Question about Mitsubishi WS-65908 TV
Mitsubishi ws65712 same as the 11 but has a shiny cabinet. went off tried both resets and when i push the power button green light click then it goes off.
  • 5 more comments
  • doug1962 Nov 10, 2010
    it the same tv as a ws65711
    it is the same tv as a ws65711
    x=1 and y=2
    did it again and this time it was 2-2
    no I don't have any experience with this sort of thing but it sounds expensive and probably not worth the cost?
    thanks for your help
    nice job, thanks
  • 4,889 Answers
Ok. I understood the green light click and then it goes off. But what do you mean by "same as 11 by has a shiny cabinet" Please clarify this so that I can help you resolve your issue.
Posted on Nov 10, 2010
  • 5 more comments
  • eagle338
    eagle338 Nov 10, 2010
    Ok. The problem you have described seems like a protection fault. Lets try an error code operational check. Unplg the set from the mains and plug it back. Press and hold the device and menu/input buttons for 5 seconds. It will blink x number of times, followed by a short pause and another y number of times. Count the blinks and get me the no of blinks before and after the pause so that I can tell you what the problem is.
    Sai.
  • eagle338
    Thats weird. Coz 12 means no error. Did you try turning it on. Because when the unit dtects a surge, it goes into protect mode, and will not allow you to turn the set back on until you reset it ie., unplugging and replugging. Give it a shot and let me know
  • eagle338
    Ok. that means short detected in X-ray protection circuit. This is a High voltage circuit. My first question for you is, do you have the experience of working on high voltage circuits? I am talking about 25000V. May not be a good idea to mess with if you have never worked on electronic circuits of this kind. The voltages in the CRT are residual and I am concerned that you might hurt yourself.
  • eagle338
    Well it depends on whether you want to go HD by buying a new set. Otherwise spending a couple hundred dollars on this baby is worth it. Television sets just dont last these days. If its LCDs are ok , plasmas are a lot worse and don't even ask me about DLPs!
  • eagle338
    You are welcome. Thank you for using Fixya!
  • rkgzx9 Feb 03, 2011
    what does 2 blinks then 2 blinks mean?? Thanks
  • eagle338
    eagle338 Feb 03, 2011
    @rkgzx9
    Is it the same model number? These codes vary from model to model
Mitsubishi medallion hd 1080
I would try the reset button in the front. Unplug the set push the reset and plug it back in.
Mar 27, 2014 | Televison & Video
The power went out at my house for about two seconds and when it came back on the TV timer light started blinking and has never stopped. I have pushed the reset button and have also un-plugged the TV and...
Thats a common problem when the power goes out the weak caps can no longer charge and then the led will blink green non stop. www.tvrepairworld.com has the Mitsubishi V26 Chassis DLP DM/Power repair kit should solve that problem. The kit contains the capacitors and the CD with detailed repair instructions.
Oct 07, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Blinking Green Timer Light
I suspect the lamp area is VERY dirty as is the cabinet's filters and fans. This causes great stress on your tv and lamp. Take the time to clean all of them fully. Is the unit in a dirty area? or in a high temp area? DLP's dont like high temp or contaminated areas as they are NOT air sealed units.
Aug 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Won't turn on after reset ws-55511 hdtv
YOU GOTTA REPLCE THE STK ICS OR THE CAPS ON THE DM BOARD
Jul 18, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55909 dm board repair
The DM is fine if the led isnt blinking. Your set is going into protective shutdown. Try pressing the menu and the device/input buttons on the set both in together for 5 seconds to see if the set will blink a series of blinks pause then blink another series of blinks. Such as 2 blinks pause then 2 blinks, Then let me know what the blinks were and I will assist you with whats wrong
May 28, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Light flashing and tv won't turn on
Hi there, I have a Mitsubishi HDTV 1080 and when I tried to turn it on the tv this morning it wouldn't turn on and the power light is flashing green. I pushed in the reset button but it just keeps flashing and still won't turn on.
Oct 05, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi VS-70707 rear projection TV
DOES THE LIGHT BLINK IN A PARTICULAR PATTERN?
Jan 31, 2008 | Mitsubishi WS-55807 TV
Green blinking light on Mitsubishi WS-55813 HDTV
generally this means a bad digital module.. as a techinican the first thing that we would check are what is know as standby voltages. if they were there we would replace digital module.! question. Does it blink for more than 70 seconds. This unit comes with a lockout feature. to unlock press and hold menu down for 10 seconds on front panel.
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
Mitsubishi WS-65908 TV Logo
148 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
