Question about Nelson Sprinkler: Traveling Tractor
I need to take the rear wheels off to replace the motor assembly. Any suggestion on how to get the metal axle cover off?
  • 4 Answers
They are a pain. Just clamp on with a pair of vise grips & rock back & forth. Once you get a little slack under them then try a claw hammer. Just like pulling a nail. If you ruin it they carry them at Home Depot or Lowes in the hardware area. Just like what holds the wheels on a wagon or bbq grill. I can't remember what dia the axle is. If you don't have calipers just use a open end wrench to find the shaft size.
Posted on Jun 23, 2011
  • glen kelly
    glen kelly Aug 12, 2017
    I first took a punch to the flange that locks the cap into the groove on the axle, breaking the connection, and they slid right off with vice grips.
2007 ford sport trac rear wheel bearing replacement
Jeff is describing how to replace the front wheel bearings. In the front, the bearing is part of a "hub cartridge". Randy is describing how to change the rear bearings on a truck with a "dead" rear axle. The sort of differential which is one massive cast iron assembly from rim to rim. However, your truck has an IRS [Independent Rear Suspension] design. You need to remove the wheels, brakes & the complete rear knuckle assembly. To remove the bearing from the knuckle requires a hydraulic press and a "knife edge" bearing removal tool. I doubt that you have these tools available. If not, find an auto parts store or auto machine shop with these tools. They can press the old bearing out and install the new one for you. Then you can reassemble the knuckle assembly from that point on. The video linked below should help you.
Ford Explorer Independent Rear Suspension Rear Wheel Bearing and Hub...
With the knuckle off, you can easily replace the ball joints at the same time. Odds are you will ruin the original ball joints getting the knuckle assembly off, anyway.
Jan 11, 2015 | 2007 Ford Explorer Sport Trac
On my 2004 suzuki vl 800 I want to take off the back tire on the left side where you put the gear oil does that come off with the tire
Yes, the oil reservior separates from the wheel assembly. Here is the whole process for removing the rear wheel assembly. In order to remove the rear wheel assembly, you are going to need a motorcycle lifting jack stand or similar device.
1. Stand the bike on the side stand
On the left side of the rear wheel:
2. Remove the two forward facing bolts.
3. Remove the allen head bolt with the wide head.
On the right side of the rear wheel:
4. Remove the brake adjuster nut on the end of the actuating lever.
5. Remove the Toque link nut at the bottom of the wheel assembly.
6. Remove the axle nut (castle nut and cotter pin). Move aside the now loose plastic former on the left side of the bike and remove the axle from that side. You will need to hold the castle nut while loosening the axle.
7. Place the motorcycle jack under the swing arm or chassis tubes to stabilize the rear end. Lift the motorcycle until the rear tire is just off the ground.
8. Remove the axle. When you remove the axle, the spacer under the left side cover will probably fall out.
9. Remove the three cap nuts (left side) and use a screwdriver to gently pry the wheel from the splined drive gear and place the wheel assembly on the ground.
10. Pull the wheel assembly rearward.
Reverse the process to replace the wheel.
Check the level of the final drive oil and fill as needed with SAE90 hypoid gear oil with a GL-5 rating. While you have everything apart, you should also check the brake pads and wheel bearings for wear and replace if necessary. God Bless and good luck!
May 30, 2011 | 2004 Suzuki VS 800 Intruder
1998 ford explorer 2 wheel drive rear wheel bearing replacement
what about it?
conventional axle or limited slip? Get axle code off door sticker.
SECTION 205-02: Rear Drive Axle/Differential - Ford 8.8-Inch Ring Gear 1998 Explorer/Mountaineer Workshop Manual
IN-VEHICLE REPAIR Rear Wheel Bearing and Axle Shaft Oil Seal -4.0L SOHC and 4.0L EI, Conventional
Special Tool(s) swn~us~en~file=st1514a.gif~gen~ref.gif Axle Seal Replacer
T83T-1175-A swn~us~en~file=st1283a.gif~gen~ref.gif Axle Wheel Bearing Puller
T83T-1225-A swn~us~en~file=st1322a.gif~gen~ref.gif Axle Wheel Bearing Replacer
T83T-1225-B swn~us~en~file=st1326a.gif~gen~ref.gif Driver Handle
T80T-4000-W swn~us~en~file=st1185a.gif~gen~ref.gif Impact Slide Hammer
T50T-100-A
Removal
  1. Remove the axle shaft; refer to Axle Shaft in this section.
Axle Shaft Removal
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not use heat to loosen a seized lug nut. Heat can damage the wheel (1007) and the rear wheel bearings (1225).
