Question about Car Audio & Video
Removed radio to work on AC now the radio won't functoin. CD and MP3 works
  • 1 more comment
  • willnway Nov 10, 2010
    not a fix, same problem
    antenna and ground connected, speakers work, cd and mp3 works, radio acts like no reception, speakers work. antenna is intact
    Acts like antenna problem, everything intact, when playing radio gets static and feint signal. does this radio require reset paremeters
  • 2,427 Answers
Did you connect an antenna ?????
If so, then take a graound wire from the radio and connect it to the the outer (metal part) of the antenna jack, or antenna itself, some antenna's require a chasis ground of the car.. In this case sub that with the ground of the radio itself..
Posted on Nov 10, 2010
  • Rishi Roshan Ali Nov 11, 2010
    well there inst really a reset perimeter, The only thing I can think off is reception !!!
    There are 3 FM bands ?? try each one and try repositioning the antenna until you can get a clear signal.
Radio will not work on AC
check ac wire & its connecting jack,then step down transformer
Apr 19, 2014 | Dewalt Dc012 Worksite Radio With Built-In...
I am getting an error read on my CD player. The CD Disc CD player (original) to my 2003 Experdition will not release CDs. The CD player which is an automatic feed was force fed a CD by a minor child. The...
The unit can be removed but disassembly will be required to remove the OFFENDING CD. Even at that, the player mechanism may have been damaged so that CDs simply cannot be played at all
Jan 28, 2013 | OEM 2002-2004 Ford Focus Factory AM/FM...
My FM radio won't work on my MP3 player
have you tried to power off and power on , is your location frequency friendly
Jul 26, 2012 | Coby Audio Players & Recorders
1999 toyota 4runner radio works but cd player won't read cd
I am having the same issue! How did you resolve your problem?! ANY advise would be greatly appreciated!
Jun 02, 2012 | 1999 Toyota 4Runner
I have the Sony S2 Sports ZS X1 and it will not turn on.
Before confirm transformer fault, load batteries and see whether it works. After loading batteries, pull out its AC cord from its AC socket at it back side. With AC cord connected at the back of the set, battery supply won't connected to the set. There is a cut - off switch at the AC socket. Only after removing the AC cord, the set will work on battery.
Try this. If it works with battery, make sure that transformer or internal mains fuse has blown out.
May 29, 2012 | Sony S2 Sports ZS-X1 Radio/CD Boombox
Why won't my 2003 Honda Pilot won't read my cds?
For Radio related problem,the help links are below.Click the link below to go through its procedure:-----Car radio works but CD player not working? http://technoanswers.blogspot.in/2012/02/car-radio-works-but-cd-player-not.html-----------How to reset Radio code after car battery is died?
http://howtobyme.blogspot.com/2011/12/how-to-reset-radio-code-after-car.html
------------- Can car radio code block Passkey anti theft system ?
http://schematicsdiagram.blogspot.com/2011/12/can-car-radio-code-block-passkey-anti.html
How to wire new car Radio?
http://schematicsdiagram.blogspot.com/2011/12/how-to-wire-new-radio-on-1990-toyota.html
Radio Stereo Wiring Diagram?
http://schematicsdiagram.blogspot.com/2011/12/radio-stereo-wiring-diagram-for-1991.html
How to remove radio on Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-radio-on-acura-car-models.html
Where is Radio Fuse located?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radio-fuse-located-on-2007.html
----------- After Market Stereo wiring?
http://schematicsdiagram.blogspot.com/2011/12/after-market-stereo-wiring-for-1999.html
car radio doesn't allow to switch to the XM Band to get the radio ID?
http://schematicsdiagram.blogspot.com/2012/01/chevy-car-radio-doesnt-allow-to-switch.html
No power to radio Scion Xb?
http://repairhelpcenter.blogspot.com/2012/01/no-power-to-radio-on-2005-toyota-scion.html
Radio has power but no sound?
http://repairhelpcenter.blogspot.com/2012/01/lexus-rx330-radio-has-power-but-no.html
Radio goes ON and OFF while driving?
http://technoanswers.blogspot.com/2012/01/radio-goes-on-and-off-while-driving.html
Town Car Radio stereo wiring?
http://technoanswers.blogspot.in/2012/02/lincoln-town-car-radio-stereo-wiring.html
Radio wiring diagram for Car?
http://technoanswers.blogspot.in/2012/02/radio-wiring-diagram-for-1997-lincoln.html
How to remove cd player from dash?
http://technoanswers.blogspot.in/2012/01/how-to-remove-cd-player-from-dash-on.html
This will help.
Thanks.
Mar 05, 2012 | 2003 Honda Pilot
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
Works on batteries. does not work on ac. If you leave cord in it and turn off ac it still will not work, but if you take cord out of the unit it will then work on batteries.
If the AC cord can be removed from the back of the radio, then there is a mechanical lever inside where the AC cord plugs into the radio. That lever will cause the battery connection inside to be open (or disconnected) so that it will run off AC and not blow up the batteries. That is why it won't run on batteries when that cord is plugged in.
If it runs on batteries but not AC, find another cord to try. Most radios use about the same cord. If a second cord still doesn't make it work, it's most likely a fuse inside for the AC circuitry. they are usually mounted on a circuit board inside the radio right near where the AC cord plugs into the radio.
You should be able to take the radio apart (while it's unplugged from AC of'course) and find that fuse. If your good with a soldering iron you can replace the fuse. Replacements can be found at Radio Shack. If your reading these instructions to begin with, your probably not good with a soldering iron and you should just buy a new radio. Good luck.
Nov 26, 2009 | Durabrand CD Player with Cassette...
Radio, dome lights and EVIC power problem
I found a paritally blown fuse. When the fuse blew metal pieces ended up partially making contact. After replacing the fuse everything worked great.
Jan 07, 2009 | 1994 Jeep Grand Cherokee
Car Audio & Video Logo
14 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
