Question about Amana NDE2330AY Electric Dryer
Is there a wiring diagram for the hookup next to the blower wheel assembly? And for the two wires for the door shut off switch?
  • johnbec Nov 10, 2010
    MODEL # LE8317W2
    SERIAL # 9601049154
    My door switch has a gray and a red wire, but my switch has three possible connections.
    The thermostat piece has 5 hook ups and 5 wires red, black, white, blue and orange. I'm not sure which wires go to which.
    This is the thermostat piece on the front next to the blower assembly.
    This is the door switch.
    Thanks.
  • johnbec Nov 11, 2010
    Amana Clothers Dryer
    Model # LE8317W2
    Serial # 9601049154
    I'm reattaching the thermostat wiring on the blower wheel housing assembly. There are 5 wires. The blue, red, an orange wires only fir on certain terminals: no problem. But each of the remaining two wires, one white, one black, can fit on either of the two remaining terminals. are they essentially interchangeable?
    President:
  • 1,891 Answers
Yes there is a wiring diagram / you should have one in the control panel and if not ther on the removeable front . if its not there its in maytags fact sheets and i tell you how to get to it .. hope this helps mm feed back pls .. mm
Posted on Nov 12, 2010
  • Amana Master
  • 8,220 Answers
I have located your wiring diagram HERE
A white wire and a yellow wire go t the door switch.
This will work if your dryer serial number starts with 11.
That's what series 11 means.
This the series 12 diagram
Here is your Amana dryer tech service manual
Posted on Nov 10, 2010
  • Dan Webster
    Dan Webster Nov 10, 2010
    The switch has 3 possible connections but all are a different size. So it is difficult to connect them wrong. If you only have 2 wires then you do not have a light in the dryer. You get it backwards and the dryer will run only with the door open and die when you close the door so that is the worst thing that could happen hooking the wires backwards. The dryer control thermostat is another animal entirely. The website I used to find the first model does not provide a wiring diagram. Their should be a diagram up near the timer tucked away in a jacket.
Tip
Blower motor does not work?
Blower motor problems are a pretty common topic. This is a basic guide on how to diagnose the problem and will work for most vehicles.
The diagram is generic and loosely based on GM's setup and more specifically a Silverado. Most manufacturers have a similar setup and the only major differences would be a ground side control (instead of the switch supplying power to the resistor it would be grounding the power from the resistor if this is the case you test light would need to be connected to power to test the switch) and late model Chrysler minivans (they use a module that looks for a difference in a/c voltage from the switch)
If the blower works on high only than likely the resistor assembly is the culprit since power to the blower essentially bypasses all of the resistors and/or the resistor assembly entirely. The reason why none off the other speeds will work is that the resistor or the circuit for the speed four setting has burned out. The lower the setting the more resistance you need to drop the voltage to the blower. The first speed setting requires all four resistors to drop the voltage enough to turn the blower at its slowest speed. Speed 2 needs to turn the blower a little faster so it uses three resistors. Speed 3 uses two resistors and speed 4 uses one.
In some cases the fan will work on high and speed setting 4. The likely cause for this is the speed 3 resistor or circuit has burned out. Speed 4 still works because it doesn't use the lower speeds resistors to control the speed of the blower. If the speed 2 resistor burns out than speed 1 and 2 will not work but 3, 4 and high will continue to work. If the speed 1 resistor burns out than speeds 2, 3, 4, and high will continue to work.
This leads us to how do we know if its the resistor or the switch or the blower. If the blower works on high than we know the blower works. That leaves us with either the switch or the resistor assembly (there are many other possibilities) which can be easily tested with a test light (or a voltmeter if you choose) The first thing to do is locate the resistor assemble. They can be behind the glove box, under the dash close to the blower motor or under the hood, again usually close to the blower motor. It will typically have 5 to six wires going to it. We'll start by unplugging the connector, turning the key on and connecting your test light to ground.
1.Turn the switch to high and backprobe all the wires. Two of them should illuminate the test light. In the diagram below this would be wire E & F. If you don't have a diagram then hold the test light on one of the two wires and move the switch to another speed setting. the wire that continuously illuminates the test light regardless of the switch position will be the constant power for high blower speed and will not need to be rechecked in the following steps.
2. Turn the switch to the next lowest setting. Backprobe the remaining wires to see if one of them illuminates the test light. Repeat until you have checked all of the speed settings.
3. If the test light has illuminated a different wire for each setting then we can reasonably assume that the switch is functioning as intended and the source of the problem is the blower resistor.
If you find one or more settings (but not all the settings) on the switch that does not illuminate the test light on any wire than we can reasonably assume that the switch has failed.