    Loosen the lug nuts (1012).
    1. Remove the center cap.
    1. With the weight of the vehicle on the wheels, loosen the lug nuts.
  1. Raise and support the vehicle.
  1. Remove the wheel and tire assembly.
    1. Remove the lug nuts.
  1. Remove the axle housing cover (4033).
    1. Loosen the axle housing cover bolts (4346) and drain the rear axle (4001).
    1. Remove the axle housing cover bolts.
    1. Remove the axle housing cover.
  1. Remove the rear disc brake rotors (2C026); refer to Section 206-04 .
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the differential pinion shaft (4211) has been removed, turning the differential case (4204) or an axle shaft (4234) will cause the differential pinion gears (4215) to fall out of the assembly. This could result in chipped or damaged components.
    Remove the differential pinion shaft.
    1. Remove the differential pinion shaft lock bolt.
    1. Remove the differential pinion shaft.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-rings in the U-washer grooves.
    Remove the U-washers (4N237).
    1. Push the axle shafts inboard.
    1. Remove the U-washers.
  1. Reinstall the differential pinion shaft.
    1. Install the differential pinion shaft.
    1. Install the differential pinion shaft lock bolt finger-tight.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the inner wheel bearing oil seal (1177).
    Remove the two axle shafts.
Installation
  1. Lubricate the lip of the inner wheel bearing oil seal.
    • Use Premium Long-Life Grease XG-1-C or equivalent meeting Ford specification ESA-M1C75-B.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the differential pinion shaft has been removed, turning the differential case or an axle shaft will cause the differential pinion gears to fall out of the assembly. This could result in chipped or damaged components.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the inner wheel bearing oil seal.
    Install the two axle shafts.
    Install the U-washers.
    1. Position the two U-washers on the button end of the axle shafts.
    1. Pull the axle shafts outward.
    1. Align the hole in the differential pinion shaft with the differential pinion shaft lock bolt hole.
    1. Install the differential pinion shaft lock bolt.
  1. Install the rear disc brake rotors; refer to Section 206-04 .
  1. Install the axle housing cover and fill the rear axle housing (4010) with 2.4 liters (5.5 pints) of specified lubricant; refer to Axle Housing Cover in this section.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Always remove any corrosion, dirt or foreign material that may be present on the mounting surfaces of the wheel or the surface of the wheel hub or rear disc brake rotor that contacts the wheel. Installing wheels without proper metal-to-metal contact at the wheel mounting surfaces can cause the lug nut to loosen and the wheel to come off while the vehicle is in motion, causing loss of control.
    Clean the wheel hub and mounting surfaces.
  1. Install the tire and wheel assembly.
    1. Position the tire and wheel assembly.
    1. Install the lug nuts and lower the vehicle.
    1. Tighten the lug nuts.
    1. Install the center cap.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Never remove the axle shaft oil seal by itself. Always remove the rear wheel bearing and the axle shaft oil seal at the same time.
    NOTE: If the axle shaft oil seal is leaking, the axle housing vent may be plugged with debris.
    Use Impact Slide Hammer and Axle Wheel Bearing Puller to remove the rear wheel bearing and the axle shaft oil seal.
Installation
  1. Lubricate the new rear wheel bearing.
    1. Use Thermally Stable Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
  1. Use Axle Wheel Bearing Replacer with Driver Handle to install the rear wheel bearing.
  1. Lubricate the lip of the new axle shaft oil seal.
  1. Use Axle Seal Replacer with Driver Handle to install the axle shaft oil seal.
  1. Install the axle shaft; refer to Axle Shaft in this section.
May 18, 2011 | Ford Explorer Cars & Trucks
My dad has a pride celebrity xl scooter and keeps getting a noise similar to a rubbing noise from rear right wheel while driving, it sounds once for every rotation of the wheel, iv checked that nothing is...
