Question about Samsung Digimax L830 Digital Camera
Hi, im having trouble with with my camera. when i power on the camera, the lens will not move and stays in the "popped out" position. in addition to this problem, the screen stays black
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Nov 10, 2010
Lens extending and then extracting wont stay on
Here is problem with gear. Something is broken or out of his position. Cameras with moving lenses have often this problem. Enough is little knock and thats it. Mine vas broken, when the child got up from the table, press the on button and and do not let the lens come out. I got to hear the crackly noice and thats all...After that im using cameras like Pentax W 90...
Jul 01, 2014 | Nikon COOLPIX L3 Digital Camera
Camera lens flickering
This type of fault is not a DIY project. You will need to take it to a Sony repair centre. I suggest you get a quote as it may be too expensive to repair and it may be better to put your money towards a new and better camera.
Jan 30, 2012 | Sony Cyber-shot DSC-W55 Digital Camera
Hi, I have cannon powershot 590. My camera is in the lens extended position and are not moving into the camera, There is a message on the LCD screeen "lens Error". Please guide me to solve the...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
May 20, 2011 | Canon PowerShot A590 IS Digital Camera
HAVE olympus 1010 stylus and the lens won't pop out. when I push the power button, it makes a sort of dragging chain sound and then 4 sort of "chimes". Looking at it facing front, the lens...
The internal plastic gears which govern the lens opening and closing are either damaged or out of alignment - this happens when a camera is dropped or has any other form of physical interaction for which it is not designed.
Jun 26, 2017 | Olympus Stylus 1010 Digital Camera
Powers on Lens move in then out,Blank display
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage. thank u rate me!!!
Jul 22, 2009 | Nikon COOLPIX P60 Digital Camera
Lens Error!
Hi onikaassing, A very common problem in all the brands "lens error". The remedy is that you have to replace the lens block assembly. Actueally the sled motor start malfunctioning, Contact nikon service centre maybe they have the component level repair facility which can reduce the repair cost. Thanks for using fixya.
Jun 14, 2009 | Nikon Coolpix S210 Digital Camera
KODAK P850
hi sir
please find whether the memory card is corrupted..
Sep 01, 2008 | Kodak EasyShare P850 Digital Camera
EasyShare camera lens is extended and will not retract, camera will not stay on either
There is not repair you can do The lens mechanism had failed Contact Kodak re your next move - repair or replace
Aug 03, 2007 | Olympus Camedia C-740 Ultra Zoom Digital...
Samsung Digimax L830 Digital Camera Logo
27 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
