Please i need a manual instruction for samsung bio vision model cs 72 02 z to set channels
How do i tune my SAMSUNG PS42S5H for high definition channels
Does this model of TV have a built in HD receiver? I've had a quick look at the instruction manual and it looks more or less the same as mine at home. I've not got HD tv reception built in but have to use a set top box. If you're in UK, it should have Freeview HD sticker from the box or manual somewhere but as this looks like an early model tv (only 1 HDMI socket) then you may need a HD set top box such as Sky HD or Freeview HD
Oct 15, 2014 | Televison & Video
Does anybody know how to get the total milage on the vision t9500 deluxe treadmill? it is a 2007 model.
please go to www.iconservice.com and download your owner manual for instruction about the how many total milage.
God bless you
Aug 23, 2013 | Vision Fitness Vision T9500 Deluxe...
How to unlock a dell desktop? It's locked from my bio .
What is the exact model of your Dell Desktop?
Usually for Dell Desktop system, you can reset the system bios to defaults and that depends on the exact model of your system.
There is a jumper on board that you can reset the bios settings.
Let me give you an example on how to clear the password and clearing the cmos settings.
Please visit http://support.dell.com/support/edocs/SYSTEMS/xps630i/en/OM/HTML/clearing.htm
You can also get the exact manual for your system, just visit Dell support site http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?c=us&cs=19&l=en&s=dhs&~ck=anavml
Jun 09, 2010 | Dell Computers & Internet
Mtisubishi TV (CRT), Model CS-2610R
that is because you do not have the correct input connected or the set needs to have a channel program redone
May 16, 2010 | Televison & Video
I need the code for unlock my tv, please help me with that.
I think you mean the parental control lock. You can bypass this added feature, or disable it completely by following the instructions in the appendix (page 84) of the owners manual.
You can find the manual by clicking the link below
Download Mitsubishi CS 31305 Owner Manual
(the guide is correct for your model number- its a catchall for other similar models)
Hope that helps
Dec 06, 2009 | Mitsubishi CS-31205 TV
I need an instruction manual for a 880x Samsung digital camcorder I purchased this camera and used it one time and put it in my case and now I can't find my instructions. I am a total loss on how to...
what is the model number of the unit?
it usually starts with SC-******
http://www.samsung.com/us/support/download/supportDownMain.do
you can enter the model number here then look for the manual to download
Jul 02, 2009 | Samsung Cameras
How do you replace proprerly a CD/DVD Drive?
HI there
I belive what you have done is ccaused a conflict on the ide channel that the dvd is on you should check the jumpers on the back of your new device and match it with the setting from your old cd.
you have three options master , slave . or cable select (cs) you can only have one master or one slave on each ribbon cable .
by what you are saying the second device on that channel must be a hard disk if you dont have your old cd drive check what the hdd is set on ie master then set your dvd to the oposite ie slave .
if your hdd is set to (cs) then also set your dvd to (cs)
this should get you going
Regards Al "alstech"
May 25, 2009 | Computers & Internet
How do you set a samsung ide hd to master mode
To set a Hard Disk to master mode is quite simple. On the side of the Hard Disk that has the power hook-up and data hook-up, there is also a small section of usually about 8 little prongs, and you'll see something that looks like somebody stuck something on those prongs. It is called a jumper, and it can put the hard disk in various states such as Master, Slave, Cable Select, and more. You usually cant use a hard drive without a jumper, so don't lose it. On either the top or bottom of the HD, there should be various information about the HD. You should also see a diagram of about 8 squares, just like the 8 prongs next to the power and data connections on the HD. Find the one for Single or Master, switch the jumper to the position it tells you to, and you'll be all set!
Apr 13, 2008 | Computers & Internet
Samsung CS-7277PF TV - Set up is locked
Samsung CS 7277PF TV SERVICE MENü IN?
Mar 18, 2008 | Televison & Video
Televison & Video Logo
193 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