The noise you are describing usually comes from the trans-axle and not from the motor/brake. Motor brake noise is usually continuous. Sounds like the trans-axle may be slightly bent on the right or rubbing internally. The easiest way to identify this is to block up the scooter and remove the rear cover. Look and listen to all the drivetrain components while the scooter is blocked up and running. If you hear rubbing at the end shaft as you describe you can try the following:
Loosen the trans-axle metal mounts that clamp the rubber sleeves over the trans-axle
Spray the rubber sleeves with silicone.
Re-torque the clamps after checking the alignment.
An overtightened or misaligned clamp can sometimes cause noise.
The brake/motor/transaxle has a prorated three year warranty so you should go through a Pride dealer for warranty repairs.
Sometimes you can get a noisy wheel on the key and key-way of the trans-axle shaft. It may be worthwhile to pull both rear wheels lubricate the shaft key-ways and keys and re-install the wheels. This can sometimes quiet a multitude of noises from the trans-axle. Depending on the age of the scooter you can do nothing, replace the brake/motor/transaxle parts individually, replace the complete assembly. I like to replace the entire assembly under warranty so there are no future problems. The rest of the repair depends on your insurance coverage or budget. Hope this helps.
Nov 30, 2010 | Pride Celebrity Xl 4 Wheel Scooter
How do you change a wheel seal on a mercury mountaneer 1998 rear end
Axle Vent
NOTE: If the vent cannot be cleared, it must be installed new.
A plugged vent will cause excessive seal lip wear due to internal pressure buildup. If a leak occurs, check the vent. Make sure the vent hose is not kinked. Remove the hose from the vent nipple and clear the hose of any foreign material. While the hose is removed, pass a length of mechanics wire or a small diameter Allen wrench in and out of the vent to clean it. Connect the hose when done. The vent is located on the drivers side top of axle housing.
If you plan on doing most repairs yourself I would suggest buying a Haynes or Chilton manual for your particular vehicle. Or there are some data disks on e.bay($12-$15) For a cost of under $25, you can almost do any repair yourself with these manuals.Also there are online manuals like the site called ALLDATA where guides can be viewed for a fee. All these solutions will save you time and money, and give peace of mind over correct repairs. I can post you some procedures here also.
  1. CAUTION: Do not use heat to loosen a seized lug nut. Heat can damage the wheel (1007) and the rear wheel bearings (1225).
  2. Loosen the lug nuts (1012).
  3. Remove the center cap.
  4. With the weight of the vehicle on the wheels, loosen the lug nuts Raise and support the vehicle. .Remove the wheel and tire assembly.
  5. Remove the lug nuts.
  6. Remove the wheel and tire assembly. Remove the axle housing cover (4033).
7.Remove the rear disc brake rotors You will have to remove the brake caliper to get rotor off.
8. CAUTION: Once the differential pinion shaft (4211) has been removed, turning the differential case (4204) or an axle shaft (4234) will cause the differential pinion gears (4215) to fall out of the assembly. This could result in chipped or damaged components.
9.
1.Remove the differential pinion shaft lock bolt. 2.Remove the differential pinion shaft. 4fd1df0.gif 10.CAUTION: Do not damage the rubber O-rings in the U-washer grooves. Remove the U-washers (4N237).
  2. Remove the U-washers.
    11.Reinstall the differential pinion shaft.
      12.CAUTION: Do not damage the inner wheel bearing oil seal (1177). Remove the two axle shafts. 1848771.gif
CAUTION: Never remove the axle shaft oil seal by itself. Always remove the rear wheel bearing and the axle shaft oil seal at the same time. NOTE: If the axle shaft oil seal is leaking, the axle housing vent may be plugged with debris. Use Impact Slide Hammer and Axle Wheel Bearing Puller to remove the rear wheel bearing and the axle shaft oil seal.
0ffed5b.gifAxle bearing puller end..
Installation
  1. CAUTION: Once the differential pinion shaft has been removed, turning the differential case or an axle shaft will cause the differential pinion gears to fall out of the assembly. This could result in chipped or damaged components.
