Question about Dometic Rooftop RV Air Conditioner
Compressor makes a humming noise
I turn the unit on and when the compressor tries to come on it makes a humming noise then cycles off and problem repeats itself? starting capacitor or compressor?
I concur that this website is absolutely worthless!!!!!!!!!!!!!!!!!!!!!!!1
Posted on Jul 25, 2008
  • 828 Answers
If you have an Amp meter available to you, you can check the electrical draw of the compressor. Compressor may have a tag that gives a rating for LRA which is locked rotor amperage. If the draw is within 2/3 of LRA check the compressor relay and or capacitor. If your reading is equal or near LRA the compressor is done. The hum you hear is power to the compressor. When it is cycling off it is the overload protector opening cutting off the power due to an electrical overdraw. Hope this helps.
Posted on Jul 24, 2008
  • Chalabi Feb 02, 2013
    thanks
This web site is useless
    Novelist:
    Champion:
  • 230 Answers
Good guess! Without hearing it myself it is hard to say for sure. Be aware that there are many things that can cause the capacitor and compressor to fail. So the problem may be bigger then just the symptoms that you see/hear. Please call a licensed technician to take a look.
Posted on Jun 17, 2008
APE08AJM1 - GE 115 Volt Portable Electronic Room Air Conditioner - Compressor not kicking on. Manual indicates it's triggering the overload relay? How do I solve this?
There is a start capacitor near the compressor that may be bad. If the capacitor tests OK then the compressor is locked up. A service man can try to get it going with a kicker capacitor but there is no guarantee that that will work.
Sep 14, 2017 | GE Heating & Cooling
Sub zero. 650 reefer. Significant hum coming from top mounted compressor, but still marginal cooling. Now a louder hum and unit no longer cooling.
Hi roger,
I see you concern, and if the unit does not cool anymore and there is a humming noise then you will need to replace or have your compressor repaired no doubt.
Have a nice day,
mvincentc
Jul 03, 2011 | Kitchen Ranges
My Santa Fe compact dehumidifier in my crawlspace makes a noise (not a smooth humming sound but more of a harsh vibrating sound) when it is not dehumidifying. I can turn the knob to the dryest setting and...
The black cylinder is the compressor. It sounds like your unit is cycling the compressor for some reason. If the compressor starts, runs fine, and removes water when you set the humidity control to the driest setting the compressor is probably OK and the problem may be with the humidity control causing the dehumidifier to "short cycle" for some reason. You may need to change the humidity control or relocate the dehumidifier in your crawl space.
If the compressor attempts to start, and then sits quiet for 10 minutes, and then attempts to start again, you have a problem with the dehumidifier. There are a few things that can cause this problem:
Low refrigerant charge
Bad compressor capacitor
Bad compressor overload
Plugged capillary tube or broken expansion valve
are the common causes of this behavior. If you suspect one of these problems, call the factory service department at 1-800-533-7533 for help.
Good luck with your dehumidiifer.
Jan 11, 2011 | Santa Fe Advance Pre-Filter Dehumidifier
Carrier Compressor Issues?
When you shut it off and back on it slugged the compressor if you turn it off and back on before the pressures equalize between the high and low sides it will slug the compressor and it will not run should let sit for five minutes or so before restarting. The humming is either the compressor making noise usually common for the compressor to make some noise or the fan motor bearings are getting bad on the outside unit. If the unit works normal probably not much you can do till it breaks if it is the compressor it is more economical to replace the whole unit if it is just the fan motor it is worth changing. You could take an amp draw on the fan motor and the compressor to see if the are within the limits on the name plate of the outside unit.
Jan 25, 2010 | Heating & Cooling
My coleman mah 3 roof top will not blowon fan side
Sounds like you have either a bad fan motor or a bad fan motor capacitor. When you turn the unit on with the fan not working, the compressor (the humming noise) runs and gets real hot real quick resulting in the compressor cutting off ( the nothing after) on it's inside high temp switch. This is what the compressor is designed to do so that when this happens, it does not burn the compressor out. Replace you fan capacitor, give the compressor an hour to cool, then try it. In most cases and if I'm correct, the unit will run just like you want it to. Good luck.
Please rate solution
Sep 09, 2009 | Coleman Mach III Air Conditioner
Makes a clicking noise and humming when starts up
If your unit is fixed with a high speed compressor and in case you are not using a votage stablizer when ever there is a fluctuation in voltage there could be a click noise from the compressor. Do not frequently open your fridge and slowly the noise will vanish. It tells you that the unit is functioning just like our heart making thud thum thud noise when it functions and nothing to be worried about. It is normal.
Jul 06, 2009 | Refrigerators
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
Friedrich QuietMaster SS12H10
It is probably either the Compressor and or the capacitor that has failed. The compressor will hum and pull a lot of amps when it has seized up. Sounds like it is time for a new unit.
Jun 30, 2008 | Friedrich QuietMaster Deluxe RS12L10 Air...
Refrig compressor "knocks" when cycling off
could be a broken spring inside the compressor and would only make a noise as the compressor stops. nothing you can do about it. you would need to break open the compressor, replace the spring, weld it back, then charge it up again with refrigerant.
Feb 11, 2008 | Refrigerators
Dometic Rooftop RV Air Conditioner Logo
479 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
