I HAVE A TIGERSWITCH 6948L2 HOW CAN I CONNECT IT TO MY COMCAST MODEM TO HAVE INTERNET ACCESS FROM ALL PORTS ON THE SWITCH
  • 4,889 Answers
You should connect the WAN cable(that usually goes into the computer from the modem) to the switch. You should then use LAN cables to connect the each LAN port of a switch to the LAN port of a computer. As simple as that.
Posted on Nov 10, 2010
How do i connect a netgear wireless router to comcast modem
Unplug your Comcast modem from your electrical outlet. Connect the Ethernet cord from the back of your Comcast modem into the Ethernet port labeled "Internet" on your new router. Connect an available Ethernet port from the back of the new router to the Ethernet port on the back of your computer.
Plug your cable modem into an electrical outlet. Plug your new router in an electrical outlet.
Reboot your computer. Click on "Start," then "Control panel." Click "Network and sharing." Select "Set up a new home network."
Click on the option for a router or cable modem when prompted by Windows to select your hardware. Your computer will attempt to access your new router. When the brand name for your router is listed, double-click it so your computer can configure itself to the new router.
Create a new name for your home network and create a unique password to prevent unauthorized users on your network. Your computer may reset your Comcast modem and router so your new changes can take effect.
Nov 04, 2010 | Computers & Internet
Xbox and laptop cant connect at the same time
your ethernet cable from comcast gets plugged into the wan port of the linksys switch. plug the xbox and laptop to one of the lan ports. the comcast box is a modem/router? without the router it won't assign dhcp addresses
Aug 19, 2017 | Linksys EtherFast EZXS55W 5x10/100 Mbps...
Connecting internet to the playstation 3
Before connecting the ethernet cable to the back of your Playstaion3 hold the modem reset button for 15 seconds, when 15 secs are up connect the ethernet cable to your ps3 system, wait until tour Comcast High Speed Internet goes online again (all the lights are showing fine) then try setting up your Playstation connection settings again, it might work since now you have reseted your modem and the modem will send information to new device, I hope this information works for you, :)
Apr 13, 2010 | Sony Playstation 3 (PS3) Console
I have a NETGEAR wire/wireless router MBR624GU. My internet provider is Comcast using a high speed internet modem by Ambit model U10C018. I connected the Comcast modem to Router LAN port using a Ethernet...
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 10, 2009 | NetGear MBR624GU Wireless Router
How do I hook up a Berklin wireless router to my comcast internet
Use an Ethernet cable to connect the port on the Comcast modem to the WAN port on the Berklin (Belkin????) router.
Use another Ethernet cable to connect one of the LAN ports on the router to the Ethernet port on your computer.
Start Internet Explorer on your computer.
Connect to the web-interface inside the router.
Run the "network setup wizard".
Run the "wireless setup wizard".
Nov 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
DHG535-2 and LAN switch issue
It sounds like the LInksys that they replaced was also a router. A router will route packets to multiple pc's that are connected to it. The cable modem just sees the router as 1 pc. When you use a switch, the cable modem will see all of your PC's. and Comcast just allows 1 pc. You will need to buy a router to use more than 1 PC which will be cheaper than using Comcasts Home Networking service which will network up to 4 pcs
May 29, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
Problem replacing 4 port hub with 8 port switch for home network.
You can obtain IP details for Preferred DNS server & Alternate DNS server from your internet service provider.
don't use automatic ip addresses.
best regards,
Krishan.
May 08, 2009 | NetGear FS108 Networking Switch
Connecting to internet
Ok, cable (coax) comes in from wall and attaches to modem. Ethernet cable goes from modem to WAN Port of router. You may have to reboot both devices to ensure that your modem (internet service provider) assigns IP address to your router. If PC is close enough, attach new ethernet cable from one of the 4 ports on your router down to your PC's ethernet adapter. (where your modem used to plug into). Router will now assign an IP address to your PC and you should be able to access the www.
Good Luck and let me know if you have any more questions.
Jul 13, 2008 | Linksys Wireless-G Broadband Router
WAN
The wan port is what you hook your modem to. Wan stands for Wide Area Network, which in your case is the internet. Your house with your 2 pc's and networking equipment would be considered a Lan, local area network.
The 4 ports on the router are switch ports, when you hook the modem up to the switch instead of the wan port the modem will only allow traffic from one physical, (MAC) address to pass through, this is why only one of your pc's can access the internet. The wan port on the router has its own MAC address, so the modem will associate with the wan port and trust all traffic that comes from that port.
Finally, after you have connected the modem to the wan port, pull the power cord on the modem then plug it back in to reset it, this will force the modem to orient with the wan port.
Jun 01, 2008 | Computers & Internet
Adding a PC to the network
Make sure your network card on the computer is enabled and properly installed. Also try replacing the cable with one that is known to be good. I hope this helps. Good luck.
Nov 05, 2007 | SMC TigerSwitch 6508TT
Computers & Internet Logo
David Payne
David Payne
