Question about Kohler Home
Our Kohler bathtub is leaking water under the tub. We think the rubber ring in the drain needs to be replaced, but we have no idea how to remove the drain, or where to buy a new one, or how to install a new one. Help!
  • 718 Answers
The drain portion of your tube is fort he most part universal, go to the local Home Depot or Loews and ask some questions sometimes they even have samples set up on boards in the plumbing dept you can look at. Get out there! Good Luck
Posted on Nov 10, 2010
K-1357 kohler whirlpool tub there is leaking only when the tub is filled and drained. when taking showers there are no leaks 3yrs old
Overflow? Seal around drain may be good enough for shower, but leaks with a little more pressure from the filled tub. Filled tub may flex the tub and drain components. What about the overflow. I bet some water is going over, but it isn't used for showers. Double check. Paper towels tied in stratigic locations always help me find a leak. Leak makes the towel soak up water nearby. It's most wet at the point of leak.
Mar 08, 2015 | Kohler Home
The tub drain is installed but it is leaking around the flang not the stopper itself? i am assuming it is leaking outside the drain ? which appears to be in the room beneath it.. 2nd floor tub.... Do...
If it is leaking from around the flange then you will need access to the under side of the tub drain to 1) tighten the drain connection or 2) replace the tub drain connection or 3) remove the drain, clean it and replace it again properly with the rubber washer and plumbers putty.
Nov 06, 2010 | Home
Galbocca jacuzzi type tub with plug that won't hold water in the tub.
Remove plug fitting and reseal or someone forgot to install the rubber washer.........Silicone and replace because the water is leaking through..Hope this helps.
Aug 11, 2010 | Whirlpool Hydrosystems 72 X 36 Biscuit ...
Bath tub leaks
Well if its not from drain then it could be from one of the supply valve (hot/cold) it is also possible that its leaking from the overflow drain. this gets overlooked sometimes because of its location. One thinks that water has to be filled that high but one might be surprised how much water gets there when taking a shower or splashing in the tub. There should be an access panel to check the valves and overflow gasket. If not remove the handles and echuns to see if you can see anything.
Mar 31, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Leaking form shower facet also leaking from
id say your tub spout or shower pipe is leaking and running down behind remove both and replace teflon tape see if it stops
Mar 14, 2010 | Home
My bathtub drain leaks. Is there a product to
No, not without sealing, I mean clogging, the drain. Do you know exactly where the leak is coming from? I would suspect that the water is getting around the drain, instead of down the drain. The visible part of the drain should unscrew from the part that is underneath. That bottom part is likely permanently sealed to your drain plumbing.
You may be able to easily fix your leak by:
#1 Unscrewing the visible drain top.
#2 Replacing the washer under that top. This will seal your tub to your drain. All water will then be forced to flow down the drain properly.
#3 Screw the top of your drain back into place WITHOUT folding or wrinkling the new washer.
Good luck
Jan 03, 2010 | Kohler 1221-H-0 Seadream 6' Whirlpool Bath...
My 2000 kohler tub drain leaks. The drain itself
Need clarification....the drain leaks to the ceiling below, or it doesn't hold water? If it doesn't hold water, no need to replace the ring. Those can be adjusted. Simply pull up on on the lever and screw it in clockwise. This will lower the stop and hold the water. If it actually leaks below, unscrew said stopper, grab a pair of needle nose pliers and place them in the drain (to grab the strainer) and use another pair to loosen. Once off, clean around drain and clean strainer, apply plumbers putty to the strainer, apply pipe "dope" (thread sealant) to the threads and tighten back in. Good luck!
Nov 25, 2009 | Kohler 1107-R-0 ProFlex Bath Tub with...
Install bathtub without existing drain
it is generally not allowed under the water regs to discharge waste water into anything other than a drain.I would suggest you install a discharge pump, typically the saniflow type which will allow you to run the waste across the room and discharge the waste into the vanity basin drainage.Should you choose to install this be aware of the waste pipe configurations shown by the instructions
Mar 20, 2009 | Kohler Overture 5ft Vikrell Bath -...
Bathtub leakes when the drain plug is activated, no leak when not
This usually is caused by a detiorated O ring that compresses to make a watertight seal at the transistion points from them drain shoe and overflow tube to the trap adapter. However it may be the trap adapter as well. Either way the best solution is to access the tub waste from the wall behind the tub drain and replace the necessary parts. Your issue is showing up because the gallons per minute/hour rate that the tub drains is far greater than the tub valve is allowed to fill the tub. This causes a greater volume of water to fill the tub waste and as such the backpessure is greater as the entire volume of water in the trap weir must be evacuated as opposed to when the tub is not plugged and the valve is ran requiring the trap weir to evacuate gradually. Some tub wates are made of metal and may have developed holes in them but they generally form along the pathway the water uses to drain. Unfortunately the only real solution is gain access to the tub wate and replace the defective part. Thanks for using Fix Ya.
Mar 10, 2009 | Kohler Model 7202: Drain For Purist® Baths...
Home Logo
248 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
