TOSHIBA SATELLITE P35-S611 W/GLOSSY SCREEN. Screen looks fine in all respects but the letters shimmy. Small letters are impossible to read. I tried two screens and both did the same. This just started today. Any suggestions??? Thanks, Jim Jackson
  • 1 more comment
  • amfriction Nov 10, 2010
    I tried you solution and it did nothing at all. Looking closer it looks as if the shimmering is hirizontal lines (not vertical.
    Jim J.
    I tried what was suggested but had "no" effect. Any suggestions?? Thanks,
    Jim Jackson
    Why would the same thing happen to two different screens. The laptop I tried them on is on now and the picture is fine???
    Jim J.
  • 12,061 Answers
Well I would think, in this case your screen and or Inverter are on the way out :(.. this is what will happen after a while, it will get gradually worse and worse until it fails completely.
Screen replacement and Inverters are easy to replace very fiddly, but pretty easy with the right instructions one should have no problem replacing these items. usually the replacement parts can be obtained from say Ebay or the like. Accordingly i have given you links below that show you how to disassemble and repair your unit.
http://www.laptoprepair101.com/laptop/2006/02/04/toshiba-laptop-disassembly-manuals/
Below is your user manual, above the disassembly how to's
http://www.retrevo.com/support/Toshiba-P35-S611-Laptops-manual/id/614bh649/t/2/
Posted on Nov 10, 2010
    President:
  • 3,278 Answers
Hello.
If you replaced the screen display on the laptop, or tried an external monitor, with the same results, then your video card or display driver could be problematic or another component other than the display.
Access the Device Manager. Find your display, Right-click and update the driver.
It's also possible that malware or a virus could be causing this problem. Try Malwarebytes (http://www.malwarebytes.com ). It's a free malware program. Download, install, update and run and remove any malware.
Hope this helps.
Posted on Nov 11, 2010
  • 6,993 Answers
Is this problem on only on web pages or all aspect of windows.
To increase font on web page, Press and hold control button (ctrl) on your keyboard, then press plus (+) constantly and your web page letters should increase. (Ctrl +)
To reduce if its too large, press ctlt then minus (-).
Good luck.
Can not read items in google search print too small
Click on view, tect size, thoose you from the list.
or,
your desktop is set to a high res. right click on desktop, prop, settings, choose a lower screen res. ( note this will also increase your icon size)
Dec 31, 2010 | Toshiba Satellite P35-S611 Notebook
Laptop shows Toshiba Logo, then Bios option, and then goes black
yes its very possible maybe the one u replaced was faulty?
Apr 08, 2010 | Toshiba Satellite P35-S611 Notebook
Toshiba satellite p35-2611 2 inch(1
the worse thing it could be is the lcd going out in a very bad way. Yes likely to get wrose over time, No not the video card because it happends on every screen, boot,preboot,and windows so guess what? If you have the lcd replaced you will be looking at a good laptop once again. Price aroung $75-100 bucks where? Ebay of all sources. Thanks I hope this was Very Helpful to you if so lay ing your ratings.
Dec 13, 2009 | Toshiba Satellite P35-S611 Notebook
Satellite P35-S611 has trouble charging
If you have to wiggle the power cord it is most likely the DC jack on the motherboard. It is usually the center pin in the the jack that breaks the solder point and the small tension band inside the jack housing weakens.
Sep 26, 2009 | Toshiba Satellite P35-S611 Notebook
I have a toshiba p35 s611 with the os changed from xp home to xp pro. Now the media player plays full screen and will not close. Only Alt+F4 will close it. I have the ATI's Mobility Radeon 9000 drivers...
Look in device manager to see which drivers you need. The ATI drivers are kind of picky so look in device manager to get the exact hardware names that are marked with yellow or red. With the upgrade you lost some drivers and will have to get them on the web with the names listed in device manager
Aug 30, 2009 | Toshiba Satellite P35-S611 Notebook
Lines on screen
usually when you have lines on your screen then you have to buy a new one
Apr 22, 2009 | Toshiba Satellite P35-S611 Notebook
Screen problem.
Does your LCD look like this or similiar? (below) If it does, there should be a female plug similiar to the picture also below.
Hook smaller end of cable to your laptop, the other end to your external monitor. Turn on your laptop. If the vertical lines are not present then its probably your LCD, which will more than likely have to be replaced. If lines are present, then like tom19511 said it may be the video drivers. I've had this same problem with my Toshiba Satellite p35 5 times already. Toshiba had to replace my LCD each time. LCD's are more expensive than an inverter. Good luck, I hope you get it fixed.
Dec 13, 2007 | Toshiba Satellite P35-S611 Notebook
Open Questions:
Losing data is a disaster. Never let that happen Use Cloud Backup'Call +1888784-9316 Cloud storage services are great for sharing files with friends and families, keeping documents in sync between all your devices, and so much more. Free cloud storage is even better! Several backup services offer free online backup plans. DataAlign is known for having the finest free cloud data backup software in the world! Not just being simple and automatic it can be customized to a large extent and not to forget the scheduling capabilities that allows it to run at any time of the day. With several years of experience in its kitty, DataAlign is the trusted innovators in free online backup solution. DataAlign is proud to be known as a market leader in providing Server Cloud Backup Solution based storage and individuals is our primary motto. Our innovative platform has been designed while keeping you in mind. To provide Cloud Backup For Small Business optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Unlike other companies, there are no catch with DataAlign free cloud backup solution. With the kind of experience, you get with DataAlign, we strongly believe that you will eventually upgrade your account to a bigger one. And that makes us give awa Online Backup Pricing accounts as a free version with no strings attached. So drop your worries and and setup your free cloud data backup account with DataAlign. Just to clarify we will not ask for your credit card details upfront when you sign up for a free account. Keep using your free account as long as you need it. DataAlign has been designed with you in mind. You wouldn't require any technical skiil or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
May 28, 2018 | The Computers & Internet
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
