Question about Sport & Outdoor - Others
I have a tasco bore sight #30/35. I have misplaced the instruction sheet. How would I be able to secure a new sheet?
5 Suggested Answers
SOURCE: Thomas Sight and Sounds Layout Instructions
http://www.thomastrackmaster.com/thomas-trackmaster-instructions.html
Posted on Feb 15, 2009
agent91
  • 2100 Answers
SOURCE: I need the instruction sheet for a Tasco Scope
Go to my profile and look at my scope tips. agent91
Posted on Mar 09, 2010
SOURCE: I need a scope guide instruction sheet for the Tasco 28a
1. Insert the Bore Stud into the Stanchion while aligning the arrows as shows. Insert the assembled scope guide into the muzzle of your rifle with the grid pattern upright.
2. Select the Aperture Cap that fits your objective rim. Place it over the objective end of your rifle scope and press until it fits flatly against the rim.
3. Using the Adjustable Scale measure the top of your rifle scope tube to the center of the rifle bore as follows: Open the rifle breach. Rest the upper arm of the scale on the scope tube before or behind the windage and elevation turrets. The scale markings should be facing towards you reading vertically and ascending from bottom to top. Slide the lower end of the scale up or down until it is touching the center point of the bore. On center fire rifles the center point will be the firing pin. On rimfire models the center will be the shell extractor. Read the number that corresponds to the indicator marked "CF". Make a note of the reading.
4. Aim the rifle toward a light, flatly lit area such as a wall or open sky. Caution: Do Not Look At The Sun As Permanent Eye Injury Could Result.
5. While keeping the riflescope at the right distance to see the full field of view, sight through it on the grid pattern. Move the stanchion right or left until the bold centerline is parallel to the vertical reticule wire. Turn the windage dial right or left until the vertical reticule is aligned with the grid centerline.
6. Use the reading from the scale to align the horizontal reticule wire. Find the numbered horizontal grid line that corresponds to the number on the scale. Turn the elevation dial right or left until the horizontal reticule wire aligns with this corresponding grid line.
7. To make your final zeroing adjustments remove the scope guide from the bore of your rifle.
WARNING: FIREING YOUR RIFLE WITHOUT REMOVING THE SCOPE GUIDE MAY CAUSE DAMAGE TO YOUR RIFLE AND OR CAUSE YOU INJURY
At a range or other safe area test fire a group of three rounds of the same type ammunition at a target at least 50 yards away. Refine your scope alignment by adjusting the windage and elevation dials. Move to your desired distance from the target and test fire another group and make your final windage and elevation adjustments.
8. Restore the stud tension by pressing the end of the spring.
Posted on Nov 05, 2010
  • 102366 Answers
SOURCE: need new battery tasco
http://www.tasco.com/products/manuals/TascoRedDot_v2.pdf
Posted on Dec 20, 2010
How open golden antler scope?
Instruction Manuals ' Tasco® - Believe it.
www.tasco.com/pages/instruction-manuals/
Golf Scopes; Infocus - 514FMY ... QP22 Electronic Open Reflex Sight · ProPoint Red Dot Scopes · Tasco Generic Riflescopes (6 Languages) · Vital Zone Reticle ...
bout 236,000 results (0.65 seconds) Search ResultsTasco Golden Antler 3 - (9 x 40 mm) Repair Questions ...www.fixya.com/.../p4821-tasco_golden_antler_3_9_x_40_mm_3_9x40Recent Tasco Golden Antler 3 - (9 x 40 mm) (3-9x40 mm) questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Spotting Scopes.Tasco Scope Problem [Archive] - Cast Boolitscastboolits.gunloads.com > ... > Cast BoolitsAug 1, 2009 - 12 posts - ‎10 authorsErgo, if you have a Tasco or Redfield optic that needs repair, use your ... Have a couple of "golden antler" Tasco scopes a rep gave me back in ...Tasco Golden Antler Riflescope - YouTube
Jan 24, 2016 | Tasco Golden Antler 3 - (9 x 40 mm)...
My cross hairs do not move when i adjust my sights. i bought a laser bore sighter and the laser points in the same exact spot no matter how far i turn my adjustments nor do my cross hairs move.
This happens a lot during bore sighting, - no shock to the scope to jar the cross hairs. So take your screwdriver and use the handle - rap the scope or better just tap it. Not hard enough to bend/dent it but jar it so things can move if need to.
Jan 04, 2011 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
At an estate sale i bought a tasco accudot-30mm 7 dente rheostat--this sight was still in the orignal box unused -the marking on the box acdist 1993 tasco sales-box contains ring mounts the main body and...
Does it look kinda like this? narseman_0.jpg This is a 1x 30mm Used for hand guns and shot guns. No zoom to speak of, just rapid target sighting..
You seem to have an older model.. Still worth over $50..
try www.tasco.com
Dec 22, 2010 | Sport & Outdoor - Others
We cannot get the scope to zero in
you may have a faulty scope,,so,,,clamp your rifle into a jig so it cant move about first,,,then bore sight it,,,without moving it test fire it and set the scope up to were the shot hit, ,fire it again the shot should hit the same spot or very close to it, if it keeps moving about mark were the cross is pointing jam the gun down and fire it off a fuw times if its still jumping around its your scope,,go buy a new one? but you must jam the gun so it cant move about,,,,
Nov 27, 2010 | Tasco WC 416X40 MBLK TADWC416X40
How to reset to zero a Tasco RF3- 7X20 Scope? I am having prblems centering this scope Thank You
Making sure it is correctly fitted to the rifle, you Bore sight it. Best to put it into a vice using a thick piece of blanket to protect the rifle. Looking through the bore you line it up on an object about 10 to 20 meters away. Then you adjust the scope to fix the crosshairs on that same object. This will get you approximately on target. Depending on what a where you are going to shoot, assuming you are using a rimfire rifle, You then set up a target about 30 to 35 meters away. And adjust your scope to center on this target. That will give you dead aim at 30 meters and again at 90 meters, with only a slight variation in height in the middle.
Feb 04, 2010 | Tasco RF37X20D 3-7x20 Rimfire Riflescope -...
How do you sight it true for the rifles prior to using the windage and elevation turrets. All other scopes I,ve seen with range compensators have the ability to be sighted in. I can't figure out how to...
You can get a base line by bore sighting the scope. Bore sight kits are a bit pricy, might be best to take it to a gun range an start at 15 yards shoot a few move out to 25 the 50 then 100. Yes your scope should be sighted for one gun one round, with a cold barrel. Let it cool between shots.
Oct 14, 2009 | Tasco 3-9x32 .22 Riflescope W/ Rings,...
Dec 14, 2008 | Tasco Scope Guide Quickly Zeroing Rifle...
Sport & Outdoor - Others Logo
54 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
