Question about Mad Catz Bluetooth Headset for PS3
It has been charging for 10 hours and still isnt fully charged
  • 11,896 Answers
Most likley the internal battery is leaking and won't hold or take 100% charge.
Posted on Nov 10, 2010
Testimonial: "want the answer i was looking for but now i know what the problem is "
  • 1 more comment
  • dani_boy_69 Nov 10, 2010
    this is the initial charge out of box been charging since 12 am and its now 10 pm (spain)
  • Nate Stansfield
    Nate Stansfield Nov 10, 2010
    Yep. I think your battery is defective.
    ok , think ill just give it back save up a bit more money and get myself a better one any suggestions?
HBS-800 China made won't hold charge no more than 3 hours
Surly it didn't specify 79 hours of charge time did it? For 10 hours of operation the charge time should be around 20 hours or less depending on the charge controller device. I would hope it shuts the charging off once it senses the battery to be fully charged. Assuming all this is working as I've stated then I would conclude it is defective and seek to return/replace under warranty.
Nov 01, 2017 | Audio Players & Recorders
24 v ryobi battery won't charge
Minimum FAST charge is 2 hours if it has a fast charge setting. If not, 6 to 8 hours to charge fully. I leave mine on overnight so about 10 hours..
May 22, 2016 | Ryobi Drills
How do I charge the battery on a 1990 xlh sportster 1200
The voltmeter test provides general indicator of battery condition. Check the voltage of the battery to verify that it is in a 100 per cent fully charged condition. If the open circuit or disconnected voltage reading is below 12.6 V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8 V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE and STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC is 100 per cent
12.6 VDC is 75 per cent
12.3 VDC is 50 per cent
12.0 VDC is 25 per cent
11.8 VDC is 0 per cent
COLD CRANKING AMPERAGE (CCA) for a DYNA battery is 270
Battery Charging Rates/Times (Approximate)
FOR A 19 AMP HOUR DYNA AGM BATTERY
BATTERY STATE OF CHARGE is 12.8 VDC is 100 per cent Charge; Rate of Charge is N/A
BATTERY STATE OF CHARGE is 12.6 VDC is 75 per cent Charge; Rate of Charge at 3 AMP is 1.75 hours at 6 AMP is 50 minutes at 10 AMP is 30 minutes at 20 AMP is 15 minutes
BATTERY STATE OF CHARGE is 12.3 VDC is 50 per cent Charge; Rate of Charge at 3 AMP is 3.5 hours at 6 AMP is 1.75 hours at 10 AMP is 1 hour at 20 AMP is 30 minutes
BATTERY STATE OF CHARGE is 12.0 VDC is 25 per cent Charge; Rate of Charge at 3 AMP is 5 hours at 6 AMP is 2.5 hours at 10 AMP is 1.5 hours at 20 AMP is 45 minutes
BATTERY STATE OF CHARGE is 11.8 VDC is 0 per cent Charge; Rate of Charge at 3 AMP is 6 hours, 40 minutes at 6 AMP is 3 hours, 20 minutes at 10 AMP is 2 hours at 20 AMP is 1 hour
The figures listed above assume that the battery is charging at room temperature. If warmer than room temperature, use a slightly shorter charging time. If colder, use a slightly longer charging time.
The use of constant current chargers to charge maintenance free batteries is not recommended. Any overcharge will cause dry out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F or 43 degrees C during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Apr 22, 2014 | Harley Davidson XL 1200 S Sportster Sport...
