Question about SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue
I have a simpletech harddirve 120 GB. Had it for about 2 years. The blue and red light usually appears and you could feel it run. Now theres no sound or moving parts and now only the red light appears. My computer does not recognize it. I tried several other computers with no luck.
    Brigadier General:
  • 10,406 Answers
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
Posted on Nov 10, 2010
My computer won't recognise my 120 gb simpletech harddrive unknown device and driver software not installed
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Sep 14, 2011 | SimpleTech (sti-u2f36/120) 120 GB Hard...
Solve Your SimpleTech (SP-U25/120G) 120 GB USB Hard Drive Blue lights are not on. Windows 7 does not recognize. I think driver is not installed. Pl advice
if your computer came with a motherboard disk the drivers could be on it
hope this helps
Jul 04, 2011 | SimpleTech (SP-U25/120G) 120 GB USB Hard...
I dropped my Simpletech 250 gb external drive for several times, now when i plugged in to my pc the red light is on but the blue light is not coming out, and i cannot see the external drive in my pc, how...
Take out the hard disk from your case and put it inside a desktop- if there's still some life left in it it will appear in My Computer. If it doesn't appears even there then it's dead for sure and all the data on it is lost.
Jan 30, 2011 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech 500 GB external hard blinking red light
I got one with the same problem. I opened up the case and hooked up the hard drive to a generic usb to sata adapter that i picked up on ebay and it works fine now if a bit clunky looking.
Sep 10, 2009 | SimpleTech 500GB SimpleDrive Pro External...
Simpletech 500 GB Hard Drive not working
The red light is an indicator of drive failure. The fall it took, especially if the drive was on at the time, could easily cause the drive to break something internally so that it will not function. I found SimpleTech drives to fail pretty easily, even when you're not dropping them. That's been my experience, anyway.
Data recovery is a very expensive proposition. If the hard drive doesn't respond to the interface as normal, they have to be pulled apart and data extracted from the internal platters. This isn't something you can do without a full safe room (dust-free, wearing special suits and all) because any dust can ruin the platter. Since it's so involved, it's usually really, really expensive. Generally, most people don't bother when it reaches that point unless it's business files (like all of your financial data, for instance).
However, if it's something you really need that bad, DriveSavers is one of the best:
http://www.drivesaversdatarecovery.com/
Jun 21, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
My simpletech 120 gb hard disk is not detecting over my pc what to do?
right click on my computer --> manage --> disk management
does it detect there ?
Also what about in device manager ( right click on my computer --> properties --> hardware tab --> device manager
Apr 17, 2009 | SimpleTech (STUU2F35120) 120 GB Hard Drive
Clicking noise and red light instead of green...need data!!
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Apr 07, 2009 | Acomdata HD120U2FE-72 120 GB Hard Drive
SimpleTech 80 GB Portable HD Won't Read
It sounds like a problem with the board inside the case,- the actual hard drive is probably OK. Opening the case will void any warranty but there may not be much left anyway. There should be 4 screws in the bottom of the drive,- front 2 may be hidden under a sticker. Try installing the drive in your new case or an empty drive bay inside your computer. I have had external hard drive cases fail before and the actual hard drive was ok.
Jan 23, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
131 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
