Brother MFC-9449CN(CC3-205-03031f04) error message. Scanner is unable to connect to PC (it worked fine a few months ago. I have tryed re installing software and Brother helpline cant help! In control panel it says that the scanner is busy. Any ideas? Thanks Nick
  • 1 more comment
  • florenda Mar 03, 2009
    I have the same problem with my printer. I have reinstalled the printer twice after installing it. But no changes. I still cant use the scanner. The only thing I can do with the printer is to print by PC but cant scan.
  • Anonymous Mar 25, 2009
    can print from pc but cant scan
  • bthomas66 May 11, 2009
    I have a brother mfc-4400cn.. I have the same problem. The connectivity to the printer is fine. I can print over the network, but I can't scan a document. Whenever I go to my printer and select the SCAN button, it just errors and says check connection. My connection is good, i've changed my ip on the printer and can still print over the network just fine. My fax is also working. AAHHHH!!!
The solution to your problem is in your network. A 205 error is network related with a confusion in where the IP address is. Make sure that you have the right IP address for your brother printer. ALSO VERY IMPORTANT... make sure that YOU DO NOT HAVE a wired AND wireless connecion. This will cause confusion between the printer and PC. It will not know where to send the file. Lastly if you are printing with a gateway connected to a router this could also cause problems. ie comcast gateway connected to router. I currently have a comcast gateway connected to router with no problems. But i also have my gateway in DMZ plus mode(complete unrestricted access for router)
Hope this helps.
to the person who says don't buy brother, I happen to like brother printers. They have been the most stable out of all that we have owned at our office. If you have a cell phone and can not figure it out you get help. the answer can't be don't buy a cell phone.
Posted on Sep 13, 2012
  • SAS KA
    SAS KA Jul 03, 2014
    when i unplugged the hard and kept just the wireless it worked like magic, thanks
  • Arief Rahman Hakim
    Arief Rahman Hakim Jun 17, 2016
    I just change my desktop IP address from automatic to static/fixed IP address. Now it's working. Thanks for the "cause confusion" keywords.
Thank you!
It is indeed well affect events / Action images, OCR ...
Thank you.
Posted on Mar 15, 2009
If you're using Win7 or Vista, you're problem is very likely related to the Windows Firewall. Go to control panel -> windows firewall. Choose advanced settings. Check Inbound Rules for a rule called BrotherNetwork Scanner. The specific local port that needs to be open is UDP 54925. Under Advanced, check to make sure the profile you're running with is selected. In my case, the brother software had created the rule in the 'Public' profile, which didn't apply because I was using the 'Private' profile. Once I switched, everything worked great.
Posted on Feb 09, 2013
    Problem Solver:
I like the Don't buy Brother idea, but check if it's a wired and wireless computer. The software doesn't like wireless....
Disable the wireless, reboot, reboot the Brother (hopefully you don't have to uninstall/reinstall), and test over hardwire.
Thats fixed it multiple times for me!
Posted on Oct 03, 2008
This is due to a stupid stupid setting within the Brother ControlCentre3 software that has its own setting for Email client and doesn't depend on the default setting in Windows. I experienced it after installing Thunderbird over Windows Mail . . . oh, how to fix it, you'll be wanting to know . . go to the Brother website www.brother-europe.com, create an account, then go to
https://www.brother-europe.com/icss_b2b_b/Z_InitLoginTransit.do?country=GB&language=EN
Posted on Aug 26, 2009
The above solution anly helps sometimes. I have the exact same problem and my solution is not to buy brother??
Posted on Sep 08, 2008
Go to MY COMPUTER then to PRINTERS & FAXES and then under Other Places to SCANNERS & FAXES.
you will see the brother and right click on properties. check in the Network tab the IP address, it's probably wrong, it should be the same as the port in the properties for the printer configuration
Posted on Jul 19, 2008
  • Darren
    Darren Aug 22, 2014
    Great answer. This worked on Windows 7. Search for Scanners and Cameras. Thanks.
  • Darren
    Darren Aug 22, 2014
    This worked in winows 7 it is Scanners & Cameras
How to fix Brother printer J415W with error message "Unable to Print 4F
defective scanner you must change scanner or replace motor inside in scanner.
Jul 30, 2016 | Brother MFC-J415W Multifunction Inkjet...
I have a Brother MFC-6490CW multifunction printer,fax, scanner, copier machine that prints fine from my pc, however I am unable to scan either at the scanner or through the pc. I get an error message...
Here is a post from the FixYa site from 2 years ago explaining your problem. It seems to be a problem with the IP address.
http://www.fixya.com/support/t678281-brother_mfc_9449cn_cc3_205_03031f04
Mar 14, 2011 | Computers & Internet
My scanner/faxer won't scan for my mfc-490cw brother product. I always have to reset it and push 20 buttons so I don't remember how to do it. Can you help?
I have the same problem. It was working fine, then after not using it for a few weeks, all the sudden I couldn't scan. I'm hooked up wirelessly through my router. I can initiate a scan both from my PC and from the scanner itself, when initated from the scanner my PC responds and shows the progress bar, and the scanner actually scans. However for some reason no data is being sent back to the PC. And after a few minutes I get an error message saying that communication was lost (or something like that) error TW007. Yesterday I called into brother support and was on the phone for an hour and a half. they walked me through verifying connectivity, uninstalling and reinstalling the software and drivers, but to no avail. In the end we made no progress. I can print without a problem, and fax and photocopy. But for some reason it seems that the scanner is not transmitting the information back to the computer, even through the connection was established and the computer is waiting for the data.