  2. Remove the differential pinion shaft.
  3. Remove the differential pinion shaft lock bolt.
  4. Remove the differential pinion shaft.
    CAUTION: Do not damage the inner wheel bearing oil seal. Install the two axle shafts. CAUTION: Do not damage the rubber O-rings in the U-washer grooves. Install the U-washers.
                                                            Install the rear disc brake rotors; Install the axle housing cover and fill the rear axle housing (4010) with 2.4 liters (5.5 pints) of specified lubricant
                                                            WARNING: Always remove any corrosion, dirt or foreign material that may be present on the mounting surfaces of the wheel or the surface of the wheel hub or rear disc brake rotor that contacts the wheel. Installing wheels without proper metal-to-metal contact at the wheel mounting surfaces can cause the lug nut to loosen and the wheel to come off while the vehicle is in motion, causing loss of control. Clean the wheel hub and mounting surfaces. Install the tire and wheel assembly.
                                                            Position the tire and wheel assembly. Install the lug nuts and lower the vehicle. Tighten the lug nuts. Install the center cap. 6a78fd6.gif WHEW Hope this can help you
                                                            Mar 21, 2010 | 1998 Mercury Mountaineer
                                                            1989 chevy 3500 4x4 454 rear brake drum removal. Does the axle bolts need to be removed
                                                            Can you tell me which type of axle you have?
                                                            Full Floating Axles To remove the drums from full floating rear axles, use the Axle Shaft Removal & Installation procedure in Section 7. Full floating rear axles can readily be identified by the bearing housing protruding through the center of the wheel.
                                                            Semi-Floating Axles
                                                            1. Raise and support the rear end on jack stands.
                                                            2. Remove the wheel.
                                                            3. Pull the drum from the brake assembly. If the brake drums have been scored from worn linings, the brake adjuster must be backed off so that the brake shoes will retract from the drum. The adjuster can be backed off by inserting a brake adjusting tool through the access hole provided. In some cases the access hole is provided in the brake drum. A metal cover plate is over the hole. This may be removed by using a hammer and chisel.
                                                            You may have to back off the automatic adjuster before you can pull the drum from the brake assembly
                                                            To install, reverse the removal procedure.
                                                            Dec 01, 2009 | 1989 Chevrolet C/K 3500
                                                            Tumble dryer
                                                            1. This doesn't appear to be a simple task so I would suggest making sure you have the time to do this so your project does not get interrupted.
                                                            2. Step 2 1: Remove power (better now than later ;-) )
                                                              2: Remove the front door assembly (2 screws holding the hinge to the drier carcase)
                                                              3: Remove the top cover (2 screws at the rear, then slide the top backwards and lift off). It's a good idea to remove any fluff from the innards at this point.
                                                            3. Step 3 4: Lay the drier carefully on it's front (I used a pillow to protect the timer and 2 pushbuttons)
                                                              5: Remove the cover over the drum bearing and earth strap (2 screws)
                                                              6: Remove the cover over the fan assembly (numerous screws)
                                                            4. Step 4 7: Remove the earthing bracket (copper assembly held by 2 small screws) and then remove the circlip and washer on the drum axle
                                                              8: Remove the fan vanes (3 hex screws holding 2 metal flanges that make up the impeller fan)
                                                              9: Remove all screws around the rear cover and gently lift it up (I supported one edge with a basin perched on the rear of the drum, it gives access to the motor chassy etc. There's a vent tube that will come dislodged at this point; it's easy to relocate later.
                                                            5. Step 5 10: Remove any bits of the old belt and drop the new one round the drum. Use tape to hold the belt in the correct position on the drum (if you don't do this, you WON'T gave enough slack to go round the motor pulley....believe me!!)
                                                              11: Carefully feed the belt past one idler wheel and then over the motor pulley. Slowly turn the drum slightly to encourage the belt to feed round the second idler wheel.
                                                            6. Step 6 12: Remove the tape used to hold the belt in place
                                                              13: Replace the rear cover (make sure the vent tube is seated correctly at front and rear). Tighten all screws.
                                                            7. Step 7 14: Replace the Fan assembly
                                                              15: Replace the drum bearing circlip (I took the opportunity of rotating the bearing through 180 degrees). Replace the copper earthing strap.
