Philips 42PFL3704D This Tv all comes on but the panel. I have the 24 volts to the inverter and the 3 volts to turn it on. and suggestions? Please Help. Thanks.
  • 4 more comments
  • Jeff
    Jeff Nov 10, 2010
    Yes, thanks
  • Jeff
    Jeff Nov 10, 2010
    No, I even turned off all the lights, nothing. thanks
  • Jeff
    Jeff Nov 10, 2010
    Yes i do have image.
  • Jeff
    Jeff Nov 10, 2010
    Ok thanks for your help. I will accept your solution. I also have a Hitachi model 55HDT52 Plasma tv. All the sudden when I turn it on it will all work for about 1-2 minutes then shut down. Any suggestions? Thanks.
  • Jeff
    Jeff Nov 10, 2010
    Yes
  • Jeff
    Jeff Nov 10, 2010
    Ok Thanks again.
  • 4,889 Answers
By tv all comes on do you mean you have sound?
Posted on Nov 10, 2010
  • 3 more comments
  • eagle338
    eagle338 Nov 10, 2010
    One more question. Last one and this will help us determine the cause of the problem. Do you have a dull glow on the screen?
  • eagle338
    Ok. Try this. Take a flash light and flash it on the screen from a close distance in different angles. See if you can notice a faint image on the screen. Try this and let me know. You may have to try different angles and keeps changing the channels to make it more noticeable.
  • eagle338
    Its a confirmed backlight inverter board failure. Though you have the voltages going into the board there are so many solid state elctronics on it that can go bad. The flashlight confirms that the backlight is not coming on. Replace the backlight inverter board to resolve the problem.
    Sai.
  • eagle338
    Thanks for the accept. As for your query, the shut down is initiated by the protection circuitry due to an overload on one of the boards(usually on the power supply or the sustain boards). The first thing I would look for would be faulty capacitors that are puffed or cracked at the top. Even tiniest of the holes means that cap is malfunctioning.
  • eagle338
    You are most welcome. Thank you for using Fixya!
Philips 42PFL3704D/F7. Why does it keep restarting?
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Oct 9, 2012 - 5 posts - ‎2 authors
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable attached ... or Cable TV to unit the power resets, philips screen comes on and keeps on resetting. ... I tried a cable to the tv without the box and I do get picture.
Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV
www.amazon.com/Philips-42PFL3704D-F7.../B001LP...
Amazon.com, Inc.
Rating: 3.3 - ‎50 reviews
Amazon.com: Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV: Electronics. ... Will do all I can to prevent others from getting ripped off by Philips. ... came up every few weeks and would take an hour or so of reset before working properly.
Visit the support page for your Philips LCD TV 42PFL3704D ...
www.philips.ca > philips > Televisions > 3000 series
PhilipsFind support for your LCD TV 42PFL3704D/F7. ... How do I output sound from myPhilips TV to external audio devices such as Home Theaters, Soundbars, AV ...
42" Philips 42PFL3704D/F7 LCD TV WON'T COME ON - A
Dec 29, 2015 | Televison & Video
I turn on my TV ,there is no sound only picture. for a while I could turn it off then back on and it ould work properly. Now the sound will not come on period
This sounds like a firmware issue, download the latest firmware from:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?tmplt=Funai&scy=US&slg=AEN&sct=LCD_EXTRA_LARGE_GT40_SU&cat=FLAT_TV_CA&session=20090907111310_76.182.116.248&grp=TV_GR&ctn=42PFL3704D/F7&mid=Link_Software&hlt=Link_Software
This should fix your problem.
Jul 10, 2011 | Philips 42PFL3704D LCD TV
We went to turn our TV on and when it turns on the Philips logo usually appears before it turns on. It is frozen on the Philips logo screen. You can't turn it off. And it will not go to the TV. I'v...
The standby power supply resistors on the inverter board have changed values. You will replace resistors R1217, (820K 1/4 watt), R1218,(820K 1/4 watt) and R1219 (390K 1/4 watt). Please use the values just mentioned. Or you may have the inverter board replaced. Take this note to a TV repair Tech.Thanks for asking and show a few hands of support!
Mar 12, 2011 | Philips 42PFL3704D LCD TV
Loud buzzing and no sound in new philips hd42"
Hi:
The buzzing you hear is the inverter board trying to light the backlights, Check the inverter boards for puffy capacitors tops, There should be two of them on each inverter board..
Dec 23, 2010 | Philips 42PFL3704D LCD TV
My tv won't turn on
In this particular model the high voltage for the backlights are produced from the power supply. The power supply is weak and may need repaired or replaced. This is the first reason you have a set that will not come on. Thanks for asking and show a few hands of support.
Nov 15, 2010 | Philips 42PFL3704D LCD TV
When turned on ,nothing comes up,no picture
there is a connection between the inverter and the powersupply. on this connector there should be a line that supplies 24 volts. if you are getting that 24 volts on a volt meter the you are most definatly looking at inveters. if you dont powersupply. just a warning if you have 24 volts and the inverter doesnt work you need a new lcd panel, which is not worth buying if you can find one
May 11, 2010 | Vizio GV47LF Television
QUINMINN
4 possible issues
1 bad inverter (won't step-up low voltage)
2 bad ccfl assembly (florescent lamps are dead)
3 faulty power supply (no 24 volts to the inverter)
4 lcd panel defective (very rare)
Feb 20, 2009 | Vizio L37 Television
LCD tv issue
at error code is 12 and it is your 12-volt supply. Measure from the inverter to the power supply for 24 volts pins 1,2 and 3. If you don't have the 24 volts disconnect the inverters from the power supply and see if the volts come up. If the 24 volts come up replace the inverters. If the 24 volts are still not there replace the power supply. The volts have to be steady and not going up and down if they are replace the power supply.
But if the 24 volts are there with the inverters connected 1M03 pin 3 for 3.2 volts. If the 3.2 volts are not there replace the small signal board. The only way to get a manual is to find it on line or call the manufacture.
Aug 26, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
