Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Changed bulb power light from red to flashing orange what does this mean
The bulb is not securely placed make sure the screw isin the back tight. also make sure the plastic cover is on and turn it off and on again should fix the problem.
Posted on Nov 15, 2010
I have a flashing orange and red light on the side of where mother power adapter goes into thehilsense computer what does it mean?
If light of adapter is green before connecting to computer, and it becomes red/orange, please get your computer's power socket checked it may be partially short.
For more clarification please mail on ali_zulfikar@yahoo.com with PIX.
Sep 16, 2017 | Orange Computers & Internet
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
First, thank you for your suggestion second, that's not the solution that I mean, I'm talking about system, the car provided with both systems in the rear, the red one is the same bulb of brake with same...
if you asking what i think your asking then you are trying to get the indicators to work europeon style and your back lights are wired to that silly american flashing stop light stlye ,well to change them over their is no switch as such you will have to return to the dealer to have the wiring plugs changed around and i do not know offhand whats involved but the dealer will have a boulitin for their mechanics to do this .It will involve disconnecting and changing the stoplight switch and disconnecting the feed from indicator stalk so it runs direct to the rear lights .hate this american idea as its so confusing when driving behind a vehicle with these lights
Nov 29, 2010 | 2007 Kia Optima
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console
VT440K orange power flashing red status light, overheated.
Make sure all the air filter caps are all the way in and nothing is broken from it. that was my cause..i had the same problem
Apr 17, 2009 | NEC (50019497) Projector Lamp for VT440,...
Red Flashing Icon
The icons from the left: 1. Power indocator 2. Hard Disk indicator --> it is a tube icon, not battery, but means hard drive. 3. Power Source indicator 4. Bluetooth indicator
The third from left means the power source indicator. Normally it is light green. If there is battery problem (can not charge or battery overload) it flashes amber/orange. If flashes red, it indicates that the battery power is low. You need to change the battery or connect the AC adapter.
Regards,
Dapid Candra
Dec 02, 2008 | Dell Latitude D505 Notebook
Flasing red light
The flashing red indicates that either the fileter cover or the lamp cover is not installed correctly. If both are installed properly and secured, the unit will require service.
Dan
May 09, 2008 | Sharp XR-10X Multimedia Projector
Changed bulb, now tv does nothing. . .please help
same problem. TV turns on but no picture or sound. when i press power button on the remote control orange light flashes for about a minute and goes back to red.
TV won't turn on. It iz frustating me a lot ay !
Mar 07, 2008 | Televison & Video
Panasonic PT 50LC14 problem
You have to close the lamp door. It has a switch in it much like a clothes dryer door in that when it is open it wont operate.
Feb 23, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
73 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
