Question about Panasonic Televison & Video
My TV keeps turning on at 3 am each morning and I'm not sure why. I typically watch TV every night up until around 10 and turn the unit off with the remote to go to bed. Unfortunately, it keeps turning on and waking me up. The only way to prevent it thus far is to get up and disconnect the electrical plug. However, this is getting annoying. I know it's not the cable box as I've switched the cable boxes and the problem continues to persist. In addition, I've tried to scan through the menu, but can't find any button/option to reset the overall metrics of the unit or even one that automatically turns the TV on. Any thoughts?
snakehead
  • 1074 Answers
SOURCE: Can't change Proline TV / Video combo to scart
visit www.partstore.com to purchase a originald remote for your set if they do not have it they can get it for you.good luck
Posted on Apr 08, 2007
SOURCE: black box in the center of screen
If the tv is an LG with built in sky then the tv is faulty.
Poor connections on microprocessor
Posted on Jan 16, 2008
  • 4234 Answers
SOURCE: Sony KV-30HS420 turns off all by itself
6 blinks is a horizontal sweep problem (I think). If the problem did not show up at the shop, I'd suspect bad connections that the move "corrected" for the short term. If you can solder, resolder any joints that appear grainy or have rings. Pay particular attention to the area close to the flyback transformer (part with large red wire coming out the top). Report back here with your results.
Dan
Posted on Apr 08, 2008
  • 71 Answers
SOURCE: Black Box on Screen
you have to turn OFF cc - closed caption - in the menu
Posted on Apr 29, 2008
ginko
  • 19396 Answers
SOURCE: VCR/DVD & Samsung TV: "weak or no signal"
Take the VCR remote, check VCR output settings ( scart1, scart2 , RCA) and signal format (PAL) etc
Posted on Jul 26, 2008
New lamp worked for 2 weeks, last night would not turn in so removed lamp thinking it was burnt to send back under warranty. Lamp appeared fine so reinserted and tv surprisinly turned on. this morning...
Edwin, sounds like you might be having a problem with your Ballast. The Ballast is what fires up lamp. Typically if this is an older unit, when you replace the bulb, you will have to replace your ballast as well. It is harder to fire up a new bulb, then it is to fire up an old bulb. That's why you wouldn't notice the problem until you changed your bulb.
Mar 01, 2014 | Panasonic Televison & Video
Faint picture screen
Press the reset switch to reset the garmin, is the backlight turned off in the settings or is it possibly faulty?
Oct 27, 2008 | Garmin StreetPilot c530 GPS Receiver
I awoke this morning to find the sound on my Apex Digital LD4088 LCD tv is dead. The picture is fine, but sound is dead, how do I solve this?
Download the user manual to your TV. Clik here to download it. See whether audio options to it are set right. If all are right, check its speaker. If speaker is OK, the audio output circuit section should be troubleshooted.
If you feel any difficulty in downloading the manual, send your email address to me. I'll send a copy of it to you by return mail.
May 16, 2012 | Apex Digital LD4088 LCD TV
Watching tv last night, the tv turn off by itself with out touching remote control, after that i keep trying to turn it on and the on/off red tv light startted flashing for a few minutes until it when off...
It can Have one of 2 Troubles, The Inverter Board is Defective or the Power Supply has bad Capacitors. I found 3 Capacitors known to go bad in that set. Replace the 10 Volt Capacitors with 16 Volt Caps and they will last forever.
Oct 07, 2010 | Samsung LN40A450 LCD TV
Tv wont turn on< red power light just keeps blinking?
I have the same thing. Just started blinking 10 times. Pretty much had to unplug the unit over night. Could never turn it off and then turn it on again.
This worked for about a week. This morning, tried to turn it on after being unplugged. Still blinks.
Called Panasonic. they attempted a couple solutions, nothing. Suggested authorized repair shop.
Aug 20, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Last night the tv was fine i turned it on this
Unplug 20 minutes. Make sure there is adequate ventilation around the set.
Try with the original manufacturer remote to view setup menu.
Power outages come at night. This sometimes resets the TV and other devices. .
Mar 25, 2010 | Insignia 42" LCD Flat-Panel HDTV
37MF321D/37 TV turned off last night. This morn, won't turn on
Please read these replies to the same problem. A new power board costs around $284.00..
http://www.fixya.com/support/t465280-magnavox_37mf321d_37
Jan 01, 2010 | Philips Magnavox 42MF521D/37 Television
Panasonic PT-53TWD63, TV will not turn on, Red power light blinks
It is most deffinately a convergence chip issue. The die for no reason. They can be bought online for around $10 dollars and anyone with experience with soldering can replace them pretty easily. I have done it.
Feb 03, 2009 | Panasonic PT-53TWD63 53" Rear Projection...
Bad picture on Toshiba
this is a malfunction vertical deflection block of your TV-set .please contact the nearest repair shop.do not turn it on until then,please.
Apr 17, 2008 | Toshiba 36A40 36" TV
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
