Question about Motorola Mobility RAZR V3
Why does it show cloudy screen instead of clear one
  • 4,102 Answers
Hi, the problem you are having is going to be to do with 1 of 2 things, now the 1st and most likely cause is going to be that the data ribbon that connects the screen to the circuit board in the bottom half of the phone has become brittle and needs replacing, you will lose all the screen if you continue to use it as it is, thats the most likely problem you got,
now their is also an outside chance the lcd screen is at fault it could be that its over heated or your phone left some where hot or humid, the best thing to do if you want to keep using the phone is to take it to an independant phone shop and ask them about the screen data ribbon and they will be able to look at it properly and tell you exactly whats wrong.
the ribbon is cheap to but but its not something you can fit yourself so you need to work out if the phone is worth fixing or not, shop around and see what price you can get then this will give you a better idea if you want the phone fixed or not.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Nov 10, 2010
Ice machine making cloudy ice
ice maker may need cleaning, filter and/or scale collector changed. IF there is no water fiter you should add one.
Jan 23, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
Laptop screen white and cloudy
From your description I would expect that the LCD panel has shorted or gone open. Either way the panel needs to be replaced. Depending on the age of the laptop you may be better off getting another laptop, new or used, and just swapping out the hard drive to your drive. If you decide o do this be sure that the laptop you buy is compatible to your old drive.
Jun 08, 2017 | Computers & Internet
How can I clean my cloudy glasses? How can I stop my glasses getting cloudy?My Bosh model is "Bosh Classixx"
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Jan 04, 2011 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Cloudy film on dishes and glasses from the diswasher
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
Dec 24, 2010 | Maytag Dishwasher
After installing a grohe faucet my water is cloudy most of the time. The cold water will eventually clear up after it runs awhile, the hot water, hardly. I never had cloudy water before installing the new...
It air bubbles in the water giving the appearance of cloudy.
It would seem that the aerator in the new faucet is particularly efficient.
If you take a glass of "cloudy" water and let it stand for a few mins, you should find it clears up nicely as the air slowly bleeds out through the top.
Dec 12, 2010 | Grohe Plumbing
Some of our dishes in the top and bottom rack are showing a white film, especially on plasticware and the outside of pots, pans, ceramic or regular glasses. Also some glasses on top rack , but not all,...
Nov 19, 2010 | Amana 24 in. ADB1500AW Built-in Dishwasher
Why do my glasses go cloudy
All glasses eventually go cloudy in dishwashers, the problem is far quicker and more noticeable with lead crystal which specifically should never be washed in this way.
The cloudiness cannot be reversed: it's caused by millions of tiny cracks in the glass surface as a result of both the chemical and physical processes inside a dishwasher. Some products claim to include a "glass protect" function, but it just slows down the damage instead of stopping it. Commercial glass-washers used in bars and restaurants also cause this damage, but as the wash cycles are far quicker and the cleaning agent is specifically for glass the damage occurs more slowly. In any case, glasses don't usually last long enough in commercial use to show this damage as they usually scratch, chip, or break before it shows.
All you can do to totally avoid the damage is to wash glasses manually and to never put lead crystal in the dishwasher. If that's not an option, then you can slow the damage by washing glasses at the lowest possible temperature: you'll find that some cleaning products are better than others at low temperature and it's not always the expensive brands.
Sorry there's no fix for your cloudy glasses, but I hope that I've helped to to avoid further damage. Please take a moment to rate my reply.
Sep 08, 2010 | Miele 24 in. G643Vi Plus Built-In...
Cloudy picture on rear projection tv
Your picture guns and mirror is dusty. You can try cleaning yourself if you know what your doing, but I would let a qualify tech to do it.
Nov 20, 2009 | Philips Televison & Video
Tv shows cloudy picture
What you said sounds like a focus problem. A focus proble is usually caused by a problem in the HV setion of the TV either in the IHVT or the HV transformer itself.
May 17, 2007 | Philips E-Box FTR9965 DTV Receiver
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
