Question about Frigidaire ATF6000ES Front Load Washer
The impeller became disengaged from the pump motor shaft on my frigidaire affinity front loading tumble washer. (model ATF6000ESO) It was made in 02/2006. Do I need to replace the entire motor/pump assembly or can the impeller somehow be re-affixed to the shaft? I see nothing obvious that would secure it. Just a little black half washer looking piece that appears to be a damper of some sort.
  • 1,531 Answers
No the impellar can not be reattached i will not hold and will come off again.I have tried to repair them before and they just do not hold. so you do have to replace the whole pump.
Posted on Nov 10, 2010
When washer turns on there is a horrible buzzing sound, e 20 error message was on before
This is a blocked drain error code (E20) which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums, buzzes or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Aug 25, 2011 | Frigidaire Affinity ATF7000E Front Load...
What does error E20 mean?
Error Code E 20 is a drain problem in the water pump. Your lines or water pump impeller may be blocked with animal hair, cloth fragments or foriegn materials.) The Impeller is an internal "Fan" that forces water thru the water pump)
Check this FixYa site for the many possible solutions
Aug 17, 2009 | Frigidaire Affinity ATF6000F Front Load...
Code e20
Check filter for blockages and waste hose outlet.check pump impeller in case something is jammed in it.you will need to remove it.if impeller moves freely it may need a new drain pump.
Hope this helps.
Aug 03, 2009 | Frigidaire Affinity ATF7000E Front Load...
How to diagnose
Sounds like your motor is blown. That's going to require a repairman.
Mar 31, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire Affinity washer
Suggestion:
Plug off the mains. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. There is a drain hose here, disconnect & drain out. There could be a lot of water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
For some front loader models after removing the panel, the filter is in the compartment having the white screw able lid. The big hose from the bottom of your tub leads to this compartment.
Mar 21, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity front load washer will not spin
sounds like the impeller on the drain pump is blocked. Noise could be coins trapped in drum. Check filter thoroughly, if you cannot remove blockage you may have to remove tubes from pump to clear out any blockage.
Dec 20, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Roper by whirlpool model # RAX4233PQ0
i assume that's a top load and not a front load as pictured..ck wiring connections to motor try turning coupler between motor and gearcase by hand if locked remove pump(2 clamps from motor) try again if turns free clean pump if not gearcase ..if turns free with pump attached and wires look ok suspect timer
Jun 20, 2008 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Frigidaire ATF6000ES Front Load Washer Logo
70 people viewed this question
Top Frigidaire Washing Machines Experts
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
jimorris77
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