                                                              16: Replace the fan housing cover and drum bearing cover. (Make sure the heating element is free of fluff and crud)
                                                            8. Step 8 17: Replace the top cover
                                                              18: Fire up the beast!!! It may smell a little if there's anything still on the heating element.
                                                            May 22, 2009 | LG Dryers
                                                            How do you remove right rear axle on a 2004 ford crown vic to replace seal on wheel?
                                                            Section 05-02A: Axle, Integral Carrier — 8.8-Inch Ring Gear 1994 Town Car, Crown Victoria/Grand Marquis. Workshop Manual REMOVAL AND INSTALLATION Axle Shaft NOTE: Whenever replacing the rear axle lubricant, use Rear Axle Lubricant XY-90-QL (ESP-M2C154-A) or equivalent.
                                                            Removal
                                                            sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The rear brake anti-lock sensor must be removed before the axle shafts are removed. The rear brake anti-lock sensor is bolted on the rear disc brake caliper anchor plate.
                                                            1. Raise vehicle to desired working height. Refer to Section 00-02 . Remove rear wheel (1007) and tire assembly. Remove rear disc brake calipers (2552) and rear disc brake rotors (2C026) .
                                                            1. Clean all dirt from area of axle housing cover with a wire brush and/or cloth.
                                                            1. Drain rear axle lubricant by removing the axle housing cover .
                                                            1. Remove differential pinion shaft lock pin and differential pinion shaft .
                                                            1. Push flanged end of the axle shafts toward the center of the vehicle and remove the rear axle shaft retaining u-washer from the button end of the axle shaft .
                                                            1. Remove axle shaft from the rear axle housing , being careful not to damage the inner wheel bearing oil seal (1177) and rear brake anti-lock sensor ring.
                                                            Installation
                                                            NOTE: Check for presence of rear axle shaft o-ring (4A332) on the spline end of the shaft and install if not present.
                                                            sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Care must be taken not to let axle shaft splines damage oil seal or bearing assembly.
                                                            1. Carefully slide axle shaft into rear axle housing without damaging rear wheel bearing (1225) or rear brake anti-lock sensor indicator (2C189) . Start splines into side gear and push firmly until the button end of axle shaft can be seen in the differential case .
                                                            1. Install the rear axle shaft retaining u-washer on the button end of the axle shaft splines, then pull the shaft outboard until the shaft splines engage and the rear axle shaft retaining u-washer seats in the counterbore of the differential side gear .
                                                            1. Position the differential pinion shaft through the differential case and differential pinion gears , aligning the hole in the differential pinion shaft with the lock bolt hole. Apply Rear Axle Lubricant to differential pinion shaft lock pin . Install differential pinion shaft lock pin and tighten to 20-41 Nm (15-30 lb-ft). sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Differential pinion shaft lock pin must be tightened to specification using Stud and Bearing Mount E0AZ-19554-BA (WSK-M2G349-A1) or equivalent.
                                                              NOTE: Axle housing cover must be installed within 15 minutes of application of the silicone rubber or new silicone rubber must be applied.
                                                              sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Make sure machined surfaces on both axle housing cover and rear axle housing are clean before installing the new silicone sealant. Inside of axle must be covered when cleaning the machined surface to prevent axle contamination. Tighten the cover bolts in a crosswise pattern to ensure uniform draw on axle housing cover .
                                                            1. Apply Silicone Rubber D6AZ-19562-AA or BA (ESB-M4G92-A or ESE-M4G195-A) or equivalent. Install axle housing cover and tighten retaining bolts to 28-38 Nm (38-52 lb-ft).
                                                            1. Add Motorcraft Rear Axle Lubricant XY-90-QL or KL (ESP-M2C154-A) or equivalent until it is 6-14mm (1/4-9/16 inch) below bottom of fill hole. Add 118.3 mL (4 oz) of Ford Additive Friction Modifier C8AZ-19B546-A (EST-M2C118-A) or equivalent to Traction-Lok axles. Install fill plug and tighten to 20-41 Nm (15-30 lb-ft).
                                                            1. Install rear brake anti-lock sensor indicator . Tighten retaining bolt to 4.5-6.8 Nm (40-60 lb-in).
                                                            1. Install rear disc brake caliper and rear disc brake rotor .
                                                            1. Install wheels and tires.
                                                            1. Insert Rear Bearing Remover T85L-1225-AH in bore and position it behind bearing so tangs on tool engage bearing outer race. Remove rear wheel bearing and inner wheel bearing oil seal as a unit, using Impact Slide Hammer T50T-100-A.