There are a few other things that can cause blower motors not to work as intended. The switch or the resistor assembly are the two most common problems.
on Oct 26, 2010 | Chevrolet Venture Cars & Trucks
NPS40 blower and ignitor always on - did i cross wires
i would suggest you call the manufacturer and ask for tech help asap
ask for them to send you the wiring diagram, it also should be on one of the covers or lid for the back of the unit. OR
http://homeappliance.manualsonline.com/manuals/mfg/napoleon_fireplaces/nps40_1.html?p=30
Jun 07, 2017 | Napoleon Auburn Pellet Stove Heater
Need to replace heater blower motor. How do I get to it?
Behind the glove box. Please see my tip at http://www.fixya.com/cars/r6234839-doesn_t_heater_or_air_conditioner_blow . These are generic instructions. If you get stuck, please get back to me.
See instructions from autozone.com below.
REMOVAL & INSTALLATION
With Air Conditioning
See Figures 1, 2 and 3
  1. Disconnect the negative battery cable.
  2. Remove the glove compartment door and glove compartment.
  3. Disconnect the blower motor wires from the blower motor resistor.
Fig. Fig. 1: Disconnect the blower motor wires from the blower motor resistor-1988 Escort
  1. Loosen the instrument panel at the lower right-hand side prior to removing the motor through the glove compartment opening.
  2. Remove the blower motor and mounting plate from the evaporator case.
  3. Rotate the motor until the mounting plate flat clears the edge of the glove compartment opening and remove the motor.
  4. Remove the hub clamp spring from the blower wheel hub. Then remove the blower wheel from the motor shaft.
Fig. Fig. 2: Unbolt the mounting plate from the case
Fig. Fig. 3: The motor can now be removed from the case
To install:
  1. If removed, assemble the blower wheel to the motor shaft and install the hub clamp.
  2. Install the motor and blower wheel assembly.
  3. Secure the instrument panel at the lower right-hand side.
  4. Connect the blower motor wires at the blower motor resistor.
  5. Install the glove compartment door and the glove compartment.
  6. Connect the negative battery cable.
  7. Check the system for proper operation.
Without Air Conditioning
  2. Remove the air inlet duct assembly.
  3. Remove the hub clamp spring from the blower wheel hub. Pull the blower wheel from the blower motor shaft.
  4. Remove the blower motor flange attaching screws located inside the blower housing.
  5. Pull the blower motor out from the blower housing (heater case) and disconnect the blower motor wires from the motor.
To install:
  1. Connect the wires to the blower motor and position the motor in the blower housing.
  2. Install the blower motor attaching screws.
  3. Position the blower wheel on the motor shaft and install the hub clamp spring.
  4. Install the air inlet duct assembly and the right ventilator assembly.
  5. Connect negative battery cable.
  6. Check the system for proper operation.
Nov 05, 2010 | 1989 Ford Escort
My 1988 Ford Tempo's heater fan is not working. I can feel heat at the windshield vents,but the fan wont come on. I have jumped the fan speed switch with a paper clip--and blew a fuse--and checked the...
your circuit is simple--I will paste it below. suspect the blower has shorted and caused the switch to burn up. remove the blower and hotwire it to the battery to see if it works. If not, replace the blower. Then run continuity tests on the swoitch and replace switch if bad. If you have questions, please let me know. Here is procedure for taking blower out:
REMOVAL & INSTALLATION With Air Conditioning
  2. Remove the glove compartment door and glove compartment by removing the retaining screws and bolts. Push the sides of the glove box in to free the drawer from dash panel.
  3. Loosen the instrument panel at the lower right hand of the glove compartment opening. This is on it necessary if the panel is in the way of the motor housing.
  4. Remove the retaining screws securing the ducting around the blower motor.
  5. Remove the clip securing the blower motor fan blade to the motor arm. Remove the fan blade from the motor.
  6. Remove the blower motor mounting plate from the evaporator case by unscrewing the retaining screws.
  7. Rotate the motor until the mounting plate clears the edge of the glove compartment opening and remove the motor.
  8. Remove the wire harness from the rear of the motor.
  9. Inspect the fan blade for broken edges or cracks. Replace if needed.
To install:
  1. Connect the wire harness to the rear of the blower motor.
  2. Install the motor into the case and secure with the retaining screws.
  3. Position and fasten the fan blade to the blower motor arm. Secure with the clip.
  4. Secure the blower motor outer housing to the duct assembly with the retaining screws.
  5. Install the instrument panel at the lower right hand side if removed earlier.
  6. Install the glove compartment door and glove compartment.
  7. Connect the negative battery cable.
  8. Run blower motors to make the motor works correctly.
  2. Remove the right ventilator assembly.
To install:
Oct 21, 2010 | 1988 Ford Tempo
How to replace a blower motor in a 1996 ford thunderbird lx
Removal
  1. Remove the glove compartment liner to gain access to the heater blower motor and blower motor wheel assembly mounting screws.
  1. Use a small screwdriver to remove clip retaining hydraulic damper strut.
  1. Remove four screws and remove the heater blower motor assembly and blower motor wheel assembly from the heater blower motor housing.
