Question about Whirlpool Whispure 510 Air Purifier
I have a Whispur 510. But the dog knock it down (face down). I think there are two plastic hooks insiside the front cover and one is broken. Where can i order a new front conver ? Thanks very much ted
  • 4,323 Answers
Hi
You can buy the front cover for your Whispure 510 from this link---
Whirlpool Whispure 510 front cover
Part#6--
Hope this helps... Please post back if you need more information.
Daniel
Posted on Nov 10, 2010
Will not operate, no reaction when power button pressed. All panels properly locked.
first off does the light come on at all? when the switch is moved to the High Medium or low setting do you see a red light or a green light on the right side of the unit? if there is no light at all, then there is either no power and you have a bad cord or a bad outlet. The only other thing could be the switch that needs to be tripped in order to let the unit run, that switch is closed by the front cover locking in place. that switch could be bad or your cover may have the tip of the pin that pushes the switch closed broken off or deformed and not pushing down enough to close the switch. try pushing a screwdriver down on the switch and see if it comes on. There's nothing that can shock you if you push on that switch, the power wires are concealed inside a plastic covered area that the switch slides into. If you close the switch and it doesn't come on the check the power cord or the wall socket for power. See if the cord has any unusual looking spots or lumps, stretching, cuts or anything that looks suspicious.
Apr 06, 2015 | Oreck XL Professional Air Purifier
Machine doesnt turn on. Is there a reset
Check the screen to make sure the plastic piece is depressing the switch at the bottom...the machine will not activate to on if this switch is not on..and depressed by the plastic piece on the Flair SCREEN.
Apr 29, 2012 | Ecoquest Flair Air Purifier
How do I change the filter on the Kenmore 335?
According to the Owners Manual, here's what you need to do,
1.Turn the air cleaner OFF and unplug it from the power outlet.
2. Carefully lay the unit down on a flat surface with the Front Grille facing up.
3. Gently push in on Release Buttons on both sides of the unit, pull Front Grille out and away.
4. Remove and discard used HEPA filter.
5. Remove any plastic protective wrapping and from the new HEPA filter.
6. Set new HEPA filter into the air cleaner.
7. Install the Front Grille by engaging its tabs into the bottom slots on the unit. Then swing grille up and gently push in top to snap into place.
8.Turn the Air Cleaner upright and plug it into an outlet for
operation.
Hope this helped you. Please let me know. Thanks
May 04, 2011 | Kenmore 335 CADR Air Purifier
How do you replace batteries in freshair remote control . i cant get the back off the remote control.
For the Fresh Air 2.0 or 2.1 remote, its oval shaped.
1. Hold the remote so that that the power button is facing up.
2. Then flip the remote in your hand so you can see the back side.
3. Then with your other hand, side your index finger from the top down the back side of the remote until you finger nail catches the a slot (about an inch from the top of the remote). Right below that slot, is a plastic tab that secures the battery cover. Using your finger nail, pull that tab down about 1/16" away from the remote to unlatch the cover.
4. Lift the cover off the remote, and you should see 2 AAA batteries. Remove the old batteries and replace with 2 new batteries.
5. Align the two tabs on the battery cover into slots on the back of the remote.
6. Gently press the back cover and the latching tab should shap into the remote.
Hope this helps.
Jun 14, 2010 | Ecoquest Fresh Air Air Purifier
Ionic Breeze GP S1830 - makes a sizzeling noise
Funny you should post this when you did as I just finished reassembling my S1730.
Mine was making very loud noise, arcing violently, smoking slightly and would give a good shock when you touched the plastic covers(yes dirty plastic will conduct electric current).
1. Unplug the unit
2. Take the plastic covers off, front has four screws and back has snap at bottom, both slide up when loose.
3. Wash the plastic covers
4. take the light out and clean it with windex
5. Vacuum the inside, be careful of the two corona wires
6. Find the bead on each corona wire and while turning them slight so the edges scrapes the wire, move them back and forth to scrap the white power off the wires
7. scrape the cone shape plastic that the corona wires runs into, this build up is the primary culprit of the arcing which is the noise you hear. be careful of the corona wires again. I used an exacto knife and gently scraped it, sandpaper has been suggested elsewhere, once done scrapping, wipe down to clean any residue. The top cones are only part accessible, after cleaning mine the noise still persisted but acceptably lower than before. I think if you completely take apart the unit you can clean this cones better.
8. Reassembly is the same is opposite of disassembling.
Hopes this helps you.
Aug 21, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
I can't get the cover back on
the plastic part that you are referring to is the lock or bracket that the door needs to lock into to and then it should swing shut. make sure that the filters are snug in there and not blocking the way of the door shutting cause that can cause things not to work right. if you have any other problems please let me know and i'll see what else we can do.
Sep 13, 2008 | Holmes Products HAP726-U Air Purifier
Can't remove the filter from my Pur Flavor Options faucet mount water filter
When mine gets stuck I stick the handle of a fork or spoon into the hole where the water comes out and use that to unscrew it. Works like a charm every time.
Aug 04, 2008 | PUR (FM-9500) Air Purifier
Wont run after I cleaned it
On the model 30200 there is a safety interlock switch actuated by a plastic tab (about 4" down from the top of the front filter cover) on the right side. Assuming that all you did was take off the front cover and clean or replace the filter(s) and the unit was working previously, this should be your answer. If in taking off the cover the switch actuation tab was broken off, you could (carefully) wedge a tab into the slot where the switch resides. This defeats the safety aspect of certifying that the unit isn't running when you remove the cover. The safe work-around is to unplug the unit before you open it for service.
Feb 09, 2008 | Hunter 30200 \ 30010 (Set) Air Purifier
Whirlpool Whispure 510 Air Purifier Logo
122 people viewed this question
Top Whirlpool Air Purifiers Experts
ray gallant
Think Crucial
Think Crucial
Vladimir Frolov
Are you a Whirlpool Air Purifier Expert? Answer questions, earn points and help others
