Question about Intermatic T101 - 24 Hr. Dial Time Switch - NEMA 1 Indoor Steel Case - Gray
Where is the pointer arrow suspose to point? (straight down?) I believe my pointer arrow got loose and got moved.
You posted under the T-101 timer.
Intermatic timers, the pointer arrow points straight down.
Posted on Nov 11, 2010
Testimonial: "Thanks, kind of what I thought. It got moved."
The arrow in my game moves really slow and not the speed I move it so I point the arrow and it seem to crawl to where im pointing
Hey Steph, if this occurs only during the game then look for settings or options under the game menu and there should be an option to change the mouse speed. Also if you are running a game that requires a high processor it could be that your computer is just running slow because it cannot a process like that. If it occurs all the time then go to your control panel and under Hardware and Sounds click Mouse (if no Hardware and Sounds, just look for mouse settings). (PS. This is for Vista but I believe it should be the same for Windows XP and Windows 7). Under Mouse properties go to Pointer Options tab. There you should see a section called Motion and that is where you can change the pointer speed. I hope this helps Steph. Please send me a feedback if it does not. Good luck. - Joe.
Oct 22, 2013 | Computers & Internet
On excel, how do I resize and move a pie chart (not the whole plot area)?
click on the frame of the chart, then hover over the frame of the chart. If the cursor is hovered at the corners or centre of each of the sides, the pointer changes into a two way arrow, click and drag at this point to resize. To move the chart, hover over the frame of the chart at any other point and and the cursor changes into a 4-way arrow, click and drag to move the chart to your desired posi.tion
Aug 26, 2013 | Computers & Internet
T104 intermatic stationary pointer moved to the side
T104 pointer is stationary and is supposed to be pointed straight down, assuming timer is installed in vertical position.
Move pointer until it points straight down and apply bit of super glue, or just remember correct location.
Copy following link for detailed information:
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
Jul 15, 2012 | Intermatic & Indoor/Outdoor Rain Tight...
Moved pointer intermatic T104
The time pointer is supposed to be stationary.
On T104 timer the pointer is stationary pointed downward at 6:00 position. So you can move it so it is pointed straight down and add a bit of super glue where pointer meets stem.
Copy following link for instructions how to set T104 timer:
Jul 05, 2012 | Intermatic T104 24h 208-277v Mechanical...
Can I move the stationary pointer clockwise and counterclockwise or will it break the devise
It is not necessary to move stationary pointer:
The stationary pointer points straight down at 6:00, and is used as a mark for setting current time.
Lift and rotate yellow dial until current time lines up with the pointer.
It will not break anything by moving the pointer, but you might forget the current time location.
Open following links to explain how timer works:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#pool
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 27, 2011 | RTO Intermatic T104R3 Timer Switch 220V -...
How do you align the colors?
Press MENU button and ON-SCREEN MENU will appear. Press
POINT LEFT/RIGHT buttons to move a red frame pointer to
IMAGE ADJUST Menu icon.
Press POINT DOWN button to move a red frame pointer to the
item that you want to adjust. and then press SELECT button.
The level of each item is displayed. Adjust each level by
pressing POINT LEFT/RIGHT button(s).
Move a red frame pointer to
the item to be selected and
IMAGE ADJUST MENU
IMAGE LEVEL ADJUSTMENT
Press POINT LEFT button to decrease contrast, and POINT RIGHT
button to increase contrast. (From 0 to 63.)
Press POINT LEFT button to adjust image darker, and POINT
RIGHT button to adjust brighter. (From 0 to 63.)
Contrast
Brightness
Press either POINT LEFT button or POINT RIGHT button to obtain
better balance of contrast. (From 0 to 15.)
Gamma
To store manually preset image, move a red frame pointer to
Store icon and press SELECT button. Image Level Menu will
appear. Move a red frame pointer to the Image 1 to 4 where you
want to set and then press SELECT button.
Image Level Menu
Move a red frame pointer to any
of Image 1 to 4 where you want
button.
Store icon
Press SELECT button at this icon to
store the adjustment.
IMAGE ADJUST
Menu icon
Press POINT LEFT button to lighten red tone and POINT RIGHT
button to deeper tone. (From 0 to 63.)
White balance (Red)
Press POINT LEFT button to lighten green tone and POINT RIGHT
White balance (Green)
Press POINT LEFT button to lighten blue tone and POINT RIGHT
White
Jan 22, 2011 | Sanyo PLC XU35 Multimedia Projector
Curser traveling to top of screen all the time,
Disable the joystick mouse in the center of the keyboard. Doubleclick Mouse in the Control Panel (Start/Settings/Control Panel). On the end tab, disable the thumbstick mouse. For my IBM Thinkpad, it's under UltraNav and I disable TrackPoint.
Aug 31, 2009 | Compaq Evo N610C Notebook
Pointer is stuck at 9:00; difficulty setting accurate on/off time
i've lost the user manual, but i would try the following:
1.) this might sound like an obvious point (maybe not), but you can turn the dial clockwise so that the "current time" arrow is on the current time.
2.) i'm not sure, but it's possible that this device functions best when it DOES NOT share a single outlet.
3.) i don't believe this device functions correctly while plugged into an extension cord.
Dec 29, 2008 | First Alert 24 Hour Timers - 2 For The...
Touchpad not working
Using your keyboard, press the windows hot key, then use the arrow keys to go up and to the right to control panel, then arrow over to the system icon, then arrow through the tabs to the hardware tab, then press TAB to select the "device manager" button and click enter....in the device manager, press tab again in order to highlight the first selection and arrow down to "mouse and other pointing devices" then press the right arrow key to expand that selection and see if it is recognizing your mouse pad, if it does, highlight it and press enter, arrow over to the "driver" tab and try updating the driver, if that doesn't work, try a troubleshoot from the first properties tab.....and if none of this works......the touchpad is most likely dead. Try contacting the manufacturer and see if they can replace the touch pad.....
Jun 27, 2008 | Acer Aspire 5100 Notebook
Intermatic T101 - 24 Hr. Dial Time Switch - NEMA 1 Indoor Steel Case - Gray Logo
254 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Craig Butler
Craig Butler
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