Dead battery 1990 xlh sportster 1200
The voltmeter test provides a general indicatorof battery condition. Check the voltage of the battery to verify that it is in a 100% fully charged condition. If the open circuit (disconnected) voltage reading is below 12.6V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester. AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE (OCV) STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
19 AMP HOUR BATTERY =
BATTERY STATE OF CHARGE = 12.8 VDC = 100% Charge; Rate of Charge = N/A
BATTERY STATE OF CHARGE = 12.6 VDC = 75% Charge; Rate of Charge @ 3 AMP = 1.75 hours @ 6 AMP = 50 minutes @ 10 AMP = 30 minutes @ 20 AMP = 15 minutes
BATTERY STATE OF CHARGE = 12.3 VDC = 50% Charge; Rate of Charge @ 3 AMP = 3.5 hours @ 6 AMP = 1.75 hours @!10 AMP = 1 hour @ 20 AMP = 30 minutes
BATTERY STATE OF CHARGE = 12.0 VDC = 25% Charge; Rate of Charge @ 3 AMP = 5 hours @ 6 AMP = 2.5 hours @ 10 AMP = 1.5 hours @ 20 AMP = 45 minutes
BATTERY STATE OF CHARGE = 11.8 VDC = 0% Charge; Rate of Charge @ 3 AMP = 6 hours, 40 minutes @ 6 AMP = 3 hours, 20 minutes @ 10 AMP = 2 hours @ 20 AMP = 1 hour
The use of constant current chargers to charge maintenance-free batteries is not recommended. Any overcharge
will cause dry-out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F. (43 degrees C) during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Chaging batter
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
COLD CRANKING AMPERAGE (CCA) for an XLH battery is 270
COLD CRANKING AMPERAGE (CCA) for a 2001 XLH battery is 270
How do i know if battery is fully charged
Every new camera needs at-least 10 hours to get fully charged. you can count that way may be.. hence there may not be any proper notifications for fully charged battery...
Sep 16, 2012 | Fujifilm Finepix L55 12 Mp Digital Camera...
How long does it take to charge battery. how do I know when we need a new battery
If ur battery is less than a year old,it take about 6 hours to fully charge the battery,after a year the battery weaker,it take like about 8 to 10 hours for a fully charge.The used of the DVD player last only 10 to 20 of used of the DVD player or DVD player the charge light don't lite at all.
Dec 13, 2010 | Durabrand PDV-709
Not starting looking for reasons. dash lights come on and cd player stops for no reason. Last time car started it died right a way then did'nt start again. I changed the starter and the battery is nearly...
it realy sounds like you have knocked the battery flat try to recharge it for a fuw days on a home charger off the car if poss if not poss that should still charge up but it takes a little longer to fully recharge the battery up but it will take at least two or three dayes to fully recharge it the way to work it out how long it should take is this,,,a 40amp hour battery will take 10 hours to recharge at 4 amps thats its max charge too?
or devide the amp hour by 10,,,ie: 60amp takes at 4 amp =15 hours charging,,,but it can be charged at 6 amps then its only 10 hours,,, i know,,,boring huh?
Jun 29, 2010 | 1997 Pontiac Grand Prix
My phones (philips cd445) will not hold a charge for more than a few hours off the cradle...yes I have replaced the batteries, twice. once with disposables, once with rechargeables
You might have what is called "memory'. If you continue to replace the phone on it's charger after each call the battery will "think" it's empty, giving you s short charge time. Next time you replace the batteries (rechargeable) FULLY charge them then leave the phone off the charger until you go to bed at night.
Sep 18, 2009 | Philips CD4452S/05 Digital Telephone and...
Unit will not turn on
Your battery is recharged when connected to your computer. Turn the player off and connect it to your computer via the USB cord. The computer must be turned on. Initial charge should be for 10 hours with subsequent charges 3 to 4 hours for a full charge. A quick charge of 1-1/2 hours will give you a 70 percent charge. A fully charged battery will last up to 15 hours under normal use.
Dec 09, 2008 | GPX MW3837 MP3 Player
Mad Catz Bluetooth Headset for PS3 Logo
521 people viewed this question
Top Mad Catz Video Game Consoles & Games Experts
Robert Little
Level 1 Expert
Dave
Are you a Mad Catz Video Game Console and Game Expert? Answer questions, earn points and help others
