Question about Bogen Communication ESYS1 ENHANCER SYSTEM COMPLETE VOICE ENHANCEMENT PKG [esys1]
I have a Bogen Enhancer system and have really enjoyed using it. But occasionally I get quite a bit of static (interference?) when I am teaching. Any suggestions?
I am struggling with similar issues. Adjusting the level down on your audio amplifier may help; this may raise another issue in that teacher's voice could seem too quite. Another concern with static may be the placement of the IR sensors. Haven't had much luck finding published guidance from Bogen. Nice system - just not working as well as hoped for.
Posted on Nov 15, 2010
How to replace my hard drive with a static drive
first check which type of connection your harddisc drive uses to interfere with motherboard.
then u need ide to sata convertor to connect static drive.
if it uses SATA then its easy.just connect your static drive .And enjoy.
Jun 29, 2014 | Washing Machines
Internal interference
ok you can used the matching transformer to avoid the interference. or you can buy a 'interference free'at the electronics stores!
Oct 06, 2007 | Toshiba 51H84 51" Rear Projection...
Weak audio static uc2-ub handheld
Sounds like either local interference or it needs to go to Shure for repair. Can you try it in another location maybe 10 miles or further away from the present location. If it operates in the MHz band you need to replace it, it is illegel to use that band in the US..
Mar 13, 2012 | Shure Beta 87A Professional Microphone
Refrigerator causes am radio static and tv static interference . what is the problem, and it dangerous?
What you probably hear and see is the AC hum of the electric motor of your refrigerator broadcasting at 60hrtz, and 120hrtz. Normally the ground leads of your electrical system is sufficient to absorbs this rf interference. I suspect that your electrical system is an older system in which the third ground lead was not run in order to tie all of the grounding of the electrical system to each other so as to absorb all of the noise put out by ac induction motors. This was common in the 1950s, and many systems have been upgraded to provide for that third ground lead. It is not dangerous, but a trifiling bit annoying.
Feb 14, 2011 | Refrigerators
Really bad crackling on line cant hear any conversations phone rings ok and dials ok but cant hear anything but crackling
Without the make and model of the phone unit, I would guess you are suffering from interference if you're using a cordless phone system.
If you are, move the base unit to a room that doesn't have appliances, wifi, or computers and check to see if that removes the static.
Jan 12, 2011 | Lands Phones
Fluid head platform is moving before the fluid
Below the head where it attached to the center column is a set of three screws. Back them out a little bit and then tighten the head, then screw those three grub screws back in to lock the head.
Apr 04, 2010 | Bogen Communication Bogen Manfrotto 3046...
Psp screen stays black
i think your graphic card or motherboard has been broken, try to get a replacement
Jan 26, 2009 | Sony PlayStation Portable (PSP) Console
Can't get the bose cinemate to work all hooked up fine get static coming through them upon connection but then nothing????
Never buy a wireless speaker system! Too susceptible to interference, and the RF transmitter/receivers will drift off frequency in a short time, leaving you with perfectly good but useless speakers. If it's a used system, there's not much you can do. If new, of course you can take it back and get a REFUND - don't exchange them for another wireless system. Run wires, live with the mess and enjoy proper performance for years.
Dec 13, 2008 | Bose Cinemate Digital Home Theater System...
Radio static only but meta data displays
There will be static. A lot of my passengers are surprised that there is static on satellite radio, but there is. Your Sirius satellite receiver "broadcasts" to your car's FM radio through a frequency you select. For example, the Sirius channel on my car radio is 89.1, which is pretty clear and works pretty well on my regular commute. But if I drive beyond that route, where 89.1 is routinely used by regular broadcast radio stations, there is a lot of interference and static. I then have to switch frequencies on both the receiver and car radio, to find another clear channel. Quite a pain. There will be interference. Even the smallest bridge, tunnel, or parking garage often seems to block satellite reception, and occasionally the signal will completely disappear for no reason.
I DID TONS OF RESEARCH FOR YOU ABOUT THESE RADIOS. THE SAME PROBLEM YOU HAVE ARE FOUND BY 100'S OF OTHERS. IT'S THE COMPANY THEMSELVES HAVING DIFFICULTIES.
Sep 14, 2008 | Alpine CDA-9856 CD Player
Bogen Communication ESYS1 ENHANCER SYSTEM COMPLETE VOICE ENHANCEMENT PKG [esys1] Logo
134 people viewed this question
Top Bogen Communication Computers & Internet Experts
David Payne
David Payne
Are you a Bogen Communication Computer and Internet Expert? Answer questions, earn points and help others
