Sony Bravia KDF-E50A12U. TV approx 2yrs. old. About a month ago poor picture quality. Goes dark when the channel is changed and then lightens slightly. On the SKY TV GUIDE SCREEN there is a purplish area to almost the entire lower left quarter of the screen with a thin whitened area below this to sceen limit. Very poor picture whilst watching TV, strange fluorescence of bright pinks and bright blues especially.
  • 84 Answers
SOURCE: fuzzy picture
You can't make SD look like HD thats why HD came out, the best you can do is adjust the picture controls to get the optium picture
Posted on Apr 13, 2008
  • 668 Answers
SOURCE: dull dark picture on kdf-e50a12u rear projection
Depending how long you have owned it and if a Lamp was ever replaced, it probably needs to be replaced. You can check with SONY at
1800-222-SONY and see if they could sell and send you one.
Hope this helps,
Skyassoc
Posted on Jul 21, 2009
techman007
  • 1112 Answers
SOURCE: My sony bravia kdf-e50a12u turns itself off
Hello Abasama:
Ok so you have gotten other assistance and no luck huh..
First where did u purchase the lamp, Look at it and make sure its a phillips type lamp, Most sites will sell you a lamp made by LTI these lamps are of poor quailty and proformance. IF the green lamp light is flashing along with the red light, The green is in most cases the lamp light error indicator, the red one next to it is the Temperture indicator. first your need to determine how may flashes the light are indicating, You could have a Bad thermistor which is located on the lamp housing itself, its use to report the lamp temp back to the main signal board. But this error code usually gives 6 flashes and 5second intervals, and repeats ifself. I have an Ebook I wrote for these types of error codes which might help you. So this is what i want u to do.
1. First turn off television
2. In sequence using your orginal sony remote that came with the set, press DISPLAY KEY, 5 KEY, VOL UP THEN PRESS THE POWER BUTTON, you must press all 4 buttons within 3secs or it will not work. the set should come on with a dianostic mode menu, with options like Fans, lamp, lamp hours, lamp door etc.. some menus are different but all sony televisions uses these code to access the diagnostic screen. Next to the options are recorded error numbers the number of times a perticular error has occured. Example (Lamp Driver----------4, or Lamp door-----------1. this indicated that the lamp door has been removed once.
or Lamp Driver has either failed 4 times or the unit tried to light the lamp 4 times.. Just remember that the number to the right represents the number of times and error has occured for that perticular function. This simple menu should lead u in the right direction for solving your problem. One note i forgot to mention, the lamp driver error also could mean the lamp itself is bad and not the driver(Ballast). Also when you have solved your problem go back to the diag menu and hit the 8 key on your remote to reset all error options back to zero. to get out of the menu just turn off power with remote, you can do this first after you see what error is being reported the go back and see what it records to futher help you troubleshoot your set
Hope this helps, I sell the Ebook for 19.95 which shows you this procedure and how to replace your color wheel and so on..
you can email me at delhielectronics@live.com
Good luck..
Posted on Sep 22, 2009
  • 603 Answers
SOURCE: ghosting on hdmi channel on my sony bravia
With HDMI there should be no ghosting. And being a Sony Bravia it should be no ghosting. My 52" Sony is great.
You've got connection issues.
Posted on Nov 25, 2009
  • 336 Answers
SOURCE: Sony bravia KDF-E50A12U rear projecion tv wont turn on
Hi it sounds like it could be an issue with board that powers the lamp ,it's called the ballast.When you put a new lamp in the ballast has to provide more power ,when it starts to go weak it will not light up.Sometimes you can put your old lamp in and will work fine.Try partstore.com they might have it right there.Hvae a blessed one!
Posted on Mar 02, 2010
Sony Bravia 3D Smart Tv
If your TV is a month old call sony and get the TV serviced or exchanged. You are covered under warranty.
Apr 11, 2012 | Sony Bravia KDL-42V4100 42 in. LCD TV
I have a sony kdf-e50a12u tv and the picture is dark. i have tried to adjust the settings but its still dark what could the problem be
Hello hmt86,
Welcome and thank you for using FixYa!
This is the backlight bulbs or the inverter board that powers them. Both will need tested, hopefully only the inverter board will need replaced.
Have a great evening!
Sep 09, 2011 | Sony KDF-E50A12U 50" LCD HDTV
Mar 02, 2010 | Televison & Video
Ghosting on hdmi channel on my sony bravia
Nov 25, 2009 | Sony Televison & Video
Dull dark picture on kdf-e50a12u rear projection
Hope this helps,
Skyassoc
Jul 21, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Double vision on tv
http://www.avforums.com/forums/showthread.php?t=384717&page=8
this will fix it i have the same tv and it fixed my i have a prob my tv has gone dark and can not c the pic i had to put the brightness up just to c it
Dec 27, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Tired with this sony tv
Sony doesn't want anyone to see a poor picture on a Sony tv so they have a circuit that blanks the video if there is a weak picture or any other problem concerning picture quality. My Sony factory Instructor told me this many many years ago. I'm feeling old...but anyway you need a technician. Sorry.
barneyluc
Oct 03, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
