Question about Lexmark Wheelwriter 2500 Typewriter
IBM Wheelwriter 30, Series II has message KYBD 099
  • Lexmark Master
  • 3,594 Answers
Tour keyboard is going bad. Hold the code down press lang (L) key release the "L" type 001, release the code key this should put you on U.S. keyboard mode. For a better repair you can try my tip under WW1000 or contact Geo Beyers Co. @ 800-392-8085 for a keyboard rebuild. Tell them O'Reilly sent you.
DickyO
Posted on Nov 11, 2010
IBM Wheelwriter 30 Series II Since changing
The ribbon may not be fully seated on the ribbon deck. The blue latch has to hol it in place.
DickyO
Jun 30, 2011 | Lexmark Wheelwriter 30 Series II...
My IBM Wheelwriter 30 Series II has a message of a box and an X in it and then the numbers 215 can someone tell me how can fix this?
Check to be sure the printwheel to be sure it is properly installed, check for debris in the P/W area, If these are OK then the sensor is probably bad.
DickyO
May 28, 2010 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Series II issue...
This is automatic return, it can be turned off with code "R".
You can download a manual at lexmark.com click on publications.
DickyO
Jul 03, 2009 | IBM Wheelwriter 30 Typewriter
IBM WHEELWRITER 30 SERIES II
I believe a 215 code is a bad printwheel sensor. You need a tech.
DickyO
Mar 05, 2009 | IBM Wheelwriter 30 Typewriter
Wheelwriter 3500 KYBD 099
Check the ywo keyboard connectors to be sure they are plugged in fully, if they are then press & hold the code key, press & rel the "L" key type 001 then release the code key.
This will put you into the english keyboard mode. To cure the problem you need a keyboard.
DickyO
Oct 06, 2008 | Lexmark Wheelwriter 3500 Typewriter
IBM Wheelwriter 30 Series II Typewriter 6787
The book says turn the T/W off wait 30 seconds and restart, if condition returns call for service. However you might try removing the batteries and unplugging the machine waiting a few minutes and restarting. CAUTION ALL THE MEMORY WILL BE LOST!
DicktO
Jul 16, 2008 | IBM Wheelwriter 30 Typewriter
WHEN TYPING THE WRONG LETTERS PRINT
Keyboard 99 is Laten supplemental. Try holding down the code key and pressing the x key it should reset the keyboard.
Jan 25, 2008 | IBM Wheelwriter 30 Typewriter
Stuck in a Mode
http://www.scantracker.com/KansasCityrepairs.html
These guys are repairers so they may have extra copies.
IBM's Typewriter's site also has manual for sale for less than $20.
The typewriter seems to have a bad ribbon cartridge or a bad typing wheel. Take each one out and try to see if it will type normal. If one does, then you know to replace it.
Zabrina
Jan 08, 2008 | Office Equipment & Supplies
Problem with striking
Sounds like a keyboard problem. Check the connectors to be sure they are fully pluged in, if this isn't the problem try putting a piece of foil over the rt hand keybourd connector contacts that are bussed together (seven I believe) replug the ketboard and test. BE SURE TO BUSS ONLY THE CONNECTORS THAT ARE BUSSED ON THE CONNECTOR!!
Dec 07, 2007 | IBM Wheelwriter 30 Typewriter
Lexmark Wheelwriter 2500 Typewriter Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
