Question about InterAct Accessories InterAct UltraRacer PC (SV-284) Game Pad
Using ultra racer pc controller with 15 pin to usb cable on windows vista. windows does not "see" when connected for calibration
Pin locations
get a 15 pin male, to 15 pin female, to male usb on the female adapter
Jun 18, 2013 | Video Game Consoles & Games
I have acer n30 pc pocket. when i connect the usb cable for chasrging it dosen't get start and i can see the message on the scree "align screen" so what is a exctly solution pls tell me...
This happens when you get new one or after reset. It wants from you, to touch 5 points on the screen to calibrate touch screen.
Start acer without connecting usb cable and calibrate it first.
Jun 10, 2011 | Acer n30 Pocket PC
My TV (42" Full HD
Yes you can - but not with a USB cable. USB is only for data (file) transfer.
What you are attempting to do is use your TV as a PC monitor, therefore it needs to be connected to your TV using a PC monitor cable (15-pin D-SUB/VGA). You will also need a separate audio cable from your PC to your TV if you want to use the TV speakers for audio. If you are using a receiver or amplifier with external speakers, you can connect the audio out from the PC directly to the amplifier/receiver.
It is also possible to connect the PC to the TV with an HDMI cable if your PC has an HDMI out port. However, some TVs wont accept an HDMI signal from a PC and this method of connection can cause other issues, so I would recommend using the PC monitor cable method.
Please let me know if you need further assistance.
Regards,
BElectric
Jan 08, 2011 | Element Electronics FLX-3211B 32 in. LCD...
Usb handy cam is invalid when i connect my camcorder to my pc
Option 1:
If you want to use the USB cable to connect the Camcorder to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port.(An i.LINK is a black D shaped connector with 4 or 6 pins. The type ofcable to be used will depend on the i.LINK port of your Computer. TheSony Camcorder will have the 4 pin i.LINK cable and if the computer hasthe 6 pin i.LINK port, then you may have to use the 4 pin to 6 pini.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE:As the Camcorder does not support USB streaming with Vista, it is notrequired to use any Sony Device Driver to transfer the video to theComputer. You do not require any Drivers or Software from Sony totransfer the video from the Camcorder to the Computer using thei.LINK/Firewire interface.
Option 2:
(Applicable for Windows XP Operating System only):
Ifyou are using a Windows XP Operating System then you have to installthe USB Streaming Driver in the Computer from the supplied Softwaredisk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
NOTE: If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Good Luck!!!!!!!!!!!!
Oct 01, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
Unable to transfer video information onto PC ACER ASPIRE using windows Vista for editing by windows movie maker. Interface on PC is via USB. If software driver for firewire or 1394 interface is available...
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Sep 28, 2009 | Sony Handycam DCR-TRV16E Mini DV Digital...
Need to transfer video from my sony handycam to my pc
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
NOTE:As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this link for the instruction to transfer video to a Computer using USB Streaming.
Good Luck!!!!!!!!!!!!!!!
Sep 14, 2009 | Sony Handycam DCR-TRV350 Digital Camcorder
My sony camcorder DCR TRV19cannot be detected on my vista computer
The videos from the tape camcorders cannot be transferred to Windows Vista Operating System as there is no USB Streaming ooption available on the Windows Vista Operating System.
The Camcorder uses the USB Streaming function to transfer the videos to the Computer.
You may wish to purchase a i.LINK/Firewire cable to connect the Camcorder to the Computer in order to transfer the videos from the Camcorder to the Computer.
The i.LINK cable is a D shaped port labeled as i, DV, IEEE1394. Please refer to your Computer manual to check whether there is an i.LINK port on the Computer.
Sony Camcorders contains 4-pin i.LINK port on it.
If your Computer has a 4-pin i.LINK port, then you can use a 4-pin to 4-pin i.LINK cable to connect the Camcorder to the Vista Computer.
If you're Computer has a 6-pin i.LINK port on it, then you can connect the Camcorder to the Computer using a 4-pin to 6-pin i.LINK cable.
You may wish to click the link below to get more details about the 4-pin to 4-pin i.LINK cable.
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=11039459&tab=Features
You may wish to click the link below to get more details about the 4-pin to 6-pin i.LINK cable.
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=11040679&tab=Features
Jul 10, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
Transferring from Windows XP to Windows Vista
use usb flash dis/hard drive to move data from one to other laptop.
Oct 24, 2008 | Eisenworld Alohabob PC Relocator Ultra...
We cannot connect the camcorder to our PC, we have followed instructions and reinstalled several times, but our PC does not recognise the camcorder!
if it's tape model must use firewire cable-no usb for video transfer-camcorder has dv port which is 4 pin and laptop has 4 pins and desktop and mac 6 pin-use movie maker program in windows xp or vista
May 20, 2008 | Panasonic Cameras
Can't get it on my PC
won't work usb -only for photos-use dv connection and get firewire cable to go from camera to comp-4-4 pin for laptops 4-6 pin for mac and desktops-use windows movie maker in xp or vista to edit
May 17, 2008 | Canon Elura 100 Mini DV Digital Camcorder
InterAct Accessories InterAct UltraRacer PC (SV-284) Game Pad Logo
354 people viewed this question
Top InterAct Accessories Video Game Consoles & Games Experts
James Wishart
Are you an InterAct Accessories Video Game Console and Game Expert? Answer questions, earn points and help others
