Question about Vivitar V3000 35mm SLR Camera
Bought a vivitar v3000s the light meter is stuck on positive and i have cahnged the batterys
2 Suggested Answers
cammedic
  • 667 Answers
SOURCE: No light meter on Vivitar V3800N
It may be that the batteries that came with the camera are dead. Double check the way you have them installed, both cells should have the positive side up as they sit in the cap. It is best to handle button cell batteries on the round edges rather than the flat sides. The battery cap for your camera should have open slots on the sides so you can place the batteries in using those openings
Posted on Feb 02, 2010
While I was charging the power chair all the indicater lights came on and with a block lights went from all green to 2 red flashing lights, w/ 2 red lights flashing I stopped and shut it off 4 five se
Two red lights blinking means the electronics on the chair think the batteries are low. Test the voltage on the holes marked 1 and 3. Hole 1 is positive and hole 3 is negative. Your meter must be set on DC volts and the meter leads must be in Common and Volts. If your meter has to have the voltage range set, put it on 200vdc. The red lights will blink if the voltage is approximately 22.5vdc or less. The green lights turn on about 24.5vdc or higher.
Sep 18, 2014 | Invacare Pronto M51 Power Wheelchair
Nikkormat 35mm SLR light meter not working!
1) Clean the battery contacts and put fresh battery.
2) Open the top cover and clean the meter switch ( located and the wind cam )
3) Meter needle maybe stuck at the rest position. Remove the stopper and replace or clean.
4) If none of these help, check the meter cells and resistor band under the shutter dial behind the lens mount ( hard to do.)
Jun 14, 2010 | Nikon Photography
Feb 01, 2010 | Vivitar V4000 50MM 35mm SLR Camera
Just bought a 2001 vs800 intruder,got it home and will not start
If you're getting no lights then it is either the ignition switch or the battery is not making connection. Check the battery with a multi-meter. Check the fusebox with a multi-meter, any power to any fuses there with key on?
Jun 16, 2009 | 2000 Suzuki VS 800 Intruder
Light meter on my vivitar v335 ( film) doesnt show up
If there is supposed to be one in the camera, you may need to install/replace a battery.
May 29, 2009 | Vivitar V4000 50MM 35mm SLR Camera
Vivitar v3800N battery holder missing
rcv7,
this camera has at least two different names that i know of (phoenix, vivitar ) .The battery covers are the same.
most camera repair shops have repair manuals with part numbers from the manufacturer. the only other way is to take a cover to a machine shop and have them make some from aluminum. we had this done for the pentax spotmatic when parts were no longer available.
Jan 14, 2009 | Vivitar V3800N Zoom 35mm SLR Camera
Film = no light meter
jackson rook,
the speed of the film may be to high if your camera has dx coding contacts in the film chamber. otherwise---- film in camera or not it has no effect on meter operation. move the advance lever to the right slightly and push down on the shutter release button slightly to turn meter on.
Sep 10, 2008 | Vivitar V4000 50MM 35mm SLR Camera
Vivitar V3000 35mm SLR Camera Logo
57 people viewed this question
Top Vivitar Photography Experts
JP Services
JP Services
JOHN TOPLISS
Jax Planet
Jax Planet
Are you a Vivitar Photography Expert? Answer questions, earn points and help others
