Question about Kenmore Dishwashers
NO WATER IN ANY CYCLE. WATER LINE OK. - Kenmore Dishwashers
  • Kenmore Master
  • 1,902 Answers
Hello
If you have already checked the water line for clogs and its clean then its the water inlet valve thats causing this problem. Please try to clean the inlet screen for any clogs and hope you understand if cleaning won't solve the issue then recommended repair is water inlet valve replacement. Please get back to me if you have any other questions.
Kevin
Posted on Nov 10, 2010
Water is going into the washer very slow during the rinse and spin cycle, also not carring the softner into the machine
Machine is not that old, the wash cycle water intake is ok? maybe bad water inlet valve? try seeing how it works on only cold and only hot water, change the hose lines from hot to cold and see what happens? as for the fabric thingy may have abad clogged line or a tiny hole in line and its going elsewhere
Sep 21, 2014 | Crosley Washing Machines
Motor not turning at all. Water goes in and pumps
Since you say relay sounds are heard, it shows the command is OK. The power to the motor is not reaching. It could be relay contact problem.
If you have a option of only spin, try this option. If it works the motor is OK. Otherwise you have to trace the power line and test it through a electrical line tester.
Apr 01, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Rinse cycle is not working. Is there a small water pump on the supply line and can it go bad
Hi there.......if the wash cycle is ok then the supply line wate pump is operating ok....some apliances use a tripple water inlet valve most likley cause is a failed valve or blocked filter on the valve
regards Sir Galahad
Aug 24, 2009 | Frigidaire Dishwashers
No water in washing/rinse cycle of dishwasher
It sounds as if the warter inlet valve (solinoid) isn't working and might have to be replaced. If everything else opeates fine, (unit pumps and sprays water that you added to it, pumps out and drains OK, then it is very likely the inlet valve has failed.
You can check for a blockage in the water inlet line, but unless you have a lot of sediment in your water or use a private well for your water supply, that would be a remote possibility, but worth taking a look at before buying replacement parts, etc.
You can remove the water supply hose/line and check for proper water flow and see if there is anything blocking the water from getting into the dishwasher. Many uints have a filter screen installed in them, so check that to see if it is blocked. Otherwise, look at the inlet valve and see if it is working correctly and go from there in replacing it.
One last thing, make sure the water supply line is actually providing water to the dishwasher, sometimes the water valves some installers use do get blocked, depending on how it was installed.
Jul 28, 2009 | Crosley Dryers
Water lines i think are ok but cant get water or make ice
Check the following:
See if the fridge has a water filter...it could be plugged and need replacement...check your manual for the location and replacement procedures
Check the inlet water line to the ice maker...it could be frozen...a hair dryer can be used to thaw it out and get the ice make to work again...be careful and don't overheat the ice maker inlet water line.
Make sure the water line is ok and not obstructed or kinked
Check the ice maker water valve to be sure it opens and isn't clogged
Cycle the arm on the ice maker and wait to see if it will make ice again
Jul 05, 2009 | GE Refrigerators
Water into washer
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 05, 2009 | Roper 24 in. RUD3000 Built-in Dishwasher
Does not complete spin cycle
Ok, when this happens, its usually because of a drainage issue. the spin cycle has to work in conjunction with the drain pump to remove the water during the spin cycle and, if there is a clog or drainage issue, the spin cycle will shutdown. check the following to address this drainage issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 01, 2009 | Frigidaire Washing Machines
Dishwasher doesnt drain on wash cycle,ok on rinse cycle
Change the circuit board, timer/progrsmer.
Take it out and clean contacts,
Look for burnt circuit line and solder a fine bead carefully on the circuit board, difficult. Use the pot and pan program.
Vitally
May 03, 2009 | Maytag MDB7100AWB Dishwasher
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Dishwashers Logo
242 people viewed this question
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
