Question about Dryers
My gas dryer heats but doesnt heat correctly, takes along time to dry the clothes
  • Dryers Master
  • 1,902 Answers
Hello
When the dryer wont dry clothes or won't heat at all it means that the issue is with the Thermostat/Thermal fuse that needs replacement as it has gone bad. Please check the thermostat for continuity as no continuity between its two pins states bad fuse. Please get back to me if you have any other questions.
Kevin
Posted on Nov 10, 2010
Dryer is running but doesnt seem to be heating it takes a long time to dry and the clothes are not warm when pulled out
Your ignition unit may be worn out and will need to be replaced. Generally, a heating element comes on and once it reaches a certain temperature, it ignites the gas pilot. Then the heating element cools off because the gas is now burning and producing heat. When this heating element stops working correctly, it will not reach the right temperature to ignite the gas. You'll need to have a professional perform the repair. If the dryer is still under warranty, this might be covered.
Check your owner's manual.
I really hope this solves your problem. If it does, please come back to Fixya and rate my advice
Jul 16, 2011 | Maytag Neptune MDG5500AW Gas Dryer
THE FIRST TIME THE DRYER STOPPED HEATING THE CLOTHES THE FLAME DIDNT KICK ON AT ALL. SO WE REPLACED THE HEATING FUSE AND IT WORKED FINE FOR 8 MONTHS. NOW THE HEAT COMES ON BUT DOESNT STAY ON LONG ENOUGH TO...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 26, 2011 | Whirlpool LGR4634J Gas Dryer
My dryer doesnt dry this is the 4th hr i have been drying a load of cloths it always takes toooo much time to dry. it is a lg dlex8377nm is there a setting on the dryer i should set on high? help!
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 11, 2010 | Dryers
It seems like the burners are not all lighting. Maytag Epic Z gas
heatman101
May 11, 2010 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Jun 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer takes long time to dry clothes
Remove the rear connecting vent and try a load at 45 minutes time dry. If it dries correct the vent blockage problem.
If not, let me know for step 2.
May 23, 2009 | Kenmore Dryers
Dryer heats up but does not dry clothes
first take the venting off the back of the dryer and dry a load if dryes normal replace venting if takes a long time to dry have a repair man clean the dryer
Jun 12, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
53 people viewed this question
Top Dryers Experts
