Question about Acer AL2216W LCD Monitor
Acer AL2216w has suddenly stopped working
I am running Vista, with a nvidia 8800 card. As of 15 minutes ago both of my displays (an Acer AL2216w and a LG L1710S) were working perfectly, with the Acer is my primary screen and LG as my secondary. I switched from dual display to single display (with Acer as primary still), as I have done many times before without any problem. The visible resolution decreased, even though according to the settings it was at the usual resolution. After restarting the computer, the screen doesn't turn on at all. My LG screen is still working fine, but when I try to either clone screen or dual view nothing at all happens, and the LG remains the primary and only display.
5 Suggested Answers
micromega69
SOURCE: Won't turn off and cylces through colors
Hi. This evening, I had the exactly the same symptom. I found a way to fix it.
When you power up the screen, keep the power and auto buttons both pressed. That seems to reset the screen. After that when you open the menu, a small F appears on the left side of the contrast icon. Go to that red F with the arrows and press menu. Another menu will popup. Choose 'Burnin' and set it to off. That's all !
Note: do not try to change other settings, they depends of the harware...
Posted on Dec 10, 2007
JULIANFIX
  • 975 Answers
SOURCE: AL2216W LCD monitor "Power status Green blinking" & No display.
LOOKS LIKE A BURN SOLDER !! , open the monitor , check the PC BOARD around the transformer area , look for burn spot or cold solder , RE solder it , try again , hope this helps please rate solution and thanks AJ
Posted on May 06, 2008
SOURCE: Native resolution suddenly scrolls.
The native resolution for the Acer AL2216W is 1600X1200. It is acting correctly for the resolution you have set it to.
Posted on Nov 10, 2009
SOURCE: same problem, acer sucks imo
Similar problem with Acer AL2216W - sometimes DVI input don't work properly (but analog in works well in the same time) and I have blackness on panel - I just need to change resolution on my ATI video card for a moment and return to native 1680x1050 (resetting of the monitor?) and things go right. This is my 1st and last time when I bought Acer product. I just opened up and replaced few bulging capacitors (CapXon - known cheap ****) and I will never buy Acer again!!! It's simply ****!
Posted on Nov 13, 2009
My Acer AL2216W Black LCD Monitor all of a sudden is wavy & flickering!?!?!? Is there anything I can do about it?
Hello,i think your LCD monitor is faulty and you should consider replacement.but first take to a qualified service personnel.
Dec 22, 2010 | Acer AL2216W LCD Monitor
My Acer AL2216W suddenly displays a blurred picture. I turned my computer off at night and in the morning after running a virus scan the picture comes in blurry. How do I fix this. I've rebooted several...
Please verify that you are running your PC video card with native resolution of this monitor, 1680x1050 @60Hz for best picture for this monitor.
Unless you may have problem inside the monitor or the video card itself, so try this monitor on another PC also.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 16, 2010 | Acer AL2216WBD LCD Monitor
I have vertical red lines generated by my Nvidia 8800 GTS graphics card
Its a GPU problem.
It can be overcome by doing reflow technique.
You need to do following.
1. Uncover ur PC casing
2. Locate the nVIDIA PCI-E Card.
3. On the card, locate the power supply pin of GPU fan.
4. Remove the pin.
5. Switch on ur PC.
6. Still u may get scrambled display/wavy screen, but wait for 5 minutes.
7. Press reset button on ur PC.
8. Ur PC might work.
9. Switch it off.
10. Connect the power supply pin back as it is.
11. Power on ur PC.
thats all.
Removal of fan power, makes the GPU to get high heat, it a reflow technique.
Remember, not to touch the GPU portion (heat sink), as it may be in higher temperature.
Try this, it works most.
Clarifications:
gnaveendra@gmail.com
Feb 22, 2010 | ASUS NVIDIA GeForce 8800 GTS (512 MB) PCI...
2nd monitor doesnt work either
Ensure your are running the monitors in dual mode still. Open your Nvidia Control Panel and click on "setup up multiple displays" Then on right panel you should see where to select your option on how to run the 2nd one. You might need a driver update from Nvidia, especially if you recently took an update from Microsoft.
Hope this helps
ps Here is the link to Nvidia: Click Me
Sep 26, 2009 | Pine Technology XFX GeForce 7950GT, (512...
Nvidia geforce 8800 gts code 43 due to vista home premium
Well if you installed the correct drivers for your video card and have the proper power supply requirements, then the vertical lines you're getting most likely indicate that your video card is bad.
Try it in another computer if available, or get another video card.
Jun 19, 2009 | PNY XLR8 NVIDIA GeForce 8800 GT 512MB...
Error code 43 "Incompatible display adapter has been disabled"
I have got Dell comp with same n-vidia 8800GT suddenly after installing adobe's update only 1 monitor functions and slowly.
Any reinstaling and updating drivers that i ve tried did not help.
May 07, 2009 | PNY XLR8 NVIDIA GeForce 8800 GT 512MB...
Apr 05, 2009 | Acer AL2216W LCD Monitor
My monitor has no input signal when i plug it on my xfx 8800gt alphadog. i've been using it for almost 5 mos, then all of a sudden, when i start my PC my mmonitor is ok but after 3-5 minutes it says no...
your card is probably overheating. the alphadog editon has an extremly small cooling for the gpu. try cleaning it with a caned air spray and check the NVIDIA control panel to see the temp. of the GPU if the problem is solved try running a game benchmark to see if that works.
Feb 24, 2009 | XFX NVIDIA GeForce 8800 GT 512MB DDR3 PCI...
Blank screen using Vista x64 with Nvidia Forceware Drivers 8600GT
Most like the sound card you have is not compatible with Windows Vista. You need to check the manufacturers website to see if there is any patch for Windows Vista
Oct 02, 2008 | Computers & Internet
GeForce 8800 GT graphics card no display
what motherboard do you have it maybe your motherboard is only up to PCI-E 8 and the card is PCI-E 16 if it is it will not work
Jul 31, 2008 | OCZ GeForce 8800 GTX, (768 MB) Graphic...
Acer AL2216W LCD Monitor Logo
114 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
