Question about Miller SPECTRUM 1251 907305-01-1 PLASMA CUTTER NEW
I need to know if the power reset button is the on/off switch. If that is the case, then I guess my problem is the PC1 board.
Swapped my ma785r board to a new case and need the pin layout for power switch and reset switch
ok i dont hqave it but as i buld a lot of used pcs and new ones its usaly goes like this there is a 9th pin and a tenth one missing next to and in a straght line down the way nest to where the missing pin is is the on of under it is the reset pins next to the reset one is the hdd led and that leaves 1 set of 2 pins left if you want e mail me and ill draw a diagram for you hope this helps
Mar 17, 2010 | Computers & Internet
NO PICTURE ON MY LG 42 PC1 D PLASMA
Very probably a fault in the sustain board or possibly the control board. You would need to remove the rear cover & check what voltages are present on the sustain board coming from the power supply. It would be best to call out an engineer to give you an assessment of the problem
Dec 01, 2009 | LG 42PC1R 42 in. Plasma HDTV
How do i plug in power button in on mother board? Lost my manual so I can't find the model #. I was just switching my mother board and all other hardware to new case and my power button (or switch or...
> power led,
Runs to the LED (Light Emitting Diode) labelled "power" on the front of your computer-case
> H.D.D led,
Runs to the front-panel LED that lights-up whenever the Hard Disk Drive is being used.
> reset sw,
Runs to the "reset" button on the front panel.
> speaker
Runs to the internal speaker
> s/b sw
Very briefly touch a metal-tip screwdriver between these 2 pins.
If the computer powers-on, you've found the "power" connector.
Nov 06, 2009 | Intel Motherboard
No pwer
check conections, did you isolated bolts while you ware inserting mother board? check condensators on mother board if there are some leeks... if this is the case ,,, buy a new mother board? is mother board new?
May 02, 2009 | Asrock K7S41GX Motherboard
Computer Case ULT33180 Powers down about 4 seconds after started
Ive done something similar, I took the CMOS battery off the motherboard and put it back in after about a minute to reset the bios. Unplugged the power supply from the motherboard and flipped the power switch on the back of the power supply (on and off a few times) and plugged the power connector back onto the motherboard. I know it sounds like an odd way of fixing this problem but has worked for me.
Jan 03, 2009 | PSA E-Torque (ULT33180)
How to connect front pannel
How about a picture? Pg. 46 in your manual.
Need manual, download from Intel. (Click on link).
http://www.intel.com/support/motherboards/desktop/RC440BX/sb/CS-013608.htm
Intel RC440BX Specification
Pg. 46
Basic rules case wiring. The color black is considered ground -. Power wires + can be any other color including stripped wires. (This is standard but case Mfg change to their own specification).
Pin 1 is + power for LED Hard drive green LED, Pin 2 is -/ground for Hard drive LED.
(Pin 3 is + power for LED Hard drive yellow LED, Pin 4 is -/ground for Hard drive LED).(See more options on pg. 47).
Pin 5 is + power for case On/off button, Pin 6 is -/ground On/off button.
Pin 7 is + power for Reset Switch, Pin 8 is -/ground for Reset Switch.
Once positive & negative pins has been located each connector follows in suit.
The Intel RC440BX front case connector is in an odd location.
The user will find it hard to connect front case LED connectors while the board in installed into the case.
Good Luck!
Mike
Apr 25, 2008 | Intel Desktop Board RC440BX...
Power Switch for this PC?
I've read your question & am still confused about which switch you need. I'm guessing that it's the power switch on your case that is broke? If so you can go to just about any auto parts store & buy a push-button two wire off/on switch. Even in a Low's store. It may or may not fit just perfactly on your case but it's better then turning the power off with a pen directly off the motherboard. Been down the road your on. It's either this or buy another case. You will not find your case a new switch. You can use your case's wiring connector to plug into the board listed on pg. 1-18 in your manual. It's two pins. You can splice the two pin connector from your case to a new switch's wires. As far as connectors go. You can buy a small pack of single connectors for a computer from radio shack to connect to the boards (power) ATX power switch. All the parts shouldn't cost you more than $10.00. Cheeper than a new case!
Feb 15, 2008 | ASUS A7V333-X (A7V333-X/L) Motherboard
Ef3116 has different up and down speed.
PC1 may have a defective NIC card. Also, verify that PC1's NIC card is using an up-to-date driver and that it's interface speed and duplex settings are set to auto-negotiate.
Jan 09, 2008 | Linksys EtherFast 3116 Port 10/100...
No power
No Power "Whatsoever"
I Followed all the instructions in aarrowgant post
when I got to the fuse I removed it and checked it with
my ohm meter, and guess what it was not blown!!!
I used a can of gas duster to blow out unit.
I reassembled the projector except for the top of case and
plunged it in "No Power" I disconnected The power
There is however a small thermal switch I Noticed mounted
on the front of the lamp housing only accessible with the case
top off, It has a small red plastic reset button on it. I dusted
this off and pushed it. pluged it back in and the power light came on followed by the projector powering up. I reinstalled the top and mounted projector back on ceiling. Working fine now 48 hrs.
This entire proceeure took me 2 1/2 hours and cost me nothing.
Good Luck,
cyberphx
Nov 05, 2007 | Sharp XR-10X Multimedia Projector
Miller SPECTRUM 1251 907305-01-1 PLASMA CUTTER NEW Logo
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Jose Velazquez
Jose Velazquez
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