Installation
  1. Using a new seal, position the heater blower motor and blower motor wheel assembly to the heater blower motor housing with the flat side of the flange near the heater blower motor switch resistor (18591). Install the four retaining screws.
  1. Tape the heater blower motor power lead to the air inlet duct to keep the wire away from the blower outlet during installation.
  1. Install the heater blower motor and blower motor wheel assembly in the vehicle.
  1. Install the glove compartment liner.
Oct 07, 2010 | 1996 Ford Thunderbird LX
Our Frigidaire front load washer will not start. The door open buzzer just buzzes even though the door is shut.
This is usually caused by the door switch. These are fairly inexpensive and very easy to replace. First unplug your machine. To check you will need to remove the wire ring that holds the front door seal to the front panel. To do this go to the six o
Sep 08, 2010 | Washing Machines
Where is the blower motor... i know that is the problem, but where and how do I change it. i already have the part
Blower Motor Removal & Installation Front To Remove:
NOTE: The blower motor is positioned on the passenger side of the vehicle beneath the instrument panel, and can be removed from the vehicle without removing the HVAC housing.
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Passenger side cowl trim panel
    • Carpet to access the front upper screw that secures the air inlet housing
    • Recirculation door actuator
    • Recirculation door actuator wire lead from the routing clip located on the lower air inlet housing and position the wire lead aside
    • Blower motor wire lead connector from the blower motor resistor or power module, depending on application. Lower Air Inlet Housing chr_pacific_lwr_inlt_hsng.gif
    • One screw (from the top) that secures the lower air inlet housing to the upper air inlet housing
    • Four screws (from the bottom) that secure the lower air inlet housing to the upper air inlet housing and remove the lower HVAC housing Blower Motor Wire Lead Grommet chr_pacific_blwr_wrg_grmmt.gif
  3. Feed the rubber blower motor wire lead grommet through the opening in the lower air inlet housing.
  4. Push the blower motor wire lead through the opening in the lower air inlet housing and remove the lower air inlet housing from the vehicle.
  5. Place the recirculation-air door as needed to access and remove the three screws that secure the blower motor to the lower half of the HVAC housing.
  6. Lightly bend the recirculation air door far enough down to remove the blower motor and wheel from the HVAC housing. Blower Motor Mounting Tabs blwr_mnting_tabs.gif
  7. Remove the blower motor and wheel from the HVAC housing. Make a note of the location of the blower motor mounting tabs.
To Install:
  1. Install or connect the following:
    • Blower motor and wheel to the lower half of the HVAC housing and line up the blower motor mounting tabs to the correct location on the HVAC housing
    • Blower motor and wheel into the HVAC housing by lightly bending the recirculation-air door far enough down
    • Three screws that secure the blower motor to the HVAC housing by positioning the recirculation-air door as needed
      1. Torque to: 17 inch lbs. (2 Nm)
    • Blower motor wire lead through the opening in the lower air inlet housing and seat the rubber grommet into the lower air inlet housing
    • Recirculation-air door pivot into the lower air inlet housing
    • Four screws (from the bottom) that secure the lower air inlet housing to the upper air inlet housing and the lower HVAC housing
    • Blower motor wire lead connector to the blower motor resistor or power module, depending on application
    • Recirculation door actuator wire lead into the routing clip located on the lower air inlet housing
    • Carpet
  2. Perform the heater-A/C control calibration procedure.
Rear To Remove:
NOTE: The rear blower motor and blower wheels are repaired only as a balanced unit. The entire blower motor and wheel assembly must be replaced if either component is fault or damaged.
    • Front center floor console cover
    • Negative battery cable Rear Blower Motor Housing chr_pacific_rear_blwr_hsng.gif
    • Body wire harness connectors from the rear blower motor power module and the rear mode door actuator
    • Body wire harness bracket from the console support bracket
    • Eight screws and the two console support brackets from the floor console base and duct assembly
    • Four screws that secure the rear blower motor housing to the floor console base and duct assembly
    • Rear blower motor housing and place it on a bench
    • Rear blower motor wire harness connector from the power module
    • Eleven retaining clips and three screws that secure the housing together
    • Two halves of the housing
    • Blower motor wire harness and grommet from the housing and remove the blower motor
To Install:
    • Rear blower motor into the housing and install the blower motor wire harness and grommet
    • Two halves of the rear blower motor housing and install the eleven retaining clips and three screws
    • Rear blower motor wire harness connector to the rear blower motor power module
    • Rear blower motor housing into the floor console
      2. Two console support brackets onto the floor console base
      3. Eight screws that secure the support brackets to the floor console base
      4. Body wire harness bracket onto the console rear support bracket
      5. Body wire harness connectors to the rear blower motor power module and the rear mode door actuator
      6. Negative battery cable
      7. Front center floor console
  2. Calibrate the A/C-heater control.
Aug 13, 2010 | 2004 Chrysler Pacifica
Amana NDE2330AY Electric Dryer Logo
260 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
