Philips DVD Player DVP 3026 set for Region 5 - Unlock code
Can you help me unlock the above
  • Anonymous Mar 14, 2014
    Unlock Philips dvp 2800
  • 376 Answers
1) Open the tray
2) Press SETUP on the remote.
3) Navigate to PREFERENCE menu
4) Go to PBC
5) Get in inside PBC menu so that ON is highlighted with yellow color
6) Key in 138931 and a menu will appear asking you to select region code.
7) Select REGION 0.
Posted on Sep 09, 2008
Require a Unlock Code for region free
DVP 3618 - how to unlock region codes?
1. Power ON the DVD player with no disc inside
2. Go to the SETUP icon and press OK; next, go to
Preferences and press OK
3. With preferences highlighted,
3a. Press NEXT CHAPTER (button above AUDIO, it looks like
this: >'),
3b. Press PREVIOUS CHAPTER (button above SUBTITLE, it looks
like this: '<)
3c. NEXT CHAPTER >'
3d. PREVIOUS CHAPTER '<
4. The OSD will show the current Region Code
5. Press the Navigation Up or Navigation Down buttons to
select your desired region, or 0 for region free
6. Press OK to confirm your region selection
It works for DVP 3618 model.
Dec 04, 2013 | Panasonic DMR-EZ47V DVD Recorder/VCR
I bought some DVDs at amazon.com, but I live outside the region code area witch the DVDs are supposed to work. I live in code area 4. I need someone to find a code to region 1. I have a Phillips home...
This player is relatively easy to change to region free. Please complete all of the steps below to unlock your DVD player.
Please note: Unlocking any DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
Unlock sequence for the Philips DVP 3020:
1. Switch on your TV and DVD player;
2. Make sure the TV is set to the correct input for the DVD player;
3. Remove any disc from the DVD player and close the disc tray;
4. Press the "SETUP" button on the DVD player remote control;
5. Use the LEFT/RIGHT arrow keys to highlight "PREFERENCE";
6. Enter 1 3 8 9 3 1 using the numerical keys on the Philips DVD remote control;
A pop-up menu will appear on the TV screen.
7. Use the UP/DOWN arrow key and choose "0" for all regions;
That's it. You should now be able to watch DVDs from all regions on your player. It is also a good idea to switch the player to standby and then switch it back on before trying any discs.
This is a verified unlock sequence for the Philips DVP 3020. If it doesn't work the first time, switch the power off and start again at step 1. If it still doesn't work, it is likely that you have updated your Firmware to a new version and this unlock sequence does not work with your firmware version
If you need further assistance, please reply to me from within this page and let me know which firmware version you have installed in your DVD player.
Regards,
BElectric.
Jan 28, 2011 | Philips Televison & Video
How do I unlock my Sony DVP - NS330 player, bought
Codes for-
Sony DVP-NS300, Sony DVP-NS305, Sony DVP-NS400D, Sony DVP-NS700, Sony DVP-S330, Sony DVP-S335, Sony DVP-S360, Sony DVP-S336, Sony DVP-S525D, Sony DVP-S530D, Sony DVP-S535D, Sony DVP-S536D, Sony DVP-S725D, Sony DVP-S735D
Turn on the unit with the remote controller, Wait until "no disc" appears in the unit's display. Press the keys: PAUSE, 3, 1, 4, 1, 5, 9. And "CODE" will appear in the display. Press the number key that corresponds to the disc zone you want to play within the next 5 seconds:0: All regions / 1: Region#1 / 2: R#2/... and so on. Then, within 5 seconds, press: PAUSE, POWER... and voilà. If you don't have good results, disconnect the equipment and repeat.
Or
Put your player in standby mode and then enter: [[0] [ENTER] Default Default region code [1] [ENTER] or [UP] [ENTER] Region 1 [2] [ENTER] or [RIGHT] [ENTER] Region 2 [3] [ENTER] or [DOWN] [ENTER] Region 3 [4] [ENTER] or [LEFT] [ENTER] Region 4 [5] [ENTER] or [TITLE] [ENTER] Region 5 [6] [ENTER] or [DVDMENU] [ENTER] Region 6 [7] [ENTER] or [RETURN] [ENTER] Region 7 [8] [ENTER] or [DISPLAY] [ENTER] Region 8
Or
Put player into standby modes by pressing power button on remote control. Then press Title button. Press Clear button. Press Power button.
Yours is not listed but these may be worth a go.
or try http://www.haldigital.com/hp/dvd.htm
May 15, 2010 | Sony DVP-NS330 DVD Player
Unlock region code for Philips DVP 3256
Region code hack for PHILIPS 3256 x/94
1. Go to Setup. [from remote]
2. Select the Preference Page.
3. Press 1, 3, 8, 9, 3, 1 on the Philips DVD Player remote.
--> It will show current region code [ for example 5 ]
4. Now Press the up/down key to select "0" which makes it region free.
5. Press ok and exit setup.
Probably the same would be applicable for 3258, 3268, 3986.
Good Luck!
Jan 02, 2009 | Philips DVD625 DVD Player
Unlock region code
Keep Tray in eject position
Press Setup from remot
Go to preference page
Press"138931"
Using Navigation Key chane region code to "0"
Press "OK"
OR
open tray
press 98790
Jun 25, 2008 | Philips DVP3040 DVD Player
Unlock region codes
Hi All,
I am looking for the region unlock code for a Sony portable
DVD player.Model number DVP-FX720
Jan 12, 2008 | Insignia NS-PDVD8 Portable DVD Player
Region Free Code: Philips DVP 5980
this worked perfectly, thank you!
Dec 19, 2007 | Televison & Video
Region codes
Philips DVP 3015K / DVP 3020 / DVP 3040 / DVP 3040K / DVP 5140 / DVP 5960
  1. Method 1:
  2. Open the disc tray
  3. Press SETUP
  4. Navigate to the preferences page
  5. Enter 138931
  6. Select the region using UP/DOWN
  7. Press PLAY
  1. Method 2:
  2. Open tray
  3. Press 9, 9, 9, 9, 0
Televison & Video Logo
694 people viewed this question
Top Televison & Video Experts