Nov 29, 2009 | Brother MFC 490cw Color Inkjet...
I have a brother MFC 9440CN when I try to scan a document the error message comes up as not being connected to pc. The cable is definitly connected as the print option works fine. Can you help. Thank you.
Are you scanning from the PC, or are you scanning from the printer?
If the latter, the scanner is trying to send the document to a server software on the PC, which is probably not running; hence the "not connected" message.
Try acquiring a picture using Control Panel -> Scanners -> Acquire Image and see if it works. If it does, you must run (or reinstall) the Control Center software, and configure it as to where to store the Scan-to-File documents.
Nov 02, 2009 | Brother MFC-9440CN Laser Printer
Brother MFC8460N was working great and now today the scanner won't work. Printer and fax work fine. When I try to scan I get the message "MFC-8460N cannot be found. Please make sure your device is ON and...
Try re-installing the scanner software - if you don't have the disc you can download it. The scanner is a very delicate mechanism so is easily damaged - if the software fix don't work maybe it is kaput
Oct 03, 2017 | Brother MFC-8460N All-In-One Printer
MFC 210c Unable to Print Use Troubleshouting and routine maintenance chapter in Users Manual
My color has not worked well in the past few months. Now I get the message Unable to Print, Use Troubleshooting and rountine maintenance chapter in user's manual. I've tried everything it told me. I've removed all ink cartridges and left them upright (they are ALL brand new) and cleaned all the ink ports. I've cleaned the machine several times. It's told me there's no ink cartrige, I've replaced them, turned the machine off and on, unlplugged, etc. Then go to print and I get the same message again and it won't print. The machine is almost 2 years old and has worked fine until about 6 months ago when the magenta stopped working all together. Now this. Any help? Thanks.
Nov 05, 2008 | Brother MFC 210C All-In-One InkJet Printer
Wont work
The issue you have posted does require little more information in order to isolate the issue to fix it. Information like have you installed the printer driver and connected the printer cable to the system in your system for the printer to communicate, are you getting any error messages when you are trying to scan or print, weather you have used the printer earlier and it was working fine till the recent past or it was just being used for sending faxes only and printing and scanning was not tried earlier, However let me provide you few steps that you cold try to fix the issue.
  1. Click on start point Control Panel and click on it.
  2. In the control panel window click on the icon labeled “System”
  3. Click on the Hardware option at the top and then click on Device manager.
  4. On the device manage page check if you have any devices under “Other Devices option with a YELLOW ! mark, if so right click on the device and left click on uninstall.
  5. Close all the windows and then insert the Driver disk for the Printer in the CD/DVD Disk Drive to install the drivers for the printer.
Note: At this point of Disconnect the printer cable if it is connected to the system tower, and do not connect the cable until the installation wizard prompts you to do so.
If you do not have the Printer driver disk handy then you can download and install the printer driver form the link below:
Brother MFC-3340CN Printer & Scanner Driver USB (Free Download)
http://www.driversdown.com/drivers/10429.shtml
Brother MFC 3240C Printer & Scanner Driver USB (Free Download)
http://printers.free-driver-download.com/Brother/25079/Brother-MFC-3240C-Printer-&-Scanner-Driver-USB-v.A-Windows-98-ME.html
  1. During the installation the wizard will prompt you to connect the printer USB cable to the system tower, so go ahead and connect it.
  2. Once the installation is finished restart the computer.
Should you require any further assistance regarding the
printer or even require assistance regarding any other
computer related issue in future please feel free to
contact me I will be more than glad to assist you.
Regards
Malik Khan
Jan 30, 2008 | Office Equipment & Supplies
Error Message: Scan Unable A6
the scanner or main circuit board is defective. Give it back to dealer due to warranty.
Jan 12, 2008 | Brother Multi-Function Center MFC-240C...
Unable to init.
Error message Unable to Change Unable to Clean Unable to Init Unable to Print Unable to Scan Cause The MFC has a mechanical problem. ?OR? A foreign obstacle, such as a clip or ripped paper, is in the MFC. Solution Open the scanner cover and remove any foreign obstacles from inside the MFC. If the error message continues, please follow the steps below before disconnecting the MFC so you will not lose any important messages. Then, disconnect the MFC from the power source for several minutes (which will erase all faxes), and then reconnect it. Check whether the MFC has faxes in the memory 1. Press Menu/Set, 9, 0, 1. 2. If the MFC has no faxes, disconnect the MFC from the power source for several minutes and then reconnect it. ?OR? If faxes are present, you can transfer them to another fax machine. Go to Step 3. ?OR? You can forward the faxes to your PC. Please see Transfer faxes to your PC. Transfer faxes to another fax machine If you have not set up your Station ID, you cannot enter fax transfer mode. 3. Enter the fax number to which faxes will be forwarded. 4. Press Black Start. 5. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. You can transfer the Fax Journal report to another fax machine by pressing Menu/Set, 9, 0, 2 in Step 1 Transfer faxes to your PC You can move the faxes from your MFC?s memory to your PC. 1. Press Menu/Set, 2, 5, 1. 2. Using ▲ or ▼, select PC Fax Receive, and then press Menu/Set. The LCD will ask if you want to transfer a fax to your PC. 3. To transfer all faxes to your PC, press 1. ?OR? To keep all faxes in the MFC?s memory, press 2. 4. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. (For details see Using Brother PC-FAX software on page 5-1 in Software User?s Guide on the CD-ROM.)
Sep 06, 2007 | Brother MFC-5840CN All-In-One InkJet...
37,653 people viewed this question
jasbo
jasbo
