Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Lawnmower will not start - Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
  • Matt Olenzek
    Matt Olenzek Nov 11, 2010
    What have you tried.
  • 20 Answers
Does the lawn mower have spark to plug or plugs ? Simple way to find out ia to remove spark plug & reattach wire to plug & hold elecrtode end up against engine block-(make sure you hold onto rubber or else could get a jolt)-and try to start again, should have spark, if not could be that flywheel strip-(magnet) is rusted over & cannot communicate w/coil to acheive spark. If this is the case simply sand the strip w/180 or 220 grit sandpaper & try again. If you have spark then you are probably not getting gas. Pull bottom scrw out of carb bowl & drain into a cup, check for debris. If gas comes out dirty will probably need to remove float bowl completly. Use care when removing & gasket can be re-used. Clean out float bowl & attachment screw-(has a hole in the bottom which feeds gas to engine) reassemble & try again. Hopefully this information helps.
Posted on Nov 11, 2010
My lawnmower stopped
Check the oil. I bet you seized the engine.
May 18, 2014 | Honda HRC216HXA Commercial Lawnmower
Having trouble starting the lawnmower. When I turned it on its side to check the blade and turned it back it started. How can I solve this
Sounds like a odd solution.
After several years of working on small engines, I can tell you that 4 out of 5 times that a lawnmower doesn't start, it is a fuel delivery problem. Other issues could be a weak spark, low compression, or a clogged air filter.
If you have confirmed that the lawnmower has spark, checked the air filter, and can feel a good bit of compression, your problem likely lies in the carb.
The only way to solve this issue is to take it apart and clean it. Some models require that you replace components such as a fuel pump diaphragm. These are popular with Briggs engines.
The process is fairly detailed but you can use this guide to cleaning a lawnmower carb for detailed assistance. Good luck.
May 24, 2013 | Garden
My brut lawnmower wont start?? what can be wrong??
try starting fluid if it fires on that then you have spark if not no spark then if it does then then look into the carb old gas left in for more than 30 days can plug up jets
Aug 26, 2012 | Garden
Lawnmower won't start
is there spark?does it fire on starting fluid
Apr 21, 2012 | John Deere JA65 Self Propelled Mower
Centura 3.8 HP Tecumseh lawnmower not working w/o starting fluid
main jet blocked needs carby service its worth it
May 12, 2010 | THQ The Lawnmower Man
I have a lawnmower with a BSA 3.5 engine that I cannot start, the problem seems to be no spark at the spark plug. As I have never worked on a lawnmower I have no idea what generates the spark on...
Test for spark by placing a screwdriver into the spark plug wire and holding it close to a bolt on the engine. should see a spark (blue). If not, problem is likely the armature (coil). The coil is located under the engine shroud and held in place by two bolts. If you replace this part, (normally $30 to $40) you must ensure a proper air gap. Auto parts stores have inexpensive repair manuals to help.
Lee
Cherokee Small Engines
Apr 21, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
