SKY PLASMA TV AV1 AND 2 NO PIC. (ONLY WORKED ON INPUT 3 VIOEO AND SOUND OK)MODEL NUMBER PDS4250
  • watehou Dec 23, 2008
    cant find tv code off sky remote my tv make is sky
  • 135 Answers
Its the video pcb located in the middle of the set when back is off
Posted on Sep 25, 2009
Need code for sky remote control for samsung model ps51d450 51inch plasma tv
Hello
Sky remote codes for Samsung TV are:
065 584 615 037 245 476 516 292 318 236 398 244 100 118 060 088
646
672
642
Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Aug 30, 2011 | Samsung Televison & Video
The volume on TV goes up but no sound
please check with other input sound come or not.if not then reset your tv from setup menu.
if other input work then please confirm which in put have no sound.
like tuner or av1,2 and pc.
Oct 18, 2010 | Sanyo DP32746 32 in. LCD Television
Plasma green ccreen with no picture but sound working
Check the scart output from the sky box. It could be on s-video or RGB. switch between the two.
Mar 16, 2009 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Sky PDS4250 42'' Plasma TV - Black line down centre of screen
not sure if this is the fix or not ...but i was tryin to fix a problem with my tv(not the same as yours)...but in the menu under adanced you can split the screen ....when i do that it puts a blue line down the middle of the screen
Dec 04, 2008 | Protron PLTV-4250 42 in. LCD Television
Sky plasma tv psd4250 no picture
its the video pcb i have the same problem
Nov 27, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Pds4250 sky 42" plasma
Are you wall mounted this TV or putting it in a tight space with not much room behind the tv?
solutiondoct
Nov 02, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Screnn going blank
sounds like sky tv issue, try different cabling
Jun 02, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
CAN ONLY GET THE SURROUND SOUND TO WORK WITH DVD'S NOT WITH NORMAL TV OR SKY?? WHY??
You should have a AUDIO menu in which you can simulate true surround sound. This should be in your owners manual. Your DVD is recorded in dolby surround sound that's why on your set it will be reproduced as recorded. I hope Samsung is using a ATSC tuner in that model?
Apr 04, 2008 | Samsung HT-Q100 System
Sky remote code for LG 42LC46 tv
After spending hours on this I found that code 0206 worked on my sky+ remote(with LG 42LC46). On an old sky remote, prior to version 4 (inside the battery compartment), just use 206.
This code was actually for a LG 42PX5D but it works perfectly on my tv.
Jan 14, 2008 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
