Question about GE (GTS16BBS) Top Freezer Refrigerator
I have a GE top freezer refrigerator. How do you remove covers to get at fan(s) in the freezer? There are two, on towards middle back and the other is middle bottom
  • GE Master
  • 8,220 Answers
I have a Kenmore Elite side by side refrigerator, the problem is the unit is not cooling at the top area of both the freezer and refrierator? the bottom areas are OK, I notice there is no air flow in the...
Is your fan inside the freezer compartment back wall towards the bottom is working. (Evaporator fan motor) ?
No fan... No circulation.
Fan may have failed or another common thing is failed defrost system has clogged up the evaporator coil and fan blade with frost. In this latter case, you will see white frost build up in the freezer back wall towards the bottom in freezer compartment.
Better call a local service technician. Little bit technical and hands on job.
Oct 23, 2017 | Kenmore Refrigerators
Freezer blower fan noise. Sounds like something vibrating but suspect the bearings in the fan motor. How to replace?
Hi, read about your request. All racks have to be removed Remove Icemaker. Remove auger assy. Remove covers top and bottom. Until you see motor. Remove screws and tip toward you until you can remove motor. Part number for motor is wr60x10185 $46.89. Hope this helps.
Jan 22, 2011 | GE GSS25LGP Side by Side Refrigerator
Ge zisw48dyb hot to touch on middle bar front between doors
Pull the refrig out and remove the lower panel . Check that the fan motor is working and no object is blocking the blade to keep it from turning . If your compressor is a top model , remove the top cover and check the fan motor and coils for dust coverage .
May 01, 2010 | GE Monogram Side by Side Refrigerator
I have a ge externa refrigerator that does not cool on top shelves of the fridge or the freezer. it cools at the bottom just not the top. model # is ESS25KSTSS. Fan is workin fine and has freon. If anyone...
If the fan is working fine the next thing to check for is heavy frost on the back wall of the freezer section toward the middle to bottom area. If you have frost there you will need to remove the panel and with ref. off use a hair dryer to defrost the ice from the coils. After the ice is defrosted you will see a defrost heater at the bottom of the evaporator coils. This will be your problem Part number 51x10101 at about 64.00 or less. Hope this helps and good luck. Rick
Mar 09, 2010 | GE (ESS25KSTSS) Side by Side Refrigerator
GE top freezer refrigerator fan rattles constantly
It is mounted properly, it is probably a bad bearing in the fan motor and/or the blade is loose on the shaft. Replace the motor.
Good Luck,
Gil
Feb 28, 2010 | GE PTS25SHS Stainless Steel Top Freezer...
I am having a problem with water in the bottom of my 11 year old whirlpool refrigerator, under crisper drawers. I understand this could be a blocked defrost drainage line. How do I access the drain line?...
There should be four screws. Two in front on each side.
The two in the back or at the fan cover. in center. take teem out. slide the fan cover up and out. now you can take out the bottom. The drain is in the middle at the back. HOPES THIS HELPS
Ken
Sep 23, 2009 | GE (GTS16BBS) Top Freezer Refrigerator
GE Top Freezer Fridge - Freezer Buzzing
If you remove the half moon cap, and two 1/4" screws you can remove the cover and get to the fan. The fan motor shaft is mostly wobbling around making the buzzing sound.
Jun 28, 2009 | GE GTS22WCP Top Freezer Refrigerator
Whisling noise coming out of inside the refrigerator. Louder when freezer door is open. maybe ice maker area?
The whistling is caused by the air circulating fan located just behind the light. It is easily accessed by removing the light cover and the two small hex screws above the light. To stop the whistling I simply turned the freezer off and pulled the fan cover out slightly to reveal the fan blades. I then pushed the blades down, toward the bottom of the until the blades stopped and i could feel the shaft slightly protruding from the top of the blades. Repositioning the blade has stopped the incessant whistling. Hope this helps!
Apr 19, 2009 | GE GSL25JFPBS Side by Side Refrigerator
WHISTLING NOISE DAY AND NIGHT IN FREEZER SECTION REFRIGERATOR GE MODEL GSS201BPDWW WHEN MOTOR IS WORKING
Apr 18, 2009 | GE Refrigerators
GE (GTS16BBS) Top Freezer Refrigerator Logo
89 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
