Question about Sharp AL-1540CS All-In-One Laser Printer
What does L 1 mean on my Sharp AL-1540CS Also E 7. Help.
  • 1,110 Answers
The L1 is for a scanner movement failure. The scanner bar that maoves back and forth under the glass is not moving as it should. The E7 is for a scanner lamp reference failure which CAN be caused by the scanner movement failure so I would try and resolve the L1 first. I have a tip posted here at Fixya that resolves the L1 so try that first and it may fix both problems. If not just comment on this and I will try and help you resolve any remaining issues.
Here is the link to the L1 solution:
http://www.fixya.com/support/r4378514-sharp_al_series_copier_l1_l_1_error_code
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Nov 10, 2010
4 Suggested Answers
rajeshmb
  • 38 Answers
SOURCE: F-5 error
Manual says F5 as copy lamp lightning abnormality.
Never had on AR series Sharp machines this trouble,but remember on old Canon NP 6016 when lamp was bad -no dark ends and low intensity of lightning but intensity too high.This machine was equiped with doc feeder and customer performed a lot of copies from glass only and I think he was damaged lamp when close the doc feeder.
the fluorescent type lamp was used on this Canon-Sharp uses Xenon lamp (I think),but they could be very common in construction (tube with electrodes on ends and gass inside)
This fault is very difficult to troubleshoot-try another lamp first,next sensor from good working machine.
Posted on Nov 13, 2008
  • 1739 Answers
SOURCE: is there a free driver download for sharp
I believe if you register your product with Sharp on their USA website you will be provided access to manuals and drivers for your printer.
Go here to register your product.
The files do not seem to be accessible without registering.
Posted on Jan 16, 2011
SOURCE: blinking h then 4
For future H 4 was sokved by calling Sharp at1-630-376-3590
Solution press the C (copy) button and then the Auto button quickly two times, if it does not clear the first time try doing it until the digital screen goes blank, then put in 1 copy find something to print and hit copy button. It should be okay after that.
katkan
Posted on Sep 24, 2009
Error code H 4 Sharp model AL 1540CS
This is a critical issue which needs constant monitoring of the device and continuous chat / email exchange.
Thus it is advised to please avail paid fixya services for better support and quick solution.
Thanks
Oct 24, 2011 | Sharp AL-1540CS All-In-One Laser Printer
We have a SHARP copier that is giving an ''L'' error signal. Pease advise as soon as you canl
L1 mean scanner problem
l4 mean main motor problem
What is your problem,I wiil solve
Jan 07, 2010 | Sharp AL-1540CS All-In-One Laser Printer
What is error code E-7 for Sharp copier AL1540CS
Hi Dave,
E7 means that the lamp under the glass is not working.The most common cause is a blown fuse that sits right beind the lamp.If you can test the fuse and take it from there.
Jun 18, 2009 | Sharp AL-1540CS All-In-One Laser Printer
Blinking h then 4
The error H and 4 blinking indicates that, You have a defective fuser unit.
H is for HEATER
You should replace youe heater unit, if your product falls in warranty period, you can avail wrranty..
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Apr 10, 2009 | Sharp AL-1540CS All-In-One Laser Printer
Code CH on Sharp copier
CH code on a Sharp usually means the front door or a side door is not completely shut. Try opening and closing every exterior door until the code goes away. If the CH is flashing, it could mean either an optical or a heat roller fuse might have blown. Have you recently replaced any supplies?
Feb 27, 2009 | Sharp AL-1540CS All-In-One Laser Printer
F-5 error
Nov 13, 2008 | Sharp AL-1540CS All-In-One Laser Printer
Printer drivers for Mac.
Goggle download program for Sharp AL-1540CS. This should take you to a site that will download the program for you. I recently got a new Vista computer and did this to hook up my old printer on it. It worked fine.
Good Luck
Jun 18, 2008 | Sharp AL-1540CS All-In-One Laser Printer
AL-1540CS error code F5
i have al-1540cs and it if flashing H then 4
Apr 09, 2008 | Sharp AL-1540CS All-In-One Laser Printer
Sharp AL- 1540cs
On my SHARP AL-1540CS printer 4 and H blinks alternately and none of the buttons except power is working.
Oct 19, 2007 | Sharp AL 1215 Black and White Copier
Sharp AL-1540CS All-In-One Laser Printer Logo
279 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
