size of either the initial or maximum page file settings, you must restart your computer to see the effects of those changes. Increases typically do not require a restart.
Note:
  • To open System, click Start, point to Settings, click Control Panel, and then double-click System.
  • To have Windows choose the best paging file size, click System managed size.
  • For best performance, do not set the initial size to less than the minimum recommended size under Total paging file size for all drives. The recommended size is equivalent to 1.5 times the amount of Ram on your system. Usually, you should leave the paging file at its recommended size, although you might increase its size if you routinely use programs that require a lot of memory
  • To delete a paging file, set both initial size and maximum size to zero, or click No paging file. Microsoft strongly recommends that you do not disable or delete the paging file.
Posted on Feb 11, 2008
welcomejee
  • 10594 Answers
SOURCE: sony memory stick pro duo format error
Use this memory stick in other Sony camera to confirm it. Problem still exist means memory stick is bad/ internal breakage.
Posted on Jun 12, 2008
  • 6 Answers
SOURCE: Dell Inspiron 1525 Memory Card Reader Compatibility
There is no big differece between the two. Both of those can work on your DELL memory card. Cheers!!
Posted on Jan 28, 2009
Fixe_You
  • 1800 Answers
SOURCE: Unable to retrieve photos from 4GB Sony Memory Stick Pro Duo
use the sony utility that comes with ur device?
Posted on Mar 22, 2009
  • 586 Answers
SOURCE: Error C 13 01 when insert Memory Stick Pro Duo with adapter -- which does fit.
    This error code is for Memory Stick. the Countermeasure are :
Format the “Memory Stick” or internal
memory.
CAUSE :
“Memory Stick” or internal memory is
unformatted.
Thanks for using fixya.
Posted on May 24, 2009
Sony memory stick duo pro 1gb is using for Sony handycam is suddenly started giving error message like reinsert memory stick. I have important pictures and video in it, now i need to recovery them. Do...
Hi Devika,
Buy a card reader that can read your memory card and connect to the computer. (Less than $8 in Sri Lanka). Connect it to PC and insert the card to the card reader.
Download Recuva and run it. select the memory card. Try to recover the files.
Best of Luck!
Sep 21, 2011 | Sony 1GB Memory Stick PRO Duo Memory Card
How Can I read my Memory Stick Pro Duo MARK 2 on my Computer? MY problem is I cannot read my Memory Stick Pro Duo Mark 2 on my computer but my computer is showing another Removable Disk(F:),which is my...
    • 1 Visit the Sony Support site (see Resources) and download the Sony memory card software. You will need to specify your operating system. Save the file to your desktop.
    • 2 Double-click the downloaded file to launch the installer.
    • 3 Follow the onscreen instructions to install the Sony memory card software. Restart the computer after completion. Once the computer starts back up, it will recognize the Memory Stick Pro Duo when inserted into the computer's memory card reader. You can browse the files using Windows Explorer or the installed x-Pict Story software.
May 31, 2011 | Sony 4GB Memory Stick PRO Duo Memory Card
1GB Memory Stick PRO Duo Memory Card: i have a memory stick pro duo card .... but now we...
Hi sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 17, 2010 | SanDisk 1GB Memory Stick PRO Duo Memory...
    My 8 gb memory stick duo is full and now it cannot be read by any psp or computer. Help me please.
    make sure it's not in lock mode. if youre still having problems, you may need to reformat the stick.
    Mar 09, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
    I have a Memory Stick Pro Duo 8GB will not open on my computer or camera..was working then quit. Advice please
    Problem for Sony Memory Stick PRO Duo (2GB) for PSP I have a Memory Stick Pro Duo 2GB will not open on pc &also not formated
    Jan 02, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
    Can't open files in sony memory stick pro duo 1gb.
    did you reformat the memory disk before you put all the files in there? if you didn't, then that could be the problem.
    Sep 05, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
    Getting my pictures back onto my camara
    Connect camera with computer with USB cord, power up camera, computer will recognize it and if you installed Sony image mixer software that will prompted, close it, click My Computer, click removable Disk, click folder to open it, now you can copy pictures from computer and paste here but be careful about picture file name should be DSCxxxxx some thing, if you have already changed file names then camera will not show these picture in playback mode though pictures would be on memory stick.
    Apr 28, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
    Problem with corrupted files
    Dont panic... Just insert the memory stick in to a card reader and donot try to open it. but make sure that your memory stick gets detected.Then you can use any of the file recovery softwares to recover the photographs with out formating.I generally use the free app "PC file recovery". In case your memory stick is not detected in the first place, then There is no other option other than formatting. But the recovery software can recover 90% of the photos even after formatting.
    If this doesnt work, post back. I will explain in more detail.
    Nov 09, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
    Psp illiterate
    Yes there is a way. What you will need is a PC, Some form of Memory stick Duo card Reader, And a PSP Compatible Memory stick Duo/Pro Duo.
    If you havent already used the memory stick inside the PSP it will not have the correct Formatted file System for use in the PSP. but you can create the file system using your computer.
    heres how to do it ! :
    1) plug your Memory stick Duo/Pro Duo into the card reader on your computer.
    2) open my computer, locate the Memory stick usually found under the "devices with removable storage" area.
    3) once inside the memory stick, create 2 seperate folders. One called "PSP" and the other one called "MP_ROOT".
    4) Navigate into the "PSP" Folder and create 3 Folders, "MUSIC", "PICTURE" & "VIDEO"
    5) Copy & Paste the Necessary files into each Subsequent Sub-Folder within the "PSP" Folder.
    Note : The PSP Can only handle Certain File types for Pictures, Music, And Video. i would suggest Navigating to http://psp.about.com/od/hardwarefirmware/p/compformat.htm before you transfer your files to ensure that you are adding files which are Viewable/Readable by The PSP's software.
    Hope this helps !?
    Oct 27, 2008 | Sony PlayStation Portable (PSP) Console
    Sony 4GB Memory Stick PRO Duo Memory Card Logo
    26 people viewed this question
    Top Sony Electronics - Others Experts
    Sandy Moore
    Sandy Moore
     Grubhead
    Grubhead
    Computer Links
    Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