                                                              Rear Disc Brake Caliper Anchor Plate
                                                            1. Lubricate the rear wheel bearing with Rear Axle Lubricant.
                                                            1. Install rear wheel bearing into the housing bore using Axle Tube Bearing Replacer T78P-1225-A.
                                                              sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Installation of rear wheel bearing or inner wheel bearing oil seal assembly without proper tool may result in an early bearing or seal failure. If inner wheel bearing oil seal becomes cocked in bore during installation, remove it and install a new one.
                                                            1. Install the inner wheel bearing oil seal using Axle Tube Seal Replacer T78P-1177-A. Use Premium Long-Life Grease XG-1-C or K (ESA-M1C75-B) or equivalent between the lips of the inner wheel bearing oil seal .
                                                            1. Install axle shafts as outlined.
                                                            May 13, 2009 | 2004 Ford Crown Victoria
                                                            Replace left rear axle seal 1999 ford explorer
                                                            Axle Shaft Removal
                                                            1. Raise and support the vehicle. For additional information, refer to Section 100-02 .
                                                            1. Remove the wheel and tire assembly. For additional information, refer to Section 204-04 .
                                                            1. Remove the differential housing cover (4033).
                                                              1. Loosen the bolts and drain the lubricant from the rear axle housing (4010).
                                                              1. Remove the bolts.
                                                              1. Remove the differential housing cover.
                                                            Remove the rear brake disc (2C026). For additional information, refer to Section 206-04 .
                                                            1. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Turning the differential case (4204) or an axle shaft (4234) with the differential pinion shaft (4211) removed will cause the differential pinion gears (4215) to fall out of the assembly and damage the components.
                                                            2. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-ring in the U-washer groove.
                                                            3. Remove the U-washer (4N237).
                                                            4. Push the axle shaft inboard.
                                                            5. Remove the U-washer.
                                                            2. Install the differential pinion shaft lock bolt finger-tight.
                                                            3. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the wheel bearing oil seal (1177).
                                                              Remove the axle shaft.
                                                            Seal Removal
                                                            1. Remove the axle shaft (4334). For additional information, refer to Axle Shaft in this section.
                                                            1. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Never remove the wheel bearing oil seal (1177) by itself. Always remove the rear wheel bearing (1225) and the inner wheel bearing oil seal at the same time.
                                                              NOTE: If the wheel bearing oil seal is leaking, the axle housing vent may be plugged with foreign material.
                                                              Using the special tools, remove the rear wheel bearing and wheel bearing oil seal together.
                                                            6c7eb46.gif Installation
                                                              • For 4.0L SOHC and 4.0L EI with limited slip rear axles and 5.0L vehicles, use SAE 75W-140 High Performance Rear Axle Lubricant F1TZ-19580-B or equivalent meeting Ford specification WSL-M2C192-A.
                                                              • For 4.0L SOHC and 4.0L EI with conventional rear axles, use SAE 80W-90 Premium Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
                                                            1. Using the special tools, install the rear wheel bearing.
                                                            1. Lubricate the lip of the new wheel bearing oil seal.
                                                            1. Using the special tools, install the wheel bearing oil seal.
                                                            1. Install the axle shaft. For additional information, refer to Axle Shaft in this section.
                                                            Feb 22, 2009 | 1999 Isuzu Rodeo
                                                            Rear passenger wheel and brake plate axle damaged
                                                            I would, Too be on the Safe Side. An Action like this Almost EVERY time will Warp the Axle and Cause Major Problems with the Suspension. I own a 95' Silverado and had a Similar Problem.
                                                            Jan 21, 2009 | 1996 Chevrolet K1500
                                                            Nelson Sprinkler:  Traveling Tractor Logo
                                                            202 people viewed this question
                                                            Top Nelson Garden Experts
                                                            Dennis
                                                            Mike Squire
                                                            Phil Walker
                                                            Phil Walker
                                                            Are you a Nelson Garden Expert? Answer questions, earn points and help others
