Question about Kenmore Washing Machines
My high efficiency washer stops working about 5 minutes into the load and flashes F35. I have to unplug it and start over or unplug and turn to rinse and spin to finish the load.
  • 147 Answers
The level switch is no good
Posted on Nov 11, 2010
Kenmore High Efficiency top load washer hung in rinse cycle
What is the complete model number of your unit?
Dec 09, 2012 | Washing Machines
My 2 yr old kenmore high efficiency washer flashes F35 and stops. i have to unplug it and start it over, wasting detergent
this is a pressure swtich failure code and possible caused by to many suds.you should try and run the unit empty with no soap on the quick wash cycle this will help clean out any soap left over in the system.
If this continues to happen replace the pressure switch this is located under the lid and has a small rubber clear or black huse running to it.also good prevent maint.is to clean the drain pump area and coin cathch if it has one over time things will build up in the pump area and can cause a pump malfunction.
Nov 10, 2010 | Kenmore HE2 Plus Front Load Washer
Trouble code F 35 about 5 minutes into wash cycle. Unit stops dead.Will not respond to hitting cancel twicw as recommended in owners manual. Will work again if I unplug washer for 15 minutes and plug it...
F35 = ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
1. Check if pressure hose is fixed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
Nov 30, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
The washer stops and flashes f35 and some times
F35
This typically indicates slow drain condition. Check for any clogs or kinks in the drain line. Also check that the pump is not clogged and that no pump impeller blades are missing/broken and that the impeller moves freely. Any broken/missing blades or if the impeller won't turn freely will indicate a faulty pump. Hard objects can sometimes make it to the pump and cause damage. Hope this helped and best wishes.
Good luck
Oct 05, 2009 | Kenmore Elite 45986 Front Load Washer
I have a HE5t kenmore elite front loading washer. It has done great for about 15 months. We were away for about 3 weeks, and since we have returned, I put in a load of clothes, and it tries to start...
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*%^*
Aug 27, 2009 | Kenmore HE2 Plus Front Load Washer
F35 Sud errors
OK, you can't use regular Gain detergent in this washer. you will need to use the recommended (HE-High Efficiency) brand. its the only way to avoid the SUDS.
Jun 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F35 and suds it turns off after 5 mins and whenever I put it on rince only it still cuts off.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
May 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code F35
May 18, 2009 | Kenmore HE2 Plus Front Load Washer
F35 Message on Brand New Washer
suds is determined using the level sw located on top right rear side. remove top cover to see. most letter codes do convert to a f code. most common reason for suds error is use of standard detergent or too much detergent. running a empty load of fabric softener can clean the system. or rinse/spin with nothing. other common problem is this is a whirlpool product.
Dec 01, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
23 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
