Question about Marley HBB1004 Electric Baseboard Heater
Our hbb1004 heater is making a ticking noise. What is the solution to make the heaters quit ticking?
  • 557 Answers
It may be a normal sound, metal expands when heated
Posted on Nov 10, 2010
Hi I turn the heat on in my 06 dodge magnum I hear a ticking noise then goes away now no ticking noise and no heat
Could be your blend door getting stuck thats making that ticking noise. Check your heater hoses to make sure they are getting hot. Check with caution theu may be very hot.
Jan 02, 2016 | Dodge Cars & Trucks
Kenwood oil filled heater timer starting making a ticking noise. Is there a way to fix it?
Most of these model are not repair able but seems like thermostat problem
Feb 03, 2015 | Kenwood Heating & Cooling
Won't stop ticking!!!! Why??
The noise could be from the expansion and contraction of the metal from heating up and cooling down. You could try loosen the mounting screws of the unit slightly to see if that helps.
Dec 14, 2012 | Williams (5009622) Ceramic Gas Wall...
Flame effect electric fire loud clicking noise
You need a new synchronous motor. This is the small motor which turns the flame effect rod. They are notorious for becoming noisy.
Nov 06, 2012 | ACE Dimplex (r) Compact Electric Fireplace...
My electric baseboard heaters make a pinging sound which drives me nuts when I am trying to sleep! Any suggestions other than changing the unit? Thanks
Electric baseboard heaters heat by radiant heat. This mean the heater is heating the metal of the heater first which causes expansion of the metal. This will cause popping metal sounds becouse it is heating up. When it kicks off, by the thermostat, it starts to cool which causes contraction of metal. This will also cause noise. Most all base board heaters I have installed and worked on does this. Sorry there is little to nothing you can do. :)
Jan 25, 2011 | Marley HBB1004 Electric Baseboard Heater
My 500 Watt Electic Baseboard heater ticks all the time, what can I do to stop this. Thank You
More than likely, the ticking is caused by the heating element ... expanding and shrinking as it gets hot and then cools off. You might get rid of some of it if you will gently lift the element and insert a small piece of fiberglass between the element and the element rest. If this noise annoys you ... maybe you can turn the radio up? :-) Don't use any other kind of material for this job.
I hope you find this suggestion helpful ...
Thanks for your interest in FixYa.com
Nov 27, 2010 | Marley HBB1004 Electric Baseboard Heater
98 Saturn SL2, AC/Heater Clicking
You need to replace the heater/AC blower motor the motor shaft bearing is defective..
Jun 18, 2017 | Saturn SL2 Cars & Trucks
Ford ka blows hot air even set at cold
sounds like heater control valve situated under scullle panel common fault on ka set heater fan switch half way between hot and cold with heater blowing then touch valve if pulsing or clicking noise it is faulty if doesnt solve problem faulty switch
Jun 07, 2009 | 1999 Ford Taurus
When engine is started, heater door makes clicking noise for 20 seconds and quits. When engine is shut off, heater door makes clicking noise for 20 seconds and quits. Door makes clicking noise when heat is...
Your air temp control blend door actuator is failing, that is the part u call a heater door, it is a gear driven miniature drive, the gears are jumping teeth making the noise, it will stop working very soon.
Apr 24, 2009 | 1998 GMC Blazer
Marley HBB1004 Electric Baseboard Heater Logo
165 people viewed this question
Top Marley Heating & Cooling Experts
Paul Carew
Ron Durham
Are you a Marley Heating and Cooling Expert? Answer questions, earn points and help others
