Question about Home
Change a tap washer - Home
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 135 Answers
Turn off water at wall valve under sink. Turn on tap to ensure valve is shut off. Remove tap handle. Remove cap, collar or bushing holding shaft in place. Shaft may need to screwed out to remove. Replace washer on end of shaft, then re-install parts in reverse order.
Posted on Nov 11, 2010
How to stop a driping tap
Try to follow these two you tube videos and see which one applies to your style of faucet.
Good luck.
How to change or tap washer to stop dripping tap or replace the type of...
How To Fix Dripping Tap Washer Change Plumbing Tips
Aug 05, 2014 | Plumbing
Changed the washer, turned tap and dishwasher on but water won't go through to dishwasher
Might be better to check if the water is coming out of the tap. Also confirm if you are getting any error code on the dishwasher.
Feb 06, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
How to replace inside tap washer in Australia?
To replace your tap washer follow these instructions or watch the video on this link http://youtu.be/kYHq4Jh2-3Q
How to Replace Tap Washer - Australia
Turn off your main water supply before you start.
Turn tap to on position.
Remove tap bonnet
Remove spindle.
Remove worn washer.
Install new washer.
Reinstall spindle.
Reinstall tap bonnet
Turn tap to the off position.
Turn your mains water supply back on
Aug 02, 2012 | Washing Machines
How do I change the washer on a Rotec Supertub tap
Those taps are fairly hard to remove, so you'll need a big crescent spanner to remove them. I have had the same leaky tap on our supertub, but have found replacement tap washers unobtainable here in Blenheim. Please let me know if you can find any.Regards, Tom
Nov 22, 2011 | Washing Machines
The rinnai 20 Infinity is perfect but have recently noted a problem. I found the basin hot water tap in the bathroom begin dripping only when the kitchen hot water tap is turned on. I don't know how...
Some taps are designed to release excess pressure but it could just be a dodgy tap washer that leaks when the pressure of hot water in pipe work builds. Change the tap washer in your tap, see if it fixes it, if not it's just the design.
Jul 02, 2011 | Water Heaters
Dripping from mixer tap in kitchen
This is a failure of the washer in the valve of the mixer tap. You can remove most of these to change the washer that is worn out. However even if the valve is faulty with a worn out thread the tap can leak.
Use the correct tool to remove , model not mentioned .
Jan 24, 2011 | Garden
How do I change a tap washer in aTechnika mixer
It may not be the washer the head gear may be faulty, sometimes if you remove it and clean it with some wire wool it works again.
Jan 01, 2010 | Computers & Internet
Do we need a Y connector for our combo washer dryer. We just have one tap in the kitchen sink
If you use a Y connector to provide water to the washer it will not be able to use different water temperatures. The water temperature at both the cold and hot inputs will be whatever comes out of the tap. The washer controls cold and hot inputs separately to change teh water temperature in the machine. A Y tap will only provide one temperature (whatever the tap is set to provide) to both inputs. If the tap is a faucet you could control the temperatures manually but the machine needs to have a water supply at both of its inputs.
Dec 08, 2009 | LG WM3431H Washer and Dryer
Change tap washer
hi first turn of your water to the tap open the taps to empty water your mixer tap con now be pushed down and twisted to come out
Nov 10, 2009 | Home
Home Logo
1,003 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
