Question about Car Audio & Video
Need the code to turn the radio on - Car Audio & Video
  • Dave DeGain
    Dave DeGain May 11, 2010
    What kind of radio is it?
    What model is it?
    President:
  • 624 Answers
Do you still have the problem with needing the code? If so, please provide the needed information. If not, just ignore this post.
Posted on Oct 16, 2008
How do u set the code
If for a radio thats 2002 or older you will need the radio serial number in order to obtain the radio code. to do this you will turn the ignition on and the radio off. then push the 1 and 6 buttion at the same time. while holdting the buttons turn the radio on and u should show a code that begins with a U or a L. Write all numbers down. then contact the honda dealer for the code to your audio system. If you already have the code....do the following. Turn your ignition to ACC or on to power on thyour radio. Enter the radio anti-theft code using the prest buttons at the botton of your radio. For example, if your anti-theft code is 55512, "You would press the 5 button three times, then the 1 button, then the 2 button. this will unlock and rest your honda radio.
Sep 03, 2012 | 2006 Honda Accord
Please help me to get the code number to unlock the radio for honda crv 2003
    • 1 Look in your owner's manual booklet for your radio anti-theft code. The code is printed on a small card (similar to a credit card) and included with your owner's manual. If you can find the code, skip to Step 5.
      If you cannot find the code, you'll need to retrieve it.
    • 2 Turn your ignition off to begin retrieving your radio code. Press and hold the "1" and "6" preset buttons on your radio. Turn your ignition on.
    • 3 Write down the code displayed on your radio. The display will flash with two numbers: one beginning with a "U" and one beginning with a "L." Write down both numbers (beginning with the "U" number), and then disregard the "U" and the "L."
      This number (eight digits) is your radio serial code. You'll need it to retrieve your radio anti-theft code.
    • 4 Contact Honda to retrieve your radio anti-theft code. You'll need your 17-digit Vehicle Identification Number, found beneath the driver's side of the windshield and your radio serial code. Honda's customer service number is (800) 999-1009. Provide the representative with the information to acquire your radio anti-theft code.
      You can also retrieve your radio anti-theft code online for free at https://radio-navicode.honda.com/
    • 5 Turn your ignition to "Acc" or "On" to power on your radio. Enter your radio anti-theft code using the preset buttons at the bottom of your radio. For example, if your anti-theft code is "55512," you would press the "5" button three times, then the "1" button, then the "2" button. This will unlock and reset your Honda radio.
Oct 09, 2011 | 2003 Honda CR-V
Code wait, what doing
When you have WAIT showing on the display this means the radio has been asking for a code and too many incorrect code entries have been made. The radio is locked down because of this. This happens when the power has been lost to the radio and it needs a code to reactivate it.
When WAIT is on the display you must leave the radio turned on under constant power with the key in the ignition turned to accessories position on until the display turns to CODE or shows ----. You must leave the radio on for up to four hours with the power uninterrupted. The waiting period depends on how many incorrect codes have been entered.
The power to the radio must remain uninterrupted or the WAIT period will start all over again hence the reason why the key must be turned in the ignition to Accessories I
Once you have CODE or ---- back on the display you need to enter the correct code to reactivate it. If you do not have the correct code I suggest you go here and purchase the code from this website which is one of the few sites I know that can decode Becker radios online.
You need to send them the serial number of the radio and they will email the code back to you.
Hope it helps. Thanks for using FixYa.
Aug 16, 2011 | Becker Indianapolis Pro 7950 CD Player
Trying to get our Motorola (yellow/ black) to communicate with Midland two way radios. They Midland will receive messages from Motorola, but they can not send to it Motorola.
Most likely your CTCSS tone codes are not turned on on the Midland radios. The CTCSS codes are also known as "Privacy Codes" or similar.
They will be from 1 to 38. Your Midland manual will tell how to set the codes on the radios. The Motorolas usually show the selected tone code below the channel number.
Alternately, you may be able to turn off the tone code on the Motorola radio(s) by setting it to "0" or "off". Then you will not need codes turned on on any of your radios and they should all communicate fine.
Dec 16, 2010 | Motorola Walkie Talkies 2-Way Radio
Radio says off. need to put in code
Turn your ign. to acc. leave radio on to it clears, then you should be able to enter your code.
If you enter your code wrong three times the radio will shut off, if it dosen't take the code the first time, call your local dealer.
Pull radio have serial number and model. good chance radio was replaced and code wasn't updated.
Sep 26, 2009 | 1995 Volvo 850
The battery died on my 2001 eclipse, now the radio only says ''off''?
This is the anti-theft device on your factory radio. When the battery died, the radio thought it had been removed from your car and went into anti-theft mode. When you turned the car back on, the radio should have read "CODE" on the display, at which point you need to enter the factory anti-theft code. After 3 failed attempts at entering the code, it will simply read "OFF" and the radio is locked.
At this point:
- find your factory anti-theft code - it should be in your owner's manual, or you can contact a dealer to retrieve it
- turn the key to the ACC position (radio and accessories on, but engine is off)
- turn on the radio so the display reads "OFF"
- let the car sit for 1 hour
- radio will turn off automatically and reset
- turn the radio on again, and it should read "CODE"
- enter the factory anti-theft code
Make sure you have the code before starting the procedure. To enter the code, use the radio preset buttons. For example, if your code is "4321", hit Preset #1 button four times, Preset #2 three times, Preset #3 two times, and Preset #4 one time. Then hit the "Tape" or "CD" button. Radio should now be unlocked.
Sep 13, 2009 | 2001 Mitsubishi Eclipse
Radio reset code
Look inside your owners manual for a card that says Radio Code.When you find it, Turn on Radio, Code will be in display, Type in your 4 digit code in using your radio preset buttons.Your radio should just come on. If you dont have the code then you will need to remove the radio and take the radio to the dealer where they will take the serial number off the radio and then retrieve the code for you....
Hope that helps
Jul 09, 2009 | 1997 Saab 900
Radio codes
call near dealer with vin ready and ask for unlock code for radio ...:)
Dec 02, 2008 | 2005 Honda Element
T5900 Walkie Talkie Issue
Hello Bo Duke,
If one radio won't walk to the other my guess if that you have the Privacy Code function set up incorrectly.
The privacy code function mutes the radio unless it receives a signal from another radio transmitting the same privacy code. If Privacy Codes are turned on for Radio A but not turned on for Radio B then you will be able to transmit from Radio A to Radio B but not from Radio B to Radio A. If Privacy Codes are turned on for both radios but each unit is set to a different code then neither radio will be able to talk to the other.
Make sure that the radios are both set to the same privacy code or that the privacy code function is turned off on both radios. You can find more information on how this function is set in the radio's Owner's Manual.
Hope this helps!
Ken
"Go Ahead. Use Us."
Jul 02, 2008 | Motorola Walkie Talkie 2-Way Radio
How do I get my motorola T5725 radios to talk to eack other
Hell ssalah,
Most of the time when one radio cannot talk to the other radio it means that the Privacy Codes are not configured properly. In order for the two radios to talk to one another they both have to be set to the same channel and Privacy Code or the Privacy Code function needs to be turned off on both radios.
The Privacy Codes can be used to keep the radios silent unless they receive a signal from another radio using the same code. This enables the radios to be used on busy channels with a minimum of interference. If Privacy Codes are turned off on one radio and turned on for the other radio, the situation you describe will occur.
Consult the user's manual for information on the Privacy Code function and either disable the function on both radios or set both radios to the same code.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 14, 2008 | Motorola Talkabout T5720 (7 Channels)...
Car Audio & Video Logo
53 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
